September 18, 2026, 06:58:09 am
Hoffman Amps Forum image Author Topic: How to use (in a guitar amp) some ECC82 (12au7) tubes that I've  (Read 10727 times)
I've some ECC82 tubes, they are rarely used in guitar amps (maybe, sometime, as PI or in the send of FXLoop)
To find an use I can use it also in CF configuration, but I was wondering if is possible to use it in other collocations on a guitar amp circuit
as V1 or V2 in Cascode configuration or simply as Anode Follower putting two in series to be used as something like a single triode of a 12ax7 tube
Often I've read that each gain stage adds harmonics so my idea has this thing on the basis
Offline rzenc
  • TUBES RULE
Re: How to use (in a guitar amp) some ECC82 (12au7) tubes that I've
« Reply #1 on: October 21, 2014, 11:23:20 am »
Hi K,
I used it to drive tonestacks with great results. It was plate-driven and I had to adjust TS caps to taste. Basically a 5879 gain stage - gain control - 1/2 ECC82 - Tonestack + vol. - 1/2 ECC82 - PI - PA
I need to find the schem, but if you are interested, pm me.
Best regards
R.
« Reply #2 on: October 21, 2014, 12:20:33 pm »
Find an old CONN organ in the garbage and you'll have 36 of them.
Some folks use them in reverb driver position in a Fender amp which can increase the usable range of the "reverb" control because they have much less gain than a 12AT7.
« Reply #3 on: October 21, 2014, 12:48:33 pm »
I like them in the D'Lator type active FX loops & sometimes use them there.
« Reply #4 on: October 21, 2014, 03:07:25 pm »
Often I've read that each gain stage adds harmonics ...
Only if you're driving the tube hard enough to push it beyond clean amplification (or mis-biasing enough to ensure there is little clean amplification).
Seems like a good tube to deliver moderate current in a preamp (a reverb driver might be a decent application), to act as a unity-gain mixer (though the relative levels of the individual signals need to be pretty close; closer than what you might offset with a 12AX7 as a unity-gain mixer), etc.
Offline Merlin
« Reply #5 on: October 22, 2014, 05:01:57 am »
If you cascade enough of them you can get as much distortion as you like, but be prepared to tweak everything.
Some examples of use, AX84 blues preamp:
http://www.ax84.com/static/corepreamps/Blues/AX84_Blues_Preamp_Schematic.pdf
Doug's Firefly, which uses a 12AU7 as the output stage:
http://ax84.com/media/ax84_m276.gif
« Reply #6 on: October 22, 2014, 06:45:11 am »
Many thanks to ALL you friends
@ Merlin
is this the Blues preamp that you mean ?
http://www.mrdwab.com/john/Blues-pre.jpg
on the two link you posted there is the same schematic (both are FireFly rev.3)
« Reply #7 on: November 20, 2014, 05:40:58 pm »
I'm spending some time on research on old amp schematics
I discovered that Univox used the 12au7 in different positions on their amps
a pair attracted my attention, one has a 12au7 tube as driver and recovery of the TS (as Rzenc told  :thumbsup: )
The other was in a position at which I've think sometime but was never sure if convenient (may be in the 1236, that is a Bass amp, it was), I mean V1
on the 1236 there is also a 12au7 after the PI before the Power Tube
I think the purpose was to drive at the max the 6L6GC tubes, is this correct ?
« Last Edit: April 09, 2015, 04:53:11 pm by kagliostro »
« Reply #8 on: November 20, 2014, 10:56:00 pm »
6L6 are not hard to drive. Almost any reasonable driver can over-drive them.
And the U-1075 would need more drive than the 1268 because of higher 6L6 voltages.
It's a cross-word puzzle.
Put in a tube. Not enough gain. Put in another tube. Too much gain. Throw in a tone-stack. Or a mixer. Less gain. You move things around and change them until you have a reasonable gain-structure from input to output. You also want a reasonably minimum cost, which suggests dual-triodes, but you have to get the right halves in the best places.
The U-1075 has a lot of inputs, so has a lossy mixer, and has to start with high-gain preamps and individual gain controls. After the mixer the level is too weak to go to a tonestack, but too much gain added may overload. So a low-gain stage. Then tonestack. The output stage is lifted direct from Fenders, needs pretty strong input, so need a little gain after the tonestack. While two low-gain stages seems complex, they are just one dual-tube. This also allows a 2.2K+0.3uFd cathode network, twice, to provide a lift and shelf in the midrange, a classic guitar EQ.
The 1263 looks like two hi-gain stages before the tone/volume network but the NFB around these stages means a very clean input with moderately high gain. All the tone/volume loss is in the middle, and then it needs fairly high gain to the output. The 1263 is unusual for a guitar amp in that all the gain happens in just two NFB sections. It might be very low coloration before over-load.
Also I am sure the guy who designed the Japan-made UniVoxes had the same problem as everybody here. He just wanted to try something different each time.
« Reply #9 on: November 21, 2014, 03:58:40 am »
I like your guidance on those old circuits if well explained there is a lot to learn there
As always Many Many Thanks PRR
« Last Edit: November 21, 2014, 07:45:30 am by kagliostro »
