September 15, 2026, 10:01:58 am
Hoffman Amps Forum image Author Topic: What do you think of this idea  (Read 7488 times)
« on: April 22, 2014, 02:34:58 am »
Hi guys, After tapping my fingers RAW on the keyboard looking for answers on the "MYSTERY AMP" and I'm sure that you guys have had a similar quest. Even doing the restore on the Fi Sonic was a fun exercise that turned up very little.
This got me thinking about the AMPS I have built, I have since loaned some of these amps to the professionals that can put then to good use................
What if I was to come to an early DEMIZE or just grow old and forget to whom they ended up with................
As with the "MYSTERY AMP" there is absolutely NO clue to the person/s that took the time to build this amp and no clue to the intending design of the circuit.
A  "TIME CAPSULE" of sorts that contains a schematic, design detail/origins and other info.
I was thinking a piece of 1/2" conduit with a cap at either end that would contain a printed copy of the schem,etc. This could be fixed inside the cab/chassis.  :icon_biggrin:
Offline Jack_Hester
  • Greybeard
Re: What do you think of this idea
« Reply #1 on: April 22, 2014, 03:58:28 am »
Be sure to laminate it, to protect it from moisture and mildew.  So far, I've only used acid-free sheet protectors.  Laminating will protect it for ages.
Jack
« Last Edit: April 22, 2014, 11:00:09 am by Jack_Hester »
"We sleep safe in our beds
                                                   ---George Orwell
« Reply #2 on: April 22, 2014, 08:13:09 am »
In some old amp you can find a printed copy of the schematic attached inside the cabinet
I think you had a good idea  :thumbsup: :thumbsup: :thumbsup:
« Reply #3 on: April 22, 2014, 10:15:39 am »
I think it's a great idea too.
Your amps are definitely 1 of a kind builds, so why not write down their story?
             Brad     :icon_biggrin:
« Reply #4 on: April 22, 2014, 11:18:57 am »
I have a schematic and board layout stuffed in an envelope inside the cab for all my amps that have a cab. I like the pipe idea more. Maybe even screw a couple clamps to the cab to secure the conduit.
« Reply #5 on: April 22, 2014, 12:06:35 pm »
You can easily take a router and use a round router bit to route out a groove on the underside of the bottom of a cab and attach a pipe there with the info inside.  Totally out of the way and not exposed to heat or loose effects pedals carried inside the cab, etc ................
Offline Platefire
« Reply #6 on: April 22, 2014, 12:14:56 pm »
I have done an envelope taped to inside (like sluckey) of cab with info inside, also glued a schematic to chassis and used decals with info. The PVC with caps and mounting bracket I think is a good idea as long as the next owner has respect for the system and maintains it. That's the reason you get amps with back-plates and other stuff missing because some people have no concept of keeping all the original parts or info on a amp. So along with the time capsule you probably need to include a speech/warning of the importance of updating and putting the info back where it belongs after viewing it.
On the right track now<><
« Reply #7 on: April 22, 2014, 12:23:32 pm »
Laminated manila envelope, one face affixed to cabinet wall. Schematics/documentation, etc in envelope (laminated if you like).
« Reply #8 on: May 21, 2014, 06:13:20 pm »
> I was thinking a piece of 1/2" conduit with a cap at either end that would contain a printed copy of...
If you have more than a slip of paper, and value your time more than a few bucks an hour, you might consider these:
Canister | Manual Holder | Manual Tube | Document Canister | Document Holder
With pictorial instructions! (Take out, read, put-back!)
Made to go on a tractor (harvester, combine, seeder, etc). Weather resistant. Tough. By the time you go to the store, cut PVC pipe, caps, brackets, you are well into the $4 cost of the 2" tube.
I just got a 1968 tractor plus a stack of manuals, so I'm looking at the 11'x14" job to keep all that stuff at-hand and *with* the machine when I am gone.
I know nothing about the company except they sent me a catalog (I get on some odd lists). The catalog is unpretentious hard-core farm hardware. Harrow disks, flail mower blades, subsoilers. Retail outlets in NC, SC, GA, VA... summa you might just go over there.
--- Edit-- the $10 flat-manual holder is $14 shipping to Maine, so buying one/two is not cheap.
« Last Edit: May 21, 2014, 06:18:52 pm by PRR »
Offline Jack_Hester
  • Greybeard
« Reply #9 on: May 23, 2014, 03:57:10 am »
When you print the schematic or other info, print on bonded paper, as most bonded paper is acid free.
I have printed on "vellum", or an engineering drawing paper that seems to hold well.  (40 years on some).
Is vellum still available?  As we no longer have a drafting department on site, I haven't seen vellum used in quite a while.  I like it.  A friend of mine has a beautiful 'Kentucky' rifle drawn on vellum, and framed.  Nothing like it.
Jack
                                                   ---George Orwell
« Reply #10 on: May 23, 2014, 05:36:42 am »
« Reply #11 on: May 23, 2014, 05:30:06 pm »
I like the item to which refers PRR, but if you have difficulties to get it
This thing put on me an idea, why don't add to the amp a socket with tube shield
put on the top (internal side) something as shutting (a proper size coin ?) and label the external in the same manner is labeled the item proposed by PRR
use this receptacle for your documents
« Last Edit: May 23, 2014, 05:32:23 pm by kagliostro »
Offline Jack_Hester
  • Greybeard
« Reply #12 on: May 23, 2014, 07:52:27 pm »
http://www.dickblick.com/products/clearprint-1000h-drafting-vellum/
Still available. Are those decent prices?
I would say that for it's intended purpose (as suggested in this thread), the 100-sheet packs are what I would consider reasonable.  Thanks for the link.
Jack
                                                   ---George Orwell
« Reply #13 on: May 23, 2014, 08:29:02 pm »
You're welcome. I don't think I've ever had my hands on vellum, so I was curious. Not something I remember seeing at Staples.  :icon_biggrin:
