September 16, 2026, 05:22:57 am
Hoffman Amps Forum image Author Topic: HOLDEN/WASP  (Read 30144 times)
Re: HOLDEN/WASP
« Reply #50 on: January 02, 2015, 06:53:31 am »
When the relay is off the LED is on and there is 18v across the switch
Are you sure? That's a lot of voltage to come from a 6.3VAC filament winding!
Remove the diode and cap that are parallel to the switch. Does that help?
Re: HOLDEN/WASP
« Reply #51 on: January 02, 2015, 02:24:18 pm »
Hey Sluckey, The power supply is tapped off the power tube heaters and measure approx. 13v. I thought this was a good source of power seeing that the relay doesn't draw much current.
Thinking that it was a problem to use the heater tap I used a small transformer and had the same problem.
I also removed the cap/diode and just had the LED and it presented the same problem.
Anyway i'll recheck things. :think1:
Re: HOLDEN/WASP
« Reply #52 on: January 02, 2015, 03:22:44 pm »
Maybe try a different type relay?
Re: HOLDEN/WASP
« Reply #53 on: January 02, 2015, 06:59:01 pm »
relay latches - won't release b/c of current flow thru LED, even when switched off. if i fiddle with 120R in your schema, i can get it to work in simulator, but not reliably.
EDIT: i used 56R for 120R and 220R for 470R.  assumed 100mA 5V coil w/ DCR of 50 ohms @ 110mH.
Re: HOLDEN/WASP
« Reply #54 on: January 02, 2015, 10:50:18 pm »
Hey pete, these are the same relay I have used in all my builds. http://www.jaycar.com.au/productView.asp?ID=SY4052
With the 120r is pretty close to 12v across the coil when the relay is on.
Re: HOLDEN/WASP
« Reply #55 on: January 02, 2015, 11:43:30 pm »
Hey DL, Paralleled the 120r and it did nothing.
For what ever reason the LED/resistor is stuffing things up.
I increased the LED dropping resistor to 1k5 and this has done the trick, also there is no lost of brightness in the LED.
« Last Edit: January 03, 2015, 12:19:34 am by TIMBO »
Re: HOLDEN/WASP
« Reply #56 on: January 03, 2015, 08:25:58 am »
the trick was to get the relay OFF state current through the LED low enough for the relay to drop out. glad you got it sorted.
Re: HOLDEN/WASP
« Reply #57 on: January 03, 2015, 08:50:48 am »
sim of you problem. the first two screen captures show a working circuit with 1500ohm dropping R. the third screen capture show shows the latched state of the relay with a 470 ohm dropping resistor - i had already toggled the one the switches off to on to off - notice both LEDs stil it.
the relay values were estimates taken from an omron datasheet. i estimated the coil pickup at 75% of maximum and coil dropout at 20% of max. 42mA is maximum @ 12V.
Re: HOLDEN/WASP
« Reply #58 on: January 03, 2015, 01:59:37 pm »
WOW, that's impressive.
Re: HOLDEN/WASP
« Reply #59 on: January 04, 2015, 03:48:49 am »
Hi guys, Down to the last few questions.
I noted that here http://el34world.com/Forum/index.php?topic=17556.0 the boys have adjusted the grid leak via the pot/resistor to match the resistors on the original major.
The Wasp had 100k resistors and the usual 250k pot/2.2m resistor combo is what I used, I have read that this could be a problem. Its seems to work as I have it.
After having the amp on for a good while I checked the main Ecaps after switching off. There was still voltage but if slowly bled of over a short time down to about 110v and the preamp Ecaps are down to 0v.
So 220k/3w across both Cap cans be enough?
The local guys also mention a 150k/3w across the standby sw. as a switch saver??
And that my friends is just about that. :icon_biggrin:
Re: HOLDEN/WASP
« Reply #60 on: January 04, 2015, 02:06:39 pm »
absolutely. use 330L or 470k as well if you wish - just a longer discharge time constant.
with 700V on the plates, i wouldn't even have bothered with a PPIMV. simple is best. 2.2M isn't going hold for long if one of the pots wiper opens.
use a 180K || with 250K pot. R is then ~105K full up (as it was) and if a wiper opens up it's 180K: much, much better than 2.2M grid leak.
no opinion on the standby saver.
Re: HOLDEN/WASP
« Reply #61 on: January 06, 2015, 02:01:09 am »
Thanks DL, On it. :thumbsup:
Re: HOLDEN/WASP
« Reply #62 on: January 09, 2015, 03:12:50 am »
Hi guys, The Holden wasp is done.
I'm very happy the way it has turned out.
The two channels are very useable as they are.
Channel 1 is very clean even up to pretty max volume and could take a pedal in front well.
Channel also has a nice blues breakup at higher volume and the two channels can be jumpered to add some extra gain.
To OD kicks it up a notch and adds some great overdrive that is not too over the top.
I'm trying to convince someone local here to do a demo as I couldn't do it justice.
Re: HOLDEN/WASP
« Reply #63 on: January 09, 2015, 08:51:38 am »
very nice work! :-)
Re: HOLDEN/WASP
« Reply #64 on: January 09, 2015, 10:07:13 am »
Looks great Timbo!!!!!
             Brad       :icon_biggrin:
Offline terminalgs
Re: HOLDEN/WASP
« Reply #65 on: January 09, 2015, 10:45:46 am »
very cool.
Re: HOLDEN/WASP
« Reply #66 on: January 09, 2015, 01:11:50 pm »
Very impressive and a great job!  THANKS for sharing the photos and info.
Re: HOLDEN/WASP
« Reply #67 on: January 10, 2015, 01:29:05 pm »
I thought I'd try to convert this to an easy to read GIF file so others could see what a great approach Timbo took to this build.
« Last Edit: January 10, 2015, 02:33:34 pm by tubenit »
Re: HOLDEN/WASP
« Reply #68 on: January 10, 2015, 02:14:02 pm »
Hey Tubenit, Thanks for that. Just a small change. I used a 180k with 250k pot for the PPIMV. This was a suggestion from DL, as this now makes the grid leak similar to the original 100k resistors. :icon_biggrin:
EDIT: Corrected this in the above post
I also added 390p caps to the 100k plate resistors on the OD. This did add some smoothness as well reduced some ghosting of the notes. Thanks
« Last Edit: January 10, 2015, 02:28:52 pm by tubenit »
Re: HOLDEN/WASP
« Reply #69 on: January 10, 2015, 02:39:19 pm »
Wow!  That looks like it just came off the music store shelf new!  Very nice job!  You should be proud of this restoration. :worthy1:
Sound clips?  Go ahead, you can do it!  We have all made fools of ourselves in the Sound clip section, join the club!
Re: HOLDEN/WASP
« Reply #70 on: January 10, 2015, 02:57:22 pm »
 :huh:
