August 29, 2026, 01:12:46 pm
Hoffman Amps Forum image Author Topic: 5e3 kit - filament center tap  (Read 4213 times)
Offline 6v6Pin1
« on: June 01, 2015, 10:56:06 am »
Does the filament center tap (2 100ohm resistors to ground on the lamp) need to be connected to the first power tube, or can it be connected to any tube? I cut the wires too short but I can still reach the second power tube.
Re: 5e3 kit - filament center tap
« Reply #1 on: June 01, 2015, 11:03:21 am »
*Anywhere* in the amp will work fine. Fender connected it to the pilot lamp ass'y, of all places. Probably, the closer to the power supply, the better.
Offline 6v6Pin1
« Reply #2 on: June 01, 2015, 12:35:18 pm »
Ok great, this will be cleaner for me. I will connect second power tube -> Lamp -> 100 ohm resistors -> ground.
