September 18, 2026, 11:59:47 am
Hoffman Amps Forum image Author Topic: Filament Overvoltage  (Read 5219 times)
Offline clyde
« on: March 18, 2015, 08:54:12 pm »
I'm planning on using the 115v tap on a Hammond PT, needing the boost in voltage but am concerned about filament voltage being too high.  Lowering the 6.3v tap can be done with either diodes or resistors as I understand.  Any preferences and why?  However, how do I handle the 5v rectifier tap?
Offline lkrasner
Re: Filament Overvoltage
« Reply #1 on: March 18, 2015, 09:35:08 pm »
I would be very surprised if the higher voltage caused any issue. Maybe tube life will be decreased a bit. If you want to be safe, just put a resistor in. It's simple and reliable.
Calculate your total filament current, then use ohms law to figure out what resistor you should use to drop it down to 6.3.
« Reply #2 on: March 19, 2015, 02:11:23 am »
Ditto for the 5v winding
Offline clyde
« Reply #3 on: March 19, 2015, 09:06:03 pm »
And the B+ on the 5v winding?
« Reply #4 on: March 19, 2015, 09:49:18 pm »
Should not be affected.
Offline clyde
« Reply #5 on: March 19, 2015, 11:06:12 pm »
Cool, thanks.
Offline clyde
« Reply #6 on: March 23, 2015, 05:31:13 pm »
Good old RG, always on top of things.  It isn't exactly what I'm needing as I want the higher B+ running the PT on the 115v tap, just worried about the filaments running at 7.1v.
« Reply #7 on: March 23, 2015, 07:40:53 pm »
Here's the 1st post guys. ^
He needs the extra B+dcv. So a bucking transformer is out.
                         Brad    :icon_biggrin:
