September 18, 2026, 04:49:55 am
Hoffman Amps Forum image Author Topic: board layout, components too close?  (Read 4352 times)
Offline hesamadman
« on: November 10, 2014, 01:56:55 pm »
I laid out another 5 watt. This time there were 2 differences.
1. I used a 290ax PT rather than a 269JX. This is about 100 more volts on the secondary.
2. I didn't have much board material so I compacted the layout pretty close.
The amp worked and sounded great, but it had a hum that was pretty annoying. It was loud. Not normal loud. I tried everything. Moving wired, grounding, had to make a heater filament center tap.  I could not get that hum to budge. Im wondering if its possible to have laid out components too close. There wasnt any AC wires close to the preamp circuitry. Power amp and preamp had a sufficient amount of gap between. Could I have something mounted too close on the board?
Re: board layout, components too close?
« Reply #1 on: November 10, 2014, 02:01:22 pm »
The last board I made had the turrets on a .25" spacing. Show us a schematic and some hi-rez pics.
Offline hesamadman
« Reply #2 on: November 10, 2014, 02:13:30 pm »
I didnt think this was the case. I mean PCB has components neck and neck. I  pulled the board. Gonna work on wire routing later and will get better pics.
Offline hesamadman
« Reply #3 on: November 10, 2014, 02:14:25 pm »
And this
Offline hesamadman
« Reply #4 on: November 10, 2014, 04:11:30 pm »
Would filtering be an issue if volume control will control hum?  Since this transformer is of a higher voltage, wondered if filtering should be adjusted.
« Reply #5 on: November 10, 2014, 05:20:41 pm »
If you mean turning the volume down reduces the hum (or turning it up increases hum), then no. The hum is between the input jack and volume control.
