September 17, 2026, 09:45:19 am
Hoffman Amps Forum image Author Topic: Tube crowbar  (Read 5309 times)
Tube crowbar
« on: May 08, 2014, 10:38:47 pm »
I discovered one other particular tool
the Hytron Tube Lifter
a crowbar to be used with tubes  :w2:
isn't excessive and unsafe ?
(Edit: Cropped and resized to meet the 1024 pixel size limit. Image Size Post
« Last Edit: May 09, 2014, 06:05:05 pm by HotBluePlates »
Re: Tube crowbar
« Reply #1 on: May 09, 2014, 06:12:35 pm »
It might be excessive. But I've had tube sockets so tight before that trying to wiggle or rock the tube out risked cracking the glass at the pins.
And the tool is only unsafe if you use it in an unsafe manner.
stratele52
  • Guest
Re: Tube crowbar
« Reply #2 on: May 14, 2014, 02:51:53 pm »
Look to be in steel = danger ,
 IMO  better to use your hand to not break the tube . If you need that tool something wrong with tubes / socket , better to see what before break the tube
