July 29, 2026, 09:43:34 pm
Hoffman Amps Forum image Author Topic: 5E3 cabinet  (Read 7118 times)
Offline SacDave
5E3 cabinet
« on: April 15, 2015, 08:52:59 am »
This is one of my custom built cabinets. They are made out off Cherrywood with Maple trim. The bent skin is about 3/16" thick. Each one takes about 30 hours to make.
Re: 5E3 cabinet
« Reply #1 on: April 15, 2015, 09:55:44 am »
Very nice!
Offline MadMax
Re: 5E3 cabinet
« Reply #2 on: April 15, 2015, 05:11:29 pm »
Oh, Man, That is awesome! Thanks for sharing.
-Mad Max-
Re: 5E3 cabinet
« Reply #3 on: April 15, 2015, 07:55:19 pm »
Those are incredible! Very artistic.
Offline Fresh_Start
  • noob de Lux
Re: 5E3 cabinet
« Reply #4 on: April 16, 2015, 10:57:43 pm »
Very cool!  :occasion14:
Are you using steam while bending the wood "skin"?  It's multiple layers bent then glued together, isn't it?
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
Offline SacDave
Re: 5E3 cabinet
« Reply #5 on: April 17, 2015, 07:52:30 am »
No don't use steam, I do use heat , heat gun also have a heated mold takes about 45min to bend each curve. The core is made of 7 layers of 1/8" bending plywood. I did just build a steam box to try some bends on 3/8" wood. Also I spent countless hours on the mold went from 36 C-clamps to 12 pieces of all-tread.
Re: 5E3 cabinet
« Reply #6 on: April 17, 2015, 09:55:47 pm »
So you are saying you build up the sides with 7 layers of bending plywood? Are those individual layers bent around a form like the sides of a guitar? How do you glue them together without voids and warbles in the plys? Dozens and dozens of clamps?
Offline SacDave
Re: 5E3 cabinet
« Reply #7 on: April 18, 2015, 08:40:03 pm »
The mold  has a 9.5" metal band (kind of like a strap) that pulls everything tight around the mold, there is also some other cross clamps .  The cherry wood skin I clamp it the same way after the shell is made. One thing for sure you have to work fast once you start glueing. I think the next one I might glue up 3 plys then after thats dry glue up the other 4. then the skin. I Don't know when I'm going to build another one  but I'll take a bunch of pics.  I want to try and steam bend the wood  but I don't think I can bend it faster than it will cool.  The plywood pieces bend no problem  you can bend them by hand . The Skin I pre-bend before I glue it on.
Offline TNblueshawk
Re: 5E3 cabinet
« Reply #8 on: April 23, 2015, 11:04:59 am »
Wow, that is amazing.
