September 08, 2026, 02:44:14 pm
Hoffman Amps Forum image Author Topic: How tidy are your builds?  (Read 9401 times)
Offline bakerlite
  • Don't forget to play it...
« on: October 23, 2014, 05:41:17 am »
I wonder - despite what i perceive as my best intentions I don't seem to get that precise look when I come to the end of a build.
Maybe because I go to fast - its not a race after all!
Anyway I thought of this because I found this fantastic AC30 build pics with nice music too...
http://www.per-viklund.magix.net/all-albums/!/oa/4513476/
This is definitely a new benchmark for tidiness ! i might stick a few pictures on the wall for inspiration the next time i build something...
Cheers,
Bakerlite
Re: How tidy are your builds?
« Reply #1 on: October 23, 2014, 06:03:07 am »
My builds are rarely tidy.  AND .......... they are typically very quiet at idle.
« Reply #2 on: October 23, 2014, 11:33:12 am »
Every time I try to be tidy it hums itself off the bench.  Clearly I am missing something.... :laugh:
Jim :dontknow:
Offline Platefire
« Reply #3 on: October 23, 2014, 01:19:25 pm »
That slide show and background music (Apache) was very good. My builds are not a bench mark to display but I think most of the regulars on this site do very neat layouts(better than mine) and lead dress. I think sluckey is one of the more precise that I've seen and several others in the same category. This is about as good as it get for me. Platefire
« Last Edit: October 23, 2014, 01:22:12 pm by Platefire »
On the right track now<><
« Reply #4 on: October 25, 2014, 10:38:06 am »
You know mine are sloppy as hell  :icon_biggrin:
Offline bakerlite
« Reply #5 on: October 25, 2014, 11:37:15 am »
Ha nice!
Two questions:
1)while this may be a soldering 101 question how on earth do you get those nice soldering blobs built up ON TOP of the turrets like that.  I would pay to see a close up 15 second video of you dong one of those. I always thought I was OK at soldering but now I want to learn to make em as clean lookin as that before I go at anything else.
2) what gauge buss wire is that?
I recently used bridge suspension rope for my buss wire! (18awg solid cloth as it was all I had and easy to take the cloth off. However it's a bit over the top.)  So I must add some to my next order.
Cheers,
Bakerlite
Offline andyfromdenver
« Reply #6 on: October 25, 2014, 11:22:35 pm »
Lol that's so clean it's ???? Dirty? :)
OP et al, here's one I'm really proud of.
It's a 70's Champ with added in reverb including the added triode like the Princeton Reverb.
I went SS rectifier & upped the filtering so it's mega quiet.
I was so proud of myself and then someone pointed out that Allen Amps calls it their Chihuahua.
(mine has a mid boost and a cute cab :)
"Whether you have good credit, bad credit, no credit, what is credit? Can't read or write..."
« Reply #7 on: October 26, 2014, 06:42:20 am »
I should do a close up video of how I do those lugs.
Basically you feed in some solder and let it fill the hole
Pull the iron tip and solder away and let the inner fill get solid
Bring in the iron and solder to create a dome
I use 20 gauge wire for the pot buss.
24 gauge buss for the short lug jumpers on the boards
22 gauge for the power supply rails and long ground lug buss on the board
« Last Edit: October 26, 2014, 06:45:56 am by EL34 »
