September 17, 2026, 05:44:34 am
Hoffman Amps Forum image Author Topic: Zener Diode for dropping B plus voltage?  (Read 12013 times)
Offline smackoj
« on: January 06, 2015, 08:12:29 am »
hello amigos; I need to drop 30-40 volts from an old PT. I think a zener diode would be a good attempt prior to swapping out the PT for a lower output model. Is a 10 watt zener a safe starting point or does it need to be rated at more watts?
thanks, jack d
 :icon_biggrin:
Re: Zener Diode for dropping B plus voltage?
« Reply #1 on: January 06, 2015, 08:25:06 am »
Depends on how big the amp is. 40V and 10W implies 250mA. Half that for safety. So, if the B+ current will be 125mA or less, I'd use a 10 watter,,, with a heatsink.
Offline smackoj
« Reply #2 on: January 06, 2015, 05:32:56 pm »
OK; so a pair of 6L6s could draw up to 144 ma and a 6SL7 an additional 30 ma....would these current numbers from the tube manual be pushed to the max figures which would be beyond normal playing range?   thanks
 :icon_biggrin:
« Reply #3 on: January 06, 2015, 06:03:11 pm »
it is doubtful that a 6SL7 would be drawing 30mA - at least not in a guitar amp. 2mA would be typical - maybe 4-5mA worst case.
Offline phsyconoodler
« Reply #4 on: January 06, 2015, 06:56:26 pm »
I have used a 25 watt resistor bypassed by a reversed 450volts  capacitor with positive to ground as a voltage reduction placed in series with the pt center tap.
  Works on several amps i have tried. They are still in service after five years
Offline smackoj
« Reply #5 on: January 06, 2015, 07:14:21 pm »
3-4 ma for a 6SL7. thanks, read the tube chart wrong.
I'm not for sure if I understand noodler's suggestion. I'll re-read it a few more times and see if the light bulb goes on in the cranium.
jack   :icon_biggrin:
« Reply #6 on: January 06, 2015, 07:42:12 pm »
Offline smackoj
« Reply #7 on: January 06, 2015, 07:56:31 pm »
good link to the schemo.  thanks, understand it now.
 :icon_biggrin:
« Reply #8 on: January 06, 2015, 08:24:31 pm »
I used a string of four 1N5353B 16V, 5W ZENER DIODEs on the PT center tap to lower the B+ in an old organ PS I converted to a guitar amp. Lowered it around 48 volts if I remember right. The amp has two 6sl7s a 5R4 rectifier and two 6L6GCs in it and works fine.
« Last Edit: January 06, 2015, 08:35:29 pm by mresistor »
Offline smackoj
« Reply #10 on: January 06, 2015, 08:56:49 pm »
cool idea, thanks.    :icon_biggrin:
« Reply #11 on: January 14, 2015, 08:57:22 pm »
I believe I have seen the ground artificially elevated using mosfets.
Psychonoodler already posted a back-bias arrangement that does exactly this with 1 resistor and 1 cap.
One problem I see, is the cathode to heater voltage difference.
Psychonoodler's approach causes no issues with heater-to-cathode voltage. Neither does using zener diodes.
Offline JPK
« Reply #12 on: January 17, 2015, 01:48:00 pm »
a good read.
http://www.aikenamps.com/index.php/what-is-back-biasing
Thanks for posting this. I got lost in his sea of white pages....again. What incredibly valuable amplifier info that guy writes.
« Last Edit: January 17, 2015, 06:05:37 pm by JPK »
I love tubes
« Reply #13 on: January 18, 2015, 01:20:56 pm »
Using the zener on the CT you must pay attention to the voltage of the bias if the amp is a fixed bias and the bias comes from the same winding
