September 17, 2026, 04:18:27 pm
Hoffman Amps Forum image Author Topic: Is possible I've seen a schematic with a lamp used in NFB circuit ?  (Read 5735 times)
Seems to me that some time ago I've seen a schematic on which a lamp (filament or neon ?) was used on the NFB circuit
may be the schematic was from one of the Radiotron Handbook's, but I don't remember well
Someone remember such a circuit ?
Re: Is possible I've seen a schematic with a lamp used in NFB circuit ?
« Reply #1 on: April 23, 2014, 05:55:22 pm »
I don't see why not,
Just off the top of my head, I do not believe that a standard neon light would work, (minimum voltage requirements).
I could see LED's usd in NFB loop, possibly with a selector to choose colors and to tune the loop
What a cool idea!
Offline printer2
« Reply #2 on: April 23, 2014, 07:26:54 pm »
There was incandescent bulbs used across the output as a sort of powersoak (or maybe I was dreaming about it).
« Reply #3 on: April 23, 2014, 07:35:21 pm »
Seems to me that some time ago I've seen a schematic on which a lamp (filament or neon ?) was used on the NFB circuit ...
It was the basis of Hewlett-Packard's first product (an audio oscillator), which launched them into the test equipment market.
The oscillator used a lamp in the cathode, which was also a negative feedback return. If the oscillator signal tended to get bigger, the lamp turned on harder and was a larger resistance (it had a positive temperature coefficient; more current = more heat = higher resistance). Being in the cathode circuit, it created a larger bias voltage under these conditions, which tended to turn the oscillator off. If the oscillator signal dropped, the lamp became a smaller resistance, creating less bias voltage, which turned the oscillator more-on.
The lamp-stabilized negative feedback circuit created a nearly-constant output level with changes of frequency and over time, which made the H-P oscillator valuable among its competitors.
See the schematic below.
Offline darryl
    • ValveTone Amplification
« Reply #4 on: April 23, 2014, 07:56:00 pm »
Radiotron Designer's Handbook Version 4. Chapter 16. Volume Expansion, Compression and Limiting.
« Reply #5 on: April 23, 2014, 11:40:41 pm »
@ Drgonzonm
I agree with Tubeswell, interesting idea, thanks, can you explain it a bit further ?
@ Printer2
As far as I can remember there was a discussion about a filament lamp in series with a cap, this elements were placed in parallel with the output of the amp, PRR gave some explanation about
@ HotBluePlates
That schematic was one I've find searching on the Radiotron 4 before asking here, thanks for the explanation, very interesting
@ Darryl
Many Thanks you got it ! That is exactly what I remembered, my search was without result because Radiotron has more than 1500 pages
« Reply #6 on: April 24, 2014, 12:48:50 am »
> Hewlett-Packard ... oscillator used a lamp...
FWIW, Meacham of BTL lamp-stabilized a crystal oscillator at about the same time.
« Last Edit: April 24, 2014, 12:51:17 am by PRR »
