August 01, 2026, 05:13:11 pm
Hoffman Amps Forum image Author Topic: 1 meg resistor on input jack  (Read 6053 times)
Offline supro66
« on: February 08, 2015, 10:51:52 am »
Is the 1 Meg resistor required on the input jacks
I built two Supro 6420 Thunderbolt and no 1 meg resistors were on the original
what do they do
Re: 1 meg resistor on input jack
« Reply #1 on: February 08, 2015, 11:11:15 am »
They ensure the grid has a return path to ground. Otherwise, you are relying on the resistance inside your guitar to provide that ground path. They are not strictly required and many cheap amps omitted them as a cost saver.
I would not build an amp without them.
« Reply #2 on: February 08, 2015, 11:53:08 am »
What Steve said.
Offline supro66
« Reply #3 on: February 08, 2015, 12:01:22 pm »
Ok I will do a remod on all three
I did remove the death caps from the original
« Reply #4 on: February 08, 2015, 02:12:11 pm »
According to the 6420 schematic in the Hoffman library, the Supro already has a 270kΩ resistor to ground, after a coupling cap from the jacks.
So you don't need to add 1MΩ at the jacks. You could replace the 270kΩ with 1MΩ to see if you like the slight difference...
Offline supro66
« Reply #5 on: February 09, 2015, 08:28:25 am »
you are right
and I made up one of those schematics
http://el34world.com/charts/Schematics/files/supro/Supro_6420.pdf
also if you look at weatherford schematic he thanks me for seeing a mistake [ Jim Mitchell ]
