September 14, 2026, 10:20:14 pm
Hoffman Amps Forum image Author Topic: Hoffman ReVibe Turret Board  (Read 57398 times)
« on: July 31, 2014, 10:59:27 am »
The layout Diagram, Schematic and BOM and other build information can be found on the library page here
http://el34world.com/schematics.htm
Layout and Schematic
http://el34world.com/Hoffman/files/Hoffman_ReVibe.pdf
BOM - Parts list
http://el34world.com/Hoffman/files/Hoffman_ReVibe_BOM.pdf
Hoffman Board install instructions
Hoffman Turret Boards are on this page
http://hoffmanamps.com/MyStore/catalog/TurretBoard.htm
Hoffman amps Public parts list page is here
http://hoffmanamps.com/MyStore/catalog/PartsListIndex.htm
« Last Edit: February 27, 2015, 02:09:06 pm by EL34 »
Watto
  • Guest
Re: Hoffman ReVibe Turret Board
« Reply #1 on: March 01, 2015, 08:24:28 pm »
Probably a silly question but does the Hoffman Board for this build fit into the Weber Revibe Chrome chassis ?
Cheers
Watto
« Reply #2 on: March 01, 2015, 09:51:28 pm »
« Reply #3 on: March 02, 2015, 06:00:49 am »
I didn't know Weber still made them
At one point 4 out of 5 of them seemed to be bad
the spot welded ends just fell out of them
That's a weber chassis in the link above that Steve provided
Watto
  • Guest
« Reply #4 on: March 02, 2015, 04:59:13 pm »
Yeah I found that problem with  the spot welds before, I hope this one is up to scratch , They do sell them , mine is on it's way :-)
Offline steven
« Reply #5 on: May 15, 2015, 02:42:29 am »
Hi Doug -
I was tracking down an issue in my Revibe, and I think I found another couple of cut and paste errors on the Revibe layout. In the schematic, C24 and C25 are .047, but on the layout they are .0047. I'm guessing you cut and pasted C31, which really is .0047
Steven
« Reply #6 on: May 15, 2015, 06:34:25 am »
Thanks for the heads up
C25 is a .022, not a .047?
This appears to be correct
C24 was wrong on the layout but it was correct on the schematic and BOM
I uploaded a new revibe PDF file
Hit refresh after it loads to get the new version
« Last Edit: May 15, 2015, 06:50:29 am by EL34 »
Offline steven
« Reply #7 on: May 16, 2015, 05:18:23 am »
Sorry, C25 was a typo, I meant C28
There were 3 .0047 in a row, I think the last two (24 and 28) are .047
steve
« Reply #8 on: May 16, 2015, 07:19:25 am »
Ok thanks, I fixed that one also and uploaded a new PDF file
I updated the BOM with a new format
Offline MoparWade
  • Tube or Die
« Reply #9 on: February 05, 2016, 01:31:15 am »
This may be a dumb question but I'll ask it anyway. Is the ReVibe intended to power a speaker? I am new to this and really liked the sound of the ReVibe, would like to build a complete amp out of it.
Fast Cars and Loud Guitars
« Reply #10 on: February 05, 2016, 06:30:46 am »
No, it is an effect just like a stand alone reverb unit. You plug into it and then plug the revibe into an amplifiers
Offline bnwitt
  • Crankin' out the tone.
« Reply #11 on: March 10, 2016, 05:54:30 pm »
what's up with the extra turret on the second row from the bottom, which is to the right of the 68k resistor and to the left of the 220k resistor off of V3 pin 5
12 component columns from the left?
« Reply #12 on: March 11, 2016, 05:56:42 am »
It must have been left behind in editing :)
I uploaded a new PDF
Offline bnwitt
« Reply #13 on: March 16, 2016, 12:10:02 pm »
Cool.  That means I don't need to drill another hole in this beautiful board you already made for me Mr. H :grin:
« Reply #14 on: March 17, 2016, 05:39:59 am »
The lug was on the layout, but not on the board?
I don't remember if I had to remove it from the CNC file or not
Offline BetterOffShred
  • I play tube amps..
« Reply #15 on: December 28, 2016, 03:34:20 pm »
Is there a simple way to use a 2-button stomp box for this?   Use a stereo jack maybe and hook up J5 and J6 (from the schematic) accordingly?  I was curious as the layout seems to use a separate stomp for each.
EDIT:  Or do you just use RCA jacks, and then get that 2 button fender stomp box from Doug's Foot Pedals page?  That looks like it would work.. The Vibrato uses the grounded shield one right?     Sorry for the dumb questions!
-Brett
« Last Edit: December 28, 2016, 03:51:54 pm by BetterOffShred »
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #16 on: December 28, 2016, 03:56:57 pm »
I don't see any reason you couldn't do that.  Just connect one of the two wires to the tip, one to the ring, and ground the grounding point, then have two separate switches in a stomp box type setup with one connected to the tip, the other to the ring.  It accomplishes the same thing, you just need to have the switch lift ground or send to ground for both.
Phil Davis
tUber Nerd =|D
« Reply #17 on: December 28, 2016, 04:16:20 pm »
Yeah I wanted to make a more traditional style "Stomp" box (1590B) with 2 Big stomp switches in it to fit the aesthetic of my pedal board when I decide to tackle this project. I'd have to use a stereo plug end on my box cord, but that's no biggy.   Something to think about.  Thanks for the reply :)
-Brett
« Reply #18 on: December 28, 2016, 04:31:34 pm »
It's exactly the same as a Vintage Fender foot switch
So as long as you do it that way, you are good to go
Does not matter what kind of box the switches are in
« Reply #19 on: December 28, 2016, 04:36:19 pm »
Very Cool.  Thank you good sirs!   I already bought the reverb tank from you recently to make a reverb vibrochamp, but I'm going to just go regular viborchamp and build a revibe  instead!  Appreciate the help!
-Brett
