August 29, 2026, 01:59:24 pm
Hoffman Amps Forum image Author Topic: 2 conductor shielded wire for PPIMV  (Read 4861 times)
Offline hesamadman
« on: February 06, 2015, 09:12:13 am »
Hey guys,
I bought the two conductor shielded wire here at hoffman. Not realizing that it only had one shielded conductor. Will this be sufficient enough for shielding my PPIMV hookup? I figured I would use the shielded conductor as the outgoing wire to the el84's.
Re: 2 conductor shielded wire for PPIMV
« Reply #1 on: February 06, 2015, 09:19:47 am »
No. That wire is meant for a typical Fender footswitch where the shielded conductor is used for reverb and the unshielded conductor is used for tremolo (which doesn't require shielding).
Offline hesamadman
« Reply #2 on: February 06, 2015, 09:21:44 am »
Crud
« Reply #3 on: February 06, 2015, 09:51:12 am »
I use Belden 8451 for dual/twisted pair, shielded cable. Mouser has it.
The insulation on the twisted pair is tough stuff! I laid my soldering iron tip right on it to test it and I had to leave it there for quite a while before it melted.
                  Brad    :icon_biggrin:
Offline hesamadman
« Reply #4 on: February 06, 2015, 09:55:23 am »
Oh I have an order on back order there. Maybe they will add that to it.
