September 18, 2026, 02:05:07 pm
Hoffman Amps Forum image Author Topic: Build recommendations for this Power Transformer  (Read 7139 times)
Offline goldstache
« on: August 20, 2014, 04:41:34 pm »
I've got a new in box NOS Chicago Transformer PT
Here are the specs:
350-0-350 120MA
5V 3A
6.3V CT  4.5A
I would like to make a brownface voiced amp and would really like to add reverb.  Trem isn't a necessity.
Anybody got ANY suggestions?  I am open to everyone's input.  Would like clean over mean, although a little in-between sounds cool too!
I kind of would like to end up with a brownface princeton with verb!
Re: Build recommendations for this Power Transformer
« Reply #1 on: August 20, 2014, 07:07:56 pm »
dilemma: brownface amps didn't have reverb...
princeton reverb with P-P 7591 cathode biased.  with your PT, B+ should be around 450V with SS; w/ GZ34 about 10V less.
delete bias supply and tremelo ckts.
idle @ ~40mA/7591; load ~8-9K @ ~25W.  <-- likely a custom wind or one of the hammond one_size_fits_all...
that's the only thing i can think of other than a SE plan with a big bottle or possibly P-P 5881's into 6-7k load.
http://frank.pocnet.net/sheets/127/7/7591.pdf
Offline thermion
  • Repeat Of Fender
« Reply #2 on: August 21, 2014, 03:14:51 pm »
Insert reverb a' la 6g16 vibroverb?
« Last Edit: August 21, 2014, 03:40:06 pm by thermion »
Offline goldstache
« Reply #3 on: August 23, 2014, 10:35:40 am »
Thanks for the recommendations!  I have this amp that a guy built me back in the mid 2000's.  I would like to build something similar and add verb to it.
Can anyone distinguish the markings on the transformers that are on the amp?
I searched them on the net and found nothing.  Do they look familiar?????
Offline goldstache
« Reply #4 on: August 23, 2014, 10:36:28 am »
and here is the PT
« Reply #5 on: August 23, 2014, 02:44:45 pm »
they look like custom wound PT & OT by hyboer transformers. call heyboer and give them the part numbers and they should be able to provide the specs.
they were manufactured 2006, 43 week.
« Reply #6 on: August 23, 2014, 06:40:36 pm »
Ooh, ooh, ooh, please let us know if indeed those are Heyboers, because I have a NOS "JTM-45" PT whose label looks exactly the same (except for the different numbers, obviously)
« Reply #7 on: August 23, 2014, 07:13:02 pm »
I don't understand.
If 1 of the #'s starts with 996 it's a Hyboer.
                  Brad    :think1:
Edit: Corrected spelling of Hyboer. Brad
« Last Edit: August 23, 2014, 07:58:30 pm by Willabe »
« Reply #8 on: August 23, 2014, 07:33:16 pm »
The obvious label similarity. I didn't know about the EIA/mfr number. Sorry.
« Reply #9 on: August 23, 2014, 07:55:55 pm »
Nothing to be sorry about.    :icon_biggrin:
I just wasn't sure what you wanted to know. I only knew 996 was Hyboer because of Pete's post.
            Brad     :icon_biggrin:
Offline goldstache
« Reply #10 on: August 24, 2014, 09:12:23 am »
I fired off an email and am awaiting a response!  Thanks! I will keep ya posted.
Offline goldstache
« Reply #11 on: August 25, 2014, 08:30:16 am »
They are indeed Heyboer.  And they sent the specs in their gracious reply.
I was surprised to see that the PT was 190v-0-190v @400ma!!!!!  Wow that's a lot of current for a two stage pre, LTPI, power section PP 30watter?!
Also no bias tap.
I thought the secondaries were gonna be a lot higher.  I wasn't going to take measurements unless I didn't hear back from Heyboer.
Thanks guys!
« Reply #12 on: August 25, 2014, 09:49:51 am »
Also no bias tap.
Thanks guys!
what is the OT?
Offline goldstache
« Reply #13 on: August 25, 2014, 11:10:35 am »
As I suspected 3.3k primary
Offline goldstache
« Reply #14 on: December 09, 2014, 07:27:28 pm »
I want to make an ampeg SB-12 with the transformer mentioned in the first post
350-0-350 @120ma
5V @ 3A
6.3V @ 4.5A
But I think I'm trying to hard to use the wrong power transformer.
So........ I've decided to make a single ended KT 88 amp with reverb.
Tube rectified preferred.
Does anyone have a shared schematic that could be a starting point?
