September 14, 2026, 03:28:02 pm
Hoffman Amps Forum image Author Topic: Any interest in cheap head cabs for new Stout chassis?  (Read 78251 times)
Re: Any interest in cheap head cabs for new Stout chassis?
« Reply #100 on: February 19, 2015, 02:12:05 pm »
Got my cabinet today, Thanks SG
Here's a couple pics
Stout TMB and Plexi 6V6 sitting in the cabinet
Offline SILVERGUN
« Reply #101 on: February 19, 2015, 02:48:29 pm »
Nice!
They look sweet with the black faceplates!
 :thumbsup:
« Reply #102 on: February 19, 2015, 05:25:31 pm »
Yes they do
The workmanship is great on those
Now I have to apply some finish before I get greasy hand prints on it
Offline lego4040
« Reply #103 on: February 19, 2015, 07:38:39 pm »
 :worthy1:
« Reply #104 on: February 21, 2015, 03:33:43 pm »
I slapped some flat stain onto my cabinet today
I still have to apply a couple coats of clear coat
I added a Fender combo handle and four rubber feet
Four Rivnuts were installed in the chassis and I have it secured on the cabinet with #10 truss head screws and washers
I stock all that mounting hardware on this page
http://hoffmanamps.com/MyStore/catalog/MiscHardware.htm
I still plan on opening up the front panel for some air ventilation.
« Last Edit: February 21, 2015, 03:35:51 pm by EL34 »
« Reply #105 on: February 21, 2015, 04:13:54 pm »
I like that color. What brand, color, etc.?
Did the stain go on even or were there any blotchy places?
Offline lego4040
« Reply #106 on: February 21, 2015, 04:21:02 pm »
Nice work there, if your keeping your back completely open you think you'll need more ventelation then that?
« Reply #107 on: February 21, 2015, 05:38:20 pm »
I'll get you the brand when I get to the shop
I think it was some some of Maple color?
It's a water based stain which I have never used before
Normally I use a polyurethane with color and clear and do it in one step, but I already had this one the shelf and so I used it
It went on fine, just like any other stain
I apply it heavy with a cloth, work it in and then wipe the excess off with another cloth
That's one coat in the pics
« Reply #108 on: February 21, 2015, 05:39:46 pm »
Probably not but I think the front would look way nicer with a oval shaped opening
Offline lego4040
« Reply #109 on: February 21, 2015, 06:02:05 pm »
I dont use the water base stains on pine that much once I sand my wood down to 220 I wet the wood and let it dry to raise the hairs. I repeat and work my way up to 400 grit. I use minwax oil stain and depending on time frame I usually use a concoction of poly/tung/linseed. Craps like steel when done but works great. Or I use the poly satin spray and that works great too and quicker
« Reply #110 on: February 21, 2015, 06:24:16 pm »
Here ya go Steve
The color is Vermont Maple
I have no idea when or where I got this can, but it was brand new and had never been opened
« Reply #111 on: February 21, 2015, 06:32:12 pm »
Hey, that looks great! Very nice SG and Doug!    :bravo1:
Doug how do you like the rivnuts?
Can we see a side/end pic too?
(Ya' know,    :undecided:   if you have a good table saw you could have cut some of the depth of the cab off before you stained it. Takes 4 cuts, keeper side between blade and fence, scrap just falls away. Then hit it with the round over again.)
               Brad     :icon_biggrin:
« Last Edit: February 21, 2015, 06:56:33 pm by Willabe »
« Reply #112 on: February 21, 2015, 07:12:16 pm »
Love em
So easy to install and nothing that can come off and get lost like a cage nut
No need to reach inside to try and thread on a nut
Yea, I thought about that before I received the cabinet, but you know, the proportions look really nice.
It really could be about 1 inch less deep than it is.
And the width could be shortened also because when you use rivnuts, there's no reason to reach inside to thread on a not.
I'll leave that up to SG, but if it was me, I would probably shrink the cabinet down some more
here ya go
« Last Edit: February 21, 2015, 07:15:10 pm by EL34 »
Offline MakerDP
« Reply #113 on: February 21, 2015, 07:14:33 pm »
Nice job! I am impressed!
« Reply #114 on: February 21, 2015, 07:15:50 pm »
Thanks, It will look even nicer when it get some clear coats
« Reply #115 on: February 21, 2015, 07:20:42 pm »
Even though the current size is pretty nice, I think the size could be trimmed down some more.
Maybe about 1 inch off the back and some off the sides
Just enough off the sides to leave about 1/8th inch on each side of the chassis wings
The height is good
You can use 6L6's with the current height
Offline Ken Moon
« Reply #116 on: February 21, 2015, 07:24:23 pm »
Got mine today  :icon_biggrin:
Looks great - many thanks :headbang:
Offline lego4040
« Reply #117 on: February 21, 2015, 08:14:12 pm »
Love it and the Ptouch, TrainWreck did the same
Offline SILVERGUN
« Reply #118 on: February 21, 2015, 08:35:56 pm »
Well lego.....get your sandpaper and stain ready  :icon_biggrin:
Had sometime today and dedicated it to completing lego's cab. Only took a break to watch 2 periods of hockey.
He had requested poplar and I had to visit 2 Home Depots to find a good piece.  :rolleyes:
Final dimensions turned out to be 24"W x 9 1/4"H x 8 5/8" D with a 17" wide control opening.
I did take the time to rip down the depth and it took a little finageling, but wasn't all that bad after all.
The size of this thing made me appreciate how easy it is to work with the smaller heads.
I'm very happy to hear the positive reviews and appreciate all of the feedback.
« Reply #119 on: February 21, 2015, 08:40:27 pm »
See, poplar looks good!
I like poplar
Offline SILVERGUN
« Reply #120 on: February 21, 2015, 08:42:54 pm »
I like poplar
Yeah, me too....and my router liked it better....much smoother to cut and work
Offline SILVERGUN
« Reply #121 on: February 21, 2015, 08:46:12 pm »
We'll have to do the Stout cab in poplar  :wink:
« Reply #122 on: February 21, 2015, 09:01:14 pm »
Ok, I'll take one in poplar
But can you reduce the size a bit as per my post a few post up?
Hate to ask, but I do think you can skinny the cab size down a bit
I can get you the exact inside dimensions tomorrow
Basically 1/8th inch play on each side of the chassis wings side to side
One inch past the back side of the chassis including a 1/16th inch face plate that is stuck to the front of the chassis
« Last Edit: February 21, 2015, 09:07:26 pm by EL34 »
Offline SILVERGUN
« Reply #123 on: February 21, 2015, 09:48:00 pm »
Most definitely.
I'll go off of the measurements you give me.
And I agree 100% that it will make it right.
I'll start looking for another piece of poplar.  :icon_biggrin:
« Reply #124 on: February 21, 2015, 10:53:01 pm »
Just don't buy 1x12" stock, buy 1x10".
Look, a radial arm saw is a great tool/saw for Cross cutting, but it is Not great for ripping.
That blade WILL because the blade is over the top of the stock to be cut, it WILL climb up and RUN towards the operator and kick the stock, and if the stock kick's, it can take your HAND with it.
Now this could be wrong, but, I was taught to place 1 hand on the radial arm saw bench for stability and the other hand, that 'pulls' the 'saw arm', you 'lock' your shoulder, elbow and wrist. That way, you can stop the blade from climbing and running away.
              Brad
Edit; I meant for any kind of cut with a radial arm saw. You lock your arm, elbow and wrist straight.
« Last Edit: February 22, 2015, 09:05:02 am by Willabe »
« Reply #125 on: February 22, 2015, 06:04:55 am »
Ripping wood on a radial arm saw is scary
A table saw is scary enough as it is.
Offline lego4040
« Reply #126 on: February 22, 2015, 09:42:58 am »
Those are sharp looking SG.  I had a Radial saw and it was great but scary as hell with an entire blade out. If you dont or can't spend money on a decent table saw you can make one with a hand circular saw and wood laying around with fantastic results and when your done, you just break it down. Check out Izzy Swans basic one which attaches to a existing bench here http://youtu.be/NhORUN6oCUc
Offline SILVERGUN
« Reply #127 on: February 22, 2015, 02:22:25 pm »
Found another really nice short piece of poplar today in the last HD I have to choose from. Perfect for the stout cab.
Let's nail down the measurements.
I'm thinkin 15"W overall leaves 13 1/2" on the inside width and my stout chassis is 13 1/4" wide (ouside lip to outside lip)
Height is OK at approx. 8 1/2"
Depth could be 8 3/8" - 8 1/2" depending on preference. (?)
Also found 1 more 8' pine out of 15(?) possible candidates  :rolleyes:
I'm probably gonna start winding down head production at the end of the month and might wind up doing a 5E3 cab for an amp order I just got.
How do these plans look?
Should I do 2, 3, 6???  :icon_biggrin:
« Last Edit: February 22, 2015, 02:34:24 pm by SILVERGUN »
Offline lego4040
« Reply #128 on: February 22, 2015, 04:00:07 pm »
Sweet. Later on in the year I may bug you for a 5G9 narrow panel :icon_biggrin:
« Reply #129 on: February 22, 2015, 05:30:11 pm »
Thanks,
I'll check the depth tomorrow when I get to the shop
Offline shortfuse
« Reply #130 on: February 22, 2015, 11:00:32 pm »
Doug those face plates look great will you make a stout or plexi 6V6 face plate on a custom order?
Offline lego4040
« Reply #131 on: February 23, 2015, 06:04:02 am »
I've been thinking about trying amplates for my 5G9 build, anyone ever use them? Doug does not make face plates for the public, to time consuming I believe.
« Reply #132 on: February 23, 2015, 06:17:32 am »
No, sorry, I don't make face plates for sale
They would be $150 each for all the work it takes me to make one
Offline SILVERGUN
« Reply #133 on: February 23, 2015, 08:21:25 am »
Here's where we stand today after another productive weekend:
1- legos' custom head is complete - ready to ship - deal pending
1- shortfuse done - ready to ship - done deal except need shipping address
2- Llama - 1 done, leftover from first batch,,,,plus one more from this new batch
Built 4 more raw cabs over the weekend and got them down to the rounding over process.
Got the poplar for Doug's Stout box ready to go, just need depth measurement....looks like 8 3/8" to me is perfect.
DL should be receiving his first 2 today, and may want some of this current batch - 2 (confirmed) with 9 3/4" x 2" cutout
Ken moon may want one more out of this current batch (for next month) -  1 (confirmed)
Got a PM from another guy this morning who says he wants one.
It's just starting to get old, but my craftsmanship has hit an all time high thanks to all the practice.
This will probably signal the coming of the end of the heavy production cycle, as I don't see myself doing another batch of 4.
Thanks again guys!
« Last Edit: February 23, 2015, 09:21:18 pm by SILVERGUN »
« Reply #134 on: February 23, 2015, 08:29:31 am »
8.375 deep will work fine
13.5 inside will work fine
same height as before
« Reply #135 on: February 23, 2015, 08:50:47 pm »
got mine today. superb!
thank you very, very much!
« Reply #136 on: February 23, 2015, 09:00:23 pm »
in an ideal world, i would like two with 9 3/4" x 2" opening for the zilker chassis. for monatery reasons, if you could delay until after 1 march...
however, if you're shutting down, please build for others first.
respectfully,
Offline SILVERGUN
« Reply #137 on: February 23, 2015, 09:18:41 pm »
respectfully,
I've got 2 more set aside for you. I haven't cut the face panels yet so 9 3/4" x 2" is no problem and no more cost.
I wanted to make sure you were cool with the quality (or lack thereof  :undecided:) of the 2 you got.
The exact date of the sale doesn't matter and I will continue as planned.
Thanks and I'm glad to hear they passed QC!
« Reply #138 on: February 23, 2015, 09:26:59 pm »
respectfully,
I wanted to make sure you were cool with the quality (or lack thereof  :undecided: ) of the 2 you got.
thanks dr., please send an invoice on or after 1 march to my paypal addie.
muchly appreciated.
Offline SILVERGUN
« Last Edit: February 23, 2015, 09:40:34 pm by SILVERGUN »
Offline llama
  • I like a da tone!
    • Facebook fan page
« Reply #140 on: February 24, 2015, 11:00:34 am »
Hey Silvergun,
Man you've been busy.  Let me know in advance when you want me to come pick 'em up and pay the remainder.
I plan on running the excess depth along a table saw, and using an extra face panel for the back, adding venting of course.
Offline SILVERGUN
« Reply #141 on: February 24, 2015, 11:54:51 am »
Hey Silvergun,
Llama, I'm looking forward to seeing you and your checkbook in my shop at your earliest convenience.
Please continue our email conversation to finalize the details of your visit. You are always welcome.
We should iron out the details of your extra cover panels. Other than that, the boxes are built and sitting here waiting for your arrival.
Tell your wife you're doing charity work.
 :icon_biggrin:
« Reply #142 on: February 24, 2015, 03:04:06 pm »
Here's SG's Stout Chassis cabinet all finished up and a design cut into the front panel
I think it looks awesome
Offline lego4040
« Reply #143 on: February 24, 2015, 04:06:24 pm »
 :worthy1: CNC machined? That is old school radio looking
« Reply #144 on: February 24, 2015, 04:32:55 pm »
very, very nice...
« Reply #145 on: February 24, 2015, 04:39:36 pm »
Thank guys
I am digging the old school radio look
« Reply #146 on: February 24, 2015, 04:41:28 pm »
Doug,
That front panel is VERY cool!!  Impressive.
Offline sean_thornton
« Reply #147 on: February 24, 2015, 05:21:16 pm »
Just think Doug, if that hole was round you could have slipped a vintage back-lit tuner dial in there  :laugh: Heck, maybe even an old Vu Meter.
As it sits that cab is now the coolest looking head cab I have seen in years, gorgeous!!!.
Offline SILVERGUN
« Reply #148 on: February 24, 2015, 05:22:24 pm »
Me too.
WOW! that is cool
 :huh:
« Reply #149 on: February 24, 2015, 05:36:14 pm »
Thanks Guys
