September 14, 2026, 04:22:04 am
Hoffman Amps Forum image Author Topic: 10kl & 50kl trim pots  (Read 4147 times)
Offline blues man
  • I hate solid state amps
« on: November 30, 2014, 11:45:50 am »
Does anybody know what the watt rating is on the 10 & 50kl trim pots Doug sells? I would assume they are probably 1/2 watt.
Re: 10kl & 50kl trim pots
« Reply #1 on: November 30, 2014, 01:06:30 pm »
Most likely, they are about 1/3w or less.
It shouldn't matter much, because there is very little current through the pots. It would matter if the trimmer was used to divide couple-hundred volts, but dissipation is probably under 1/6w in a typical bias circuit dividing up 40-50vdc.
Offline blues man
« Reply #2 on: November 30, 2014, 01:45:59 pm »
Thanks for the reply. I was thinking of experimenting with the 10kl on the preamp with the cathode bypass cap for tweeking.
« Reply #3 on: November 30, 2014, 05:58:41 pm »
They should work fine for that, as far as power rating goes.
One formula for power is Voltage2/Resistance. A typical Fender gain stage will only have 1.5-2.2vdc across the cathode resistor.
2.2v2/470Ω = 1/10th watt. Even less for higher resistances.
You don't want to dial the cathode resistor to 0v, so put a 470-820Ω resistor in series with the pot to set a minimum resistance.
