September 16, 2026, 03:15:26 am
Hoffman Amps Forum image Author Topic: Mesa 50/50...no output  (Read 4204 times)
Offline JustMike
« on: January 25, 2015, 09:45:58 am »
 it fires up, tubes glow but no output on either channel. Where should I begin? The owner said he had the (original) tubes tested and they were good :icon_biggrin: , but even so, if I don't see any red plating or dead filaments, I should hear something, right?
I'm learning...
Re: Mesa 50/50...no output
« Reply #1 on: January 25, 2015, 10:07:55 am »
Need more info. Ask the owner some more questions, like how did it die. Get some voltage readings. Find out what is working and what is not working.
« Reply #2 on: January 25, 2015, 04:54:43 pm »
+1.
When taking voltage readings, listen to the speaker. Start at the output tube plates for your measurements, and check for d.c. volts.
When probing plates & grids, you might hear a little "pop" in the speaker. As you work your way backward to the input jack, the pops will get louder. make sure volume controls are up a little way when you probe a tube stage before a volume control.
When the "pop" stops, but the volume control is up, you will have found a problem (either see no d.c. volts on a tube; or an open connection like a burned trace, loose connection, or open coupling cap; you might also find a short to ground at a coupling cap or tube grid).
