September 07, 2026, 08:24:56 am
Hoffman Amps Forum image Author Topic: Stout Chassis Version 2 is here  (Read 51812 times)
« on: April 24, 2015, 01:24:22 pm »
This is the Hoffman stout chassis
The stout chassis are located on this catalog page
http://hoffmanamps.com/MyStore/catalog/Chassis.htm
Try out this click on the parts page
See the instructions on this page
http://hoffmanamps.com/MyStore/catalog/StoutChassis.htm
Here is a 3D PDF file where you can rotate and view the Chassis in 3D.
You must save this file to your computer and open it in Adobe reader
If you just click on it, it will open in a browser and it will not be in 3D
http://el34world.com/Hoffman/files/StoutChassis2.pdf
Check out all the features on version #2
Hoffman Stout Chassis Version 2
Punched Aluminum Chassis
12 inches wide x 6.5 inches deep x 2.5 inches high
.09 inch thick Aluminum
The mounting flanges are 5/8 inches wide
Front Panel
8 x .375 " holes for Jacks or pots
1 x .38" hole for Marshal style indicator lamps
Back panel
1 x .39" hole for rotary impedance selector switch
2 x .375" holes for speaker Jacks
1 x .5" Power switch hole
1 x Fender Style Fuse Holder Double D hole
1 x IEC power receptacle hole
Top
3 x .75" 9 pin socket holes
3 x 1.08" 8 pin socket holes
The last 8 pin socket holes has extra holes so you can mount an external Filter cap with a bracket
I sell several block off plates so you can block off holes or make an 8 pin hole into a 9 pin hole
They are on this page
http://hoffmanamps.com/MyStore/catalog/MiscHardware.htm
Note that I no longer stock transformers
Mojo has transformers that fit this chassis
https://www.mojotone.com/amp-parts/Transformers_1
1 x Output transformer mounting holes with multiple mounting holes for different sized transformers
Mojo - Marshall style 18 watt Output transformers fit in this chassis
1 x Small fender style choke holes
1 x Power transformer mounting hole
Mojo - Marshall 18 Watt power transformers fit in this chassis
A Fender Tremolux style power transformer will also fit here
Click on the images below to see chassis top side dimensions and hole sizes
« Last Edit: October 24, 2020, 08:46:59 am by EL34 »
Re: Stout Chassis Version 2 is here
« Reply #1 on: April 24, 2015, 01:24:31 pm »
« Last Edit: April 24, 2015, 01:28:08 pm by EL34 »
« Reply #2 on: April 24, 2015, 01:24:37 pm »
« Last Edit: April 24, 2015, 01:29:26 pm by EL34 »
« Reply #3 on: April 24, 2015, 01:24:43 pm »
These pics show parts loaded into the holes
Note that I moved the internal capacitor mounting holes back so that Marshall style indicator lamps will fit without being too close to the capacitor
« Last Edit: April 24, 2015, 01:32:01 pm by EL34 »
« Reply #4 on: April 24, 2015, 01:24:49 pm »
Top view with parts loaded
This pic shows how you can use the last 8 pin socket hole for an external capacitor with a bracket
« Last Edit: April 24, 2015, 01:34:01 pm by EL34 »
« Reply #5 on: April 24, 2015, 01:24:54 pm »
This pic show the different block off plates that I stock
You can block off a 9 pin hole
Block off a 8 pin hole
Make an 8 pin hole accept a 9 pin socket
The block off plates are on this page
« Last Edit: April 24, 2015, 01:36:03 pm by EL34 »
« Reply #6 on: April 24, 2015, 02:31:03 pm »
yay!
order sent.  :-)
« Reply #7 on: April 24, 2015, 02:33:34 pm »
Got the order, thanks Pete
Offline 6v6Pin1
« Reply #8 on: September 19, 2015, 01:30:39 pm »
I'd like to have a company make a face plate for my stout. Is the image in this thread able to be used as a faceplate template? Are the dimensions and hole locations accurate? I don't trust myself to measure accurately.
« Reply #9 on: September 19, 2015, 01:53:01 pm »
The drawings are ok, they are just here for illustrations
Better to have Mojo make the face plate because they make the chassis and already have the exact measurements
Offline guitardude57
« Reply #10 on: November 07, 2015, 10:37:38 pm »
Does anyone make a head box for this built into
 the Plexi 6v6?
"I am never surprised, and always amazed".
Mike
« Reply #11 on: November 08, 2015, 06:25:39 am »
Mojo's cabinet shop can make it
It would be around $200 though
Seems like a bunch on money for such a small box
« Reply #12 on: November 24, 2015, 04:45:46 pm »
Yepper...exactly.
Mike
Offline PharmRock
« Reply #13 on: January 27, 2016, 10:45:51 am »
I am considering making a custom faceplate through bnplasers.  What are the center-to-center spacings for the holes on the front of the chassis, as well as distance from chassis top and/or bottom edge?  I didn't see this on any of the above diagrams.
« Reply #14 on: January 27, 2016, 12:33:25 pm »
I would just measure it
I don't have those figures right now
Offline PharmRock
« Reply #15 on: February 01, 2016, 11:29:18 am »
will do...I've imported your PDF into Corel Draw and going from there.  I'll post the measurements once I get it exact.
« Reply #16 on: February 01, 2016, 11:51:45 am »
The faceplate is easy
All the holes are a standard size and the distance between each one is the same
Offline PharmRock
« Reply #17 on: February 02, 2016, 08:00:19 am »
After some inspection I noticed the grid lines in your images are spaced at 1/16 of an inch, so that makes it easy as well.
Thanks again...this is a solid chassis and perfect for my build.
« Reply #18 on: October 21, 2018, 12:18:52 pm »
I have some pages on my web site that let you click on an amp image and it will take you to that catalog page
This one lets you click on a Fender Chassis image
https://hoffmanamps.com/MyStore/catalog/photoshop.htm
This one lets you click on a Hoffman Stout Chassis image
https://hoffmanamps.com/MyStore/catalog/StoutChassis.htm
According to the interweb, IE has issues with SVG images
Chrome and Firefox are working ok on the two pages above, but IE is not quite right
Not sure about other browsers
You can post here if you info to report about the two pages above
http://el34world.com/Forum/index.php?topic=18606.0
« Last Edit: November 02, 2018, 03:24:58 pm by EL34 »
« Reply #19 on: October 24, 2020, 08:51:41 am »
I found more images of the chassis
« Reply #20 on: October 24, 2020, 09:47:39 am »
Here's a couple shots of the Stout chassis in cabinets
A forum member made the cabinets
I designed and cut the front panel cutouts on my CNC
« Last Edit: October 24, 2020, 09:52:56 am by EL34 »
Offline shortfuse
« Reply #21 on: November 10, 2020, 03:37:50 pm »
I know who made that cab I have one just like it he built for me back in 2015, that I am finally getting ready to start (been a tough past few years with work and surgery's).  That's what the parts order was for yesterday some of the items I lost or miss placed.
I really like the cut outs you did on the front.  Looks great.
Offline crgfrench
« Reply #22 on: December 28, 2020, 05:08:19 pm »
Here I have a FrankenStout about to erupt.
