September 17, 2026, 09:41:46 am
Hoffman Amps Forum image Author Topic: Help with low DC voltage on 12ax7 preamp tube  (Read 10694 times)
Offline smackoj
« on: February 27, 2015, 09:40:01 am »
ola amigos; thanks in advance for your suggestions/opinions.  I have a retrofitted Bogen amp that now is a Proluxe build. It has been working fine and then it started shocking me last night at worship team practice. I had almost no volume from it also. I popped the lid this morning and visual inspect did not turn up any glaring booboos. I did resolder the fuse holder which looked a little questionable. I warmed it up with my multi meter handy. No shocks and the volume seemed back to normal. I decided to check B+ voltages. Power tubes fine at 345vdc. It uses one preamp tube at input with 1/2 used for channel one and the other half for channel 2.  Channel 2 looking good with 250vdc but Ch. 1 no good at 59vdc.  I tried re-doing the solder connections and changing out the bypass cap and cathode R but nothing changes. Checked the voltage divider and see both sides using a 100K R.
Is it possible for Ch. 1 side of the preamp tube to be bad?  I ran out of time testing so thought I would post here while I go to work.
gracias amigos.    :icon_biggrin:
Re: Help with low DC voltage on 12ax7 preamp tube
« Reply #1 on: February 27, 2015, 09:53:37 am »
Is it possible for Ch. 1 side of the preamp tube to be bad?    Yes, always suspect tubes first.
However, because you got shocked, there may be a partial short to the chassis, leaving some B+ on the Ch1 preamp tube plate.  If so, the chassis could be live and dangerous.  You should check for that.
Is there a "death cap" at the power chord?
« Reply #2 on: February 27, 2015, 10:07:55 am »
+1
Anytime you get a shock just from touching strings or amp chassis there will be a faulty ground involved. This may mean you don't have a three prong power cord properly connected to chassis, or the house wiring has a faulty ground.
The death cap is a non-issue if you have a proper ground system in place inside your amp AND in the building.
Offline supro66
« Reply #3 on: February 27, 2015, 10:15:43 am »
here is a good test I saw it on  youtube and it works
I had an old amp with only a two prong plug
check it no light reverse the plug it lights up
put the tester on the guitar strings
it detects AC voltage on a circuit used to check live wires
like on the outside jacket of electrical cable
You can see haw it works here it works on everything
https://www.youtube.com/watch?v=306neu3iDyM
« Last Edit: February 27, 2015, 10:40:33 am by supro66 »
Offline smackoj
« Reply #4 on: February 27, 2015, 12:15:08 pm »
thanks amigos; I am not certain what a death cap is?  I am not 100 percent pos. that the 3 wire power cable is in proper but I will double check that. I believe it's in there like it should be.
So if something is amiss on Ch. 1 side of preamp tube the voltage can be down 200 volts?
Test I have done; I attached the ground side of the multi meter to the chassis and then touched the pos. lead to diff. parts of the chassis and checked for dc and ac. I did not find either on the chassis now.
thanks, jack
« Reply #5 on: February 27, 2015, 02:54:03 pm »
It's the cap from the Ground Switch (if present) to ground. Used to reduce hum on a 2-wire system. On a proper 3-wire system, it should be absent, or disconnected if the amp was refit with the 3-wire cord.
I had a Princeton Reverb with a properly-fitted 3-wire refit, yet was still shocked when touching the guitar strings with my left hand and stepping up to a mic. The amp was plugged into a 3-wire outlet in one part of the venue, while the mic was connected to a PA plugged into a 3-wire outlet on the other side of the venue. Apparently, there was not a good 0v connection among the neutral/ground for outlets throughout the building.
Point being, your amp can be perfectly fine and you can still get a shock if the house wiring is faulty.
Yes. Something is causing that triode to pull excessive current, which flows through the plate load, creates bigger-than-normal voltage drop, and results in lower-than-normal plate voltage.
Check (by unsoldering) the cathode bypass cap first. Then measure volts across the cathode resistor (if not shared with the Channel 2 triode working properly). Look for solder blobs on the top socket pins and/or mounting points of the components for that stage.
I wouldn't suspect the grid for that triode to be the issue, because a dead-short to ground at the grid should just kill the signal but not change tube bias/plate current. A dead-short to ground at the plate should cause 0v at the plate, unless the short is not to ground but some other voltage level. So a too-low cathode resistance (maybe due to a shorted bypass cap or shorted/partially-shorted cathode resistor) is the prime suspect.
Offline smackoj
« Reply #6 on: February 27, 2015, 06:17:39 pm »
double checked all the suggested points. could not get the voltage corrected with changes to the cathode resistor but I did replace the bypass cap and then, after all other attempts without change, I replaced the preamp tube. turned it on and it's working good, plenty of volume. checked the plate voltage again and found 133vdc on Ch. 1 and 127vdc on Ch. 2.  I believe that is low by approx. 100 volts but I'll await your input as to whether I should make changes? I want to play it on the 'clean' side not the dirty, raspy side.
thanks    :icon_biggrin:
« Reply #7 on: February 27, 2015, 08:45:04 pm »
Don't have schematic with volts, so what is the node volts for that tube, what size is your plate R's for each, and cathode R's. those things should be a good indicator if it's "right".  Do the math using the cathode R volts drop and that should also help, like if it's 1mA vs 3mA
« Reply #8 on: February 28, 2015, 09:25:38 am »
... could not get the voltage corrected with changes to the cathode resistor ... I replaced the preamp tube. turned it on and ... checked the plate voltage again and found 133vdc on Ch. 1 and 127vdc on Ch. 2.  I believe that is low by approx. 100 volts ...
You went from 250v+ on one plate and 50v on the other, to roughly-same voltage on both plates. What makes you think this new voltage level is not correct?
What is the voltage of the filter cap supplying this tube?
Offline smackoj
« Reply #9 on: February 28, 2015, 11:47:13 am »
what I was trying say is that 133vdc is low compared to say 250vdc that some amplifiers run on the plates. I changed the resistor feeding the filter cap for this tube and replaced the 5Y3 recto with a 5U4 and now I have 173v and 181v on the preamp tube's plates.  It is sounding nice and strong with good tone so I'm satisfied with the outcome.
thanks gents    :icon_biggrin:
« Reply #10 on: March 01, 2015, 03:42:54 pm »
Please be careful to say all you're thinking! After all, the thread was about low plate voltage due to some unknown fault, so...
« Reply #11 on: March 01, 2015, 03:52:13 pm »
I wonder what happened with the shocking issue? Did you find a cause? Is it resolved?
