September 16, 2026, 03:56:55 am
Hoffman Amps Forum image Author Topic: Hoffman Turret Board with Black G10  (Read 10971 times)
« on: August 24, 2014, 04:52:47 pm »
How do you like the first black Hoffman Turret board?
I now stock black on this page
http://hoffmanamps.com/MyStore/catalog/parts12.htm
It is non conductive G10 for those that are afraid of it  :icon_biggrin:
« Last Edit: August 24, 2014, 06:23:50 pm by EL34 »
Offline labb
Re: Hoffman Turret Board with Black G10
« Reply #1 on: August 24, 2014, 05:26:42 pm »
Been some issues with black boards  being conductive. Might want to check.
« Last Edit: August 24, 2014, 05:31:54 pm by labb »
« Reply #2 on: August 24, 2014, 05:33:39 pm »
It takes decades of humidity for black fiberboards to become conductive. It should take many more decades for a black glass/epoxy board to become conductive (if it ever happens).
« Last Edit: August 25, 2014, 12:52:25 am by HotBluePlates »
« Reply #3 on: August 24, 2014, 05:35:10 pm »
My understanding is Doug has already checked out the "conductivity issue" on the black board and there is reportedly no concern with these boards.
I think the black boards look really great!  Populated they'd look even better.  The black contrast with caps, resistors, etc... should look pretty cool!
Offline Mike_J
« Reply #4 on: August 24, 2014, 05:37:30 pm »
I like the look and will be ordering some soon.
As a side note, years ago I bought the metal tool with the holes in it from your store that I use all the time to space my layouts.  I routinely use 1/8" eyelets in addition to the turrets and haven't had any trouble with the spacing.  I think I read recently that you only recommend that spacing for the turrets.  Am I correct in that?  Glad I bought one before you quit selling them.  Very good tool to have for amp building.
Mike
« Reply #5 on: August 24, 2014, 05:38:59 pm »
apparently some of the G10/FR4 is treated to be anti-static and therefore semi-conductive, however, not all black G10/FR4 is anti-static treated.
« Reply #6 on: August 24, 2014, 05:50:32 pm »
Cool Board   :thumbsup:
« Reply #7 on: August 24, 2014, 06:00:45 pm »
Mike
I think you are talking about the 1/4 inch thick aluminum drilling template.
Nothing has changed, I still use that same spacing on my CNC machine
As long as the eyelet rims are not too close to each other, it should work just fine for eyelet spacing
« Last Edit: August 24, 2014, 06:39:52 pm by EL34 »
« Reply #8 on: August 24, 2014, 06:03:35 pm »
This board is not conductive
Fender type fiber board is way more conductive than this G10
When I get time, I'll take a scrap of the black board and hook it up to 400+ VDC and see if I can get a reading to another lug next door
I get zero reading with the test leads 2mm apart using a meter checking for resistance
« Last Edit: August 24, 2014, 06:37:00 pm by EL34 »
« Reply #9 on: August 24, 2014, 08:09:52 pm »
I'm the guy that started the conductive black board scare of 2013.
When I first started doing amps I bought 6 of these boards (pictured) from AES because I liked the "universal" punched board idea, and I liked the look of the black board.
Luckily, I found the conductive board on my first build and sent the other 5 boards back. It pissed me off as much as anything I have ever experienced because of the amount of time that I had spent trying to achieve a super clean board look, with nicely bent components and all of that rigmarole.
When I completed the amp I found that I had DC on one of my pots,,,and after a short diagnosis (and coupling cap replacement), I disconnected everything form the suspect turret and I almost broke my hand on my workbench when I measured 100VDC from a turret to ground with the turret touching nothing but the board. I am 1000% sure of what I experienced and even brought over one of our repair techs to confirm I hadn't lost all of my marbles.
I kept a piece of the board material to compare it to black G-10, and it is not the same material. The stuff from AES just feels cheaper, and does not have the high quality appearance of true Garolite.
Since that time I have bought a sheet of G-11, and I've been using black G-10 from one of Doug's competitors.  :embarrassed:
I am thrilled to see Doug now carrying the black G-10, and will be ordering my next piece from him in the very near future.
 :wav:
This is the crap board that I had to warn my fellow forum members against using:
« Reply #10 on: August 24, 2014, 08:20:46 pm »
Excellent report
I think the black board I did today looks great
It goes with both my black fully carbon bikes
Offline labb
« Reply #11 on: August 24, 2014, 08:24:27 pm »
The boards that I was thinking about did come from CE. I am sure Doug's are fine. Take a look at this video--This was a CE board.
https://www.youtube.com/watch?v=p-c3nTyobds&feature=youtu.be
« Reply #12 on: August 24, 2014, 08:27:47 pm »
Good video
I am not sure why CE is selling these boards?
Do they still sell them?
Offline labb
« Reply #13 on: August 24, 2014, 08:36:44 pm »
The guy that posted that said he contacted them and returned the boards he had. They replaced them and took the black ones that they had out of stock.
« Reply #14 on: August 24, 2014, 09:11:21 pm »
Yes, they do. They claim it is glass/epoxy, so no idea if it is still the same stuff SG had a problem with. Regardless, seems not all boards are made equal.  :icon_biggrin:
« Reply #15 on: August 24, 2014, 10:47:41 pm »
Good video
perhaps someone mistakenly spec'd the anti-static treated material.
« Reply #16 on: August 30, 2014, 04:32:09 am »
Hoffman 5F6A Black Bassman
I don't know if I can ever go back to plain old Natural after seeing the black with lugs installed
« Reply #17 on: August 30, 2014, 06:09:33 am »
That looks really sharp!
« Reply #18 on: August 30, 2014, 06:22:35 am »
Thanks Jeff
