September 15, 2026, 11:40:12 pm
Hoffman Amps Forum image Author Topic: Choke Question  (Read 4368 times)
Offline J Rindt
Choke Question
« on: September 02, 2014, 02:53:46 pm »
http://el34world.com/Forum/index.php?topic=17495.msg175610#msg175610
In reference to another post made.....
I have worked on many amps with a Pi Filter...but I never thought to put a meter across the Choke.
I checked Resistance of the choke in the AC100 (nothing else was attached to the choke) ...and the meter says 300 Ohms.
Is it "common" for a choke to read that high.?
For some reason, I though the DC Resistance of a choke would be pretty low.
Maybe it is 300 Ohms, so  to facilitate the 20 Volt drop, and Screen Regulation that sluckey was discussing.?
Thank You
Re: Choke Question
« Reply #1 on: September 02, 2014, 03:45:07 pm »
300Ω is a common resistance value for a typical choke used in a guitar amp. You can easily see a resistance range from 50Ω on up to above 600Ω, even higher. The choke is just a long piece of wire coiled around some iron. The wire has resistance. Longer wires have more resistance.
Most chokes have 3 important electrical characteristics associated with them. Inductance, DC current rating, and DCR (resistance). Look at the Hammond MFG. website for some typical values for their chokes.
Offline J Rindt
Re: Choke Question
« Reply #2 on: September 02, 2014, 05:08:09 pm »
OK...Thanks.
For some reason I had it in my mind that a choke would have very low DCR...just an assumption on my part.
Is the  reason for "High" DCR to drop the B+ for the screen supply, or is there/are there  anothger reason(s).
Thank You
Re: Choke Question
« Reply #3 on: September 02, 2014, 07:30:43 pm »
It's very low, compared to its impedance to power supply ripple.
XL = 2 * π * f * L = 2 * 3.14 * 120Hz * 15H = 11kΩ.
To get the same filtering effectiveness while using a resistor, you'd need an 11kΩ resistor which will drop almost 38 times as much voltage.
