August 29, 2026, 02:05:25 pm
Hoffman Amps Forum image Author Topic: Need Help in Tweaking my Peavey Pacer/AB763 Deluxe Reverb Conversion  (Read 21196 times)
Offline Platefire
I converted this 1976 Peavey Pacer to a One Channel AB763 Deluxe Reverb with a 6G16 Bias Tremolo in 2008. The amp is what I would call unbearably bright that when you tone it down with eq I end up cutting the bright switch, boosting bass and cutting treble to get in the tonal area I like. When you eq to that extreme the amps tends to get a little boomy. The mid eq control is a combination mid/raw. Up to about 4.5 mid peaks out and the tone stack is then progressively dialed out to fully clockwise(no tone stack). Also the amp tends to be a little sterile in touch response. Playing it fully raw helps the sterilness but is usually too bright like that also. I have tried a few other speakers but the brightness/sterileness seems to follow. The plate voltage was a little hot last time I checked at about 415 VDC on two JJ 6V6S. The bias on those tubes reads 26mV and 30mV which should be hot for 6V6's but are relatively cool to the touch. I've tried to love this amp as is but my love is running thin;>/
That is the main issue with the amp. I have a couple of minor issues that I think is easily tweaked which is on the bias trem the speed control works fine but intensity has to be at 100% to get close to what I like and still comes up a little short. The intensity needs to go more intense.
Also the amp has a little more operational hum than I like that needs to be lowered.
I am attaching the as-built schematic, the original Fender AB763 DR schematic for reference and a gut shot for an idea of what the layout is. I might have some mistakes I never located??? I would appreciate your input, suggestions and pointing out any errors you see. I want to get this amp usable for my purposes and would appreciate your help. Platefire
« Last Edit: June 18, 2015, 12:15:16 am by Platefire »
On the right track now<><
Re: Need Help in Tweaking my Peavey Pacer/AB763 Deluxe Reverb Conversion
« Reply #1 on: June 17, 2015, 03:58:27 pm »
Different speaker?
Offline Platefire
« Reply #2 on: June 17, 2015, 04:11:51 pm »
Yeah, I have tried different speakers but ones I had on hand and didn't order anything new. I originally had a Carvin British Series which was made by Eminence, and Texas Heat by Eminence and right now I have a Weber Ferrowmax/VST 12SIGF-S. I recently took out the vintage RCA Blackplate in V1 and installed a new EH 12AX7 and it seemed to help some. It just seems strange to me having to go to such an extreme on the eq to dial in some fat tone. Maybe that's normal for this amp? Platefire
Offline Platefire
« Reply #3 on: June 18, 2015, 12:39:37 am »
I did some more experimenting to try to eliminate the basics before I pulled the chassis. I checked all the tubes:
1-Tried a vintage set of Sylvania 6V6's and it had no effect on the tone.
2-Traded out all of the preamp tubes one at a time to see if that made a difference. It really didn't.
3-Tried a Eminence Ragin Cajun speaker, no improvement.
4-I even tried running the bias a little cooler, no improvement.
So I'm beginning to believe the fault is in the circuit.
I have found a couple of mistakes on my schematic. Phase inverter tube should be a V5(12AT7) instead of V4 and the V4 should be the tremolo tube presently labeled V5.
I know I did this when I was in completion stage back in 2008, but I think I will do it again and go over all components for correct values when I pull the chassis. Platefire
Offline VMS
« Reply #4 on: June 18, 2015, 01:48:09 am »
Have you tried the amp without the nfb-loop?
Offline ac427v
« Reply #5 on: June 18, 2015, 07:47:25 am »
Hi Platefire, It looks like you have too much negative feedback. Leo used the 820 ohm /100 ohm circuit for the 2 or 4 ohm speaker load amps. He used 820 ohm /47 ohm circuit for the 8 ohm speaker load on the Deluxe Reverb.
--craig
Offline Platefire
« Reply #6 on: June 18, 2015, 08:52:05 am »
I haven't tried it without the NFB. I recall when I had a thread regarding this amp back when I was building it there was discussion about the 47 ohm to ground on the end of the NFB loop---as I recall some AB763 on other models may have had a 100 ohms but the DR had 47 That will be something I'll look at when I pull the chassis and make sure the right value resistors are in there and maybe disconnect it just to see what that does. Seem like a temporary jumper over the resistors might do that?
I keep wondering about that added mid/raw control, maybe jumping over that 100K pot with a 6.8K resistor to ground to see what that does.
Another thing I'm wondering about is my schematic shows 1500 resistor on V1b cathode and the original AB763 DR schematic is a 820--wondering why I did that?
One thing I was noticing last night in experimenting was when I increased the reverb the hum also increased! I tried a different 12AT7 driver and 12AX7 recovery but it didn't change the hum.
Another thing I should say about this just info purposes, when I was checking the preamp tubes last night I found I had a 12AX7 in the PI position. I tried a 12AT7 in that position and it even sounded worst, so I put the 12AX7 back in there---so that seemed a little strange. I think that's what I originally did was tried the 12AT7 and didn't like it and went with the 12AX---this may be an indicator of something amiss.
No doubt about it the amp is unnaturally brittle. Got to get to the bottom of it. I like nice round tone. Platefire
« Last Edit: June 18, 2015, 09:06:09 am by Platefire »
« Reply #7 on: June 18, 2015, 09:32:40 am »
That's correct. Any model that had a 8Ω speaker used a 47Ω. Models that had a 2Ω or 4Ω speaker used a 100Ω.
Yes, or just disconnect the NFB wire at the speaker jack, whichever is easier.
Because your V1B does not share a cathode resistor with another tube like the original. 1500Ω is correct for your circuit.
The AB763 circuit is capable of sounding very bright because of the mid scooped tone stack. But you should also be able to get mellow tones just by twisting the knobs and turning the bright switch off. If you have any Celestion speakers try them.
Offline Platefire
« Reply #8 on: June 18, 2015, 11:14:26 am »
Howdy Sluckey
It's starting to come back to me now. I found my old project folder on this and it was Doug who paved the way on this one on a old fender amp he re-worked including adding the 6G16 bias Tremolo to the amp. I'm thinking there has to be some kind of bad connection, wrong component value or something is out of whack---I just have to fine it. I'm more familiar with fender circuits than anything else and this one is just not behaving correctly. I do have an 8 Ohm speaker--so I need to be sure that resistor to ground on the NFB is 47---not 100 like on the schematic and try it without NFB--may could make it switchable if it has a good effect without NFB?
As I recall it seems we made efforts to make the 1 channel operate as if the other channel still existed. Closer checking may show what? Platefire
« Last Edit: June 18, 2015, 11:17:02 am by Platefire »
« Reply #9 on: June 18, 2015, 11:59:15 am »
Plate,
After looking closely at your posted pictures I only have one question that may help.
What is the actual value of your slope resistor on your tone stack?
Kinda looks like brown-black-brown which would be 100 ohm instead of 100K  :dontknow:
The pic resolution isn't great and it's throwing me off.
Good luck and hope you find the problem sooner than later.
Offline Platefire
« Reply #10 on: June 18, 2015, 12:49:23 pm »
Thanks Silvergun
I checked that and it's Brown/Black/yellow and also checked it with an Ohm meter and it read 105K.
I think I might have found a serious problem on the wiring of the Mid/Raw control. Please check my as built schematic if it shows the correct wiring for this pot. If I'm reading it correctly the wire from the ground term on the bass pot goes to the input of the Mid/Raw pot, the input and output terms also are connected plus the ground term is wired to ground.
On my amp it's not so----The wire from the bass pot ground term goes to the output of the Mid/Raw pot, the input term is empty! and the ground term is wired to ground. So it the schematic right on my amp wiring??? Platefire
« Reply #11 on: June 18, 2015, 12:56:13 pm »
Is the pot order on the chassis
Volume
Treble
Mid
Bass
If so, look at a fender layout with a i mid pot as it should be the same.
« Reply #12 on: June 18, 2015, 01:05:37 pm »
I have had a Deluxe build feel sterile from too much voltage on V1 and NFB can always do this.  When you determine you have no wiring issues and it is still sterile.  Disconnect NFB as suggested and if you have a Variac try lowering the voltage to the amp.  Of course check v1 first.  Mine was at about 190vdc and dropping it with a 5u4Gb gave it some sag and give.  Touch!
I now has a 180K Plate resistor on v1 as well.
« Reply #13 on: June 18, 2015, 01:20:40 pm »
Like this Plate;
« Reply #14 on: June 18, 2015, 01:41:09 pm »
You're fine. All three of the schematics in this pic are the same even though they are wired slightly different. Your mid/raw pot is being used as a two terminal variable resistor.
Offline Platefire
« Reply #15 on: June 18, 2015, 11:00:56 pm »
Thanks guys for all the help and input. I've been working on it about the last 3 hours. My Middle/raw pot was wired like sluckey "A" arrangement even though the my schematic shows type "B". I got an alligator clip jumper and wired it up like sluckeys "B" arrangement and to my ears it sounds a whole lot better. I know sluckey said it is no difference, just a variable resistor to ground but when I including that input term like "B" arrangement, it made a world of difference to me. If it's just my imagination--Great! Good imagination :icon_biggrin: Tomorrow when I wake up, it may sound terrible :dontknow:
I checked all the voltages and included all the new voltage readings on the revised schematic attached. Some voltages on the preamp tubes is as much as 30V to 40V higher than Fender schematic. See V3 at about 210 and should be 170/180. Also on V4 PI more that 50V higher than Fenders. It appears I need to go higher on the power rail resistor to more than 10K.
To me the 12AX7 in the PI V5 sounds better than a 12AT7. Please take a look at the voltages and what do you think? Platefire
Offline ac427v
« Reply #16 on: June 19, 2015, 07:30:10 am »
I like lower voltages too. I used a 5R4GYB and my voltages dropped about 10% compared to a 5AR4. It only uses 2 amps of heater current so most power transformers can handle it.
Any update on the value of the bottom feedback resistor? I'd kinda like to see that is right before you start modding to fix the sound.
Craig
Offline Platefire
« Reply #17 on: June 19, 2015, 09:34:50 am »
Yeah, I need to change the NFB resistor to a 47. I'm also wanting as Ed suggested to hear the amp without NFB. I'm just wondering if I install a SPST switch to disconnect NFB does the 820 and 47 need to be switched off or just the 820? The bottom leg and 47 to ground is connected to that resistor/cap network on PI, so that makes me think only the 820 would need to be turned off---any insight? So I think just disconnecting the NFB from speaker jack would do it!
Also I need to look through my tube inventory to see what rectifiers I have. Currently a GZ34 in there.
On the tremolo, I changed the the 470K resistor to 220K and the .1 cap to ground to .047 adjacent to the intensity pot to increase intensity back in 2008 right after I finished but--I have to turn the intensity to 100% now to get what I want, so to get a little more play in my pot travel and a little more adjustment, I need to change the 220K resistor to 100k as instructed on Doug's tweaking of the 6G16.
Also to decrease operating hum, think I need to go from regular hook up wire to shielded on the input jack to first stage preamp and then from V1a first stage preamp to also from V2b second stage preamp where hookup wire goes under board to volume control. If I still have some hum after that, I will know to look elsewhere. Thanks, Platefire
BTW-checking my tube inventory, I do have a couple of 5U4GB's but not anything else that would work. How bout 5Y3?
« Last Edit: June 19, 2015, 10:03:57 am by Platefire »
« Reply #18 on: June 19, 2015, 10:45:27 am »
You can put the switch in series between the 820Ω and the speaker jack to open the circuit, or you can put it in parallel to the 47Ω to short it out. Either way works fine.
I noticed your output tubes are biased on the cool side. If you bias them hotter you will get more tremolo effect. There's always a tradeoff between bias and trem strength in this type circuit.
5Y3 may be too light weight for a Deluxe Reverb. But I'd try it. If you have a NOS 5Y3 it will definitely drop the voltage. I would not put that 5U4 in it unless you know the PT can supply 5volts at 3 amps. 5AR4/GZ34 is what Leo used. I'm not concerned about the voltage on the little tubes. Anyway, if you crank the bias current up to about 25mA, the extra load will likely lower all plate voltages in the amp. Try it and see. My DR is running with 423v on the plates and 24mA cathode current. You can see my voltages here...
     http://home.comcast.net/~seluckey/amps/tdr/tdr.pdf
Offline Platefire
« Reply #19 on: June 19, 2015, 10:26:44 pm »
sluckey
I did the bias change as you suggested. Even though my JJ's are supposed to be a matched set, their off, so I had to find a happy medium---a little below and a little above 25mV. So it's presently set at 23.9/27.6 and -36.5 Bias voltage.
I re-checked all the voltages to see what effect it had. All seems to be in the ballpark as yours with the exception of the PI, which is a 12AX7 in mind instead of a 12AT7--I don't know if that's why they so much higher? Anyway here is a side by side comparison:
sluckey                Platefire
V1-206/203--------V1-206/205
V2-424/424--------V2-414/412
v3-206/209--------V3-203/215
V4-196/194--------V4-242/220
V5-423/425--------V5-420/419
V6-423/425--------V6-420/417
V7-330/330AC-----V7-329/329AC
Har! Got a question about your schematic;>) You said in an earlier post that the NFB resistor to ground should be 47 with an 8Ohm speaker and 100 for 2/4 Ohm load. So why do you have a 100 Ohm resistor with your 8 Ohm speaker :w2: Thanks, Platefirre
« Reply #20 on: June 20, 2015, 04:15:04 am »
It's a mistake.
Did your tremolo get stronger?
Offline Platefire
« Reply #21 on: June 20, 2015, 07:56:19 am »
Regarding the "is the tremolo stronger" question? a long story!
Before I started tweaking my amp this time, I had the bias really hot closer to 30mV. I got to reading voltages and checking with the Weber Bias Calculator and ended up adjusting it down closer to 20mV. So my statement that the intensity needed to be slightly more was was in reference to the old 30mV setting before I started all this tweaking. So no, it's not better but about the same and really its almost adequate  but it's just something about turning it to 100% without anymore play---bugs me.
OK---on the 47 Ohm. Just checking! Have you ever tired yours without the NFB? Thanks, Platefire
« Reply #22 on: June 20, 2015, 09:19:36 am »
Yes, but I didn't like it. The amp sounded more open and raw. Lost a lot of that blackface Fender vibe.
If you put a 22µF bypass cap on the cathode (pin 3) of your trem tube the strength will increase considerably.
Offline Platefire
« Reply #23 on: June 20, 2015, 11:17:07 am »
Hay sluckey, thanks for the tip on the 22uf/25V on the trem cathode resistor. I just temporarily tagged one onto the resistor legs with a good mechanical connection for testing and yeah, I think that helped to where I can reach my fav sound at about 3:00 with a little play.
I went ahead and disconnected the NFB and tested. I like the added option of early dirt and Man! turn the raw fully clockwise with the NFB off and it's a loose cannon:>)----the good thing is with a switch you can easily get back to blackface territory. Same with the raw control--turn it counter-clockwise to about 4.5 and your there. So I don't mind drifting out of blackface territory as long as I can come back home.
I did notice when I disconnected the NFB, the operating hum increased with more gain. Not all that bad but it's on the edge of aggrivating. I checked all my ground points--good, appears to have good separation between power supply and grid wires. Not sure what generating the hum---again first step shielded on grid wires up to vol pot. Thanks, Platefire
« Last Edit: June 20, 2015, 02:30:33 pm by Platefire »
« Reply #24 on: June 21, 2015, 03:54:46 pm »
Plate,
IF you want a smoother overdrive that is not brittle or harsh in any way, consider giving this a try. I think you would find it smoother and a clearer (less muddy/gritty) tone.   I find both the PAB (preamp boost) and the mid-boost to be quite useful.
This is essentially the tone stack I use on my Tweed BluezMeister.  I feel like it has a wonderful clean tone that is significantly clearer and warmer then the Princeton Reverb I owned and most AB763 amps I've played.
I find the 25uf cathode caps to consistently be too muddy for my tonal preferences except in rare exceptions. .
with respect, Tubenit
« Last Edit: June 21, 2015, 09:11:50 pm by tubenit »
Offline MadMax
« Reply #25 on: June 22, 2015, 08:10:25 am »
Tubenit,
What are those two symbols within the highlighted section that look like traffic lights? (The only things that aren't shaded yellow).
« Reply #26 on: June 22, 2015, 09:16:25 am »
SPDT mini-toggle switches.  I can either switch mine by mini-toggle and/or relay foot switching.
Offline Platefire
« Reply #27 on: June 22, 2015, 07:16:15 pm »
Hi Tubenit
Thanks for the plan. I went over it as a possibility and one thing I couldn't work out is real estate to locate the two SPDT switches---the back panel is the only space left. I was also going to put a NFB switch back there---so would one of these switches in your plan eliminate the need to switch NFB off for more dirt or to be used in conjunction with the NFB switch?
I'm going to be out of pocket for a couple of weeks so I will have to resume this when I get back. Something to ponder :think1: Thanks, Platefire
« Last Edit: June 22, 2015, 07:19:14 pm by Platefire »
« Reply #28 on: June 22, 2015, 08:59:53 pm »
Plate,
I have done some negative feedback switches in the past on different amps.  It's a useful mod and I do like the tone of the NFB disconnected. However, it does induce more noise into the amp at idle and has more grit then smoothness to it.  So, I have not done one on my last several amps AND I removed them on two other amps. On one of those amps where I removed it, I simply inserted a plastic plug to fill the hole.  So, I wasn't removing the NFB to make room for anything else.  I removed it because I wasn't using it.
I do like the PAB and midboost on my amps. I've put something similar on 5 different amps and found them worthwhile. Between those two, I use the midboost more.  The PAB feature helps a lot with overdrive but it induces noise at idle like the NFB switch does. So, .............. IF I only had room for one mod, I'd do the midboost. The midboost is especially useful going from strat single coil type tone to a fatter humbucker type tone.
Remember, all of this is personal taste & what I like might seem less than useful or desirable to another person.
What I do like a lot is how the mid pot and bass pot are separate and each how their own ground. To my ears, this gives more tonal options as I dial those then when the bass is connected into the mid pot like on Fender amps or Marshall.  AND this is a very easy rewiring to try out.
A fairly non-intrusive and easily reversible wiring approach may be to replace the cathode caps with values I suggested and simply wire your mid pot and bass pot apart and use a 10k resistor to ground on the bass pot.  IF you like that, then add the mid boost feature.
Note the mid and bass capacitor values in the tone stack I use.  It may be helpful to try those, but what you have already may suit you just fine?
Anyhow, these are just ideas to consider.  I want your amp to sound like what you want, so I am just tossing out ideas in response to the thread comments.  Not saying you "should" try this at all.   :icon_biggrin:
Best regards and respect,  Tubenit
Offline Platefire
« Reply #29 on: June 23, 2015, 10:15:54 am »
Well I did determine something last night. I agree with you about not having a NFB switch. A couple of days ago I hooked a SPST switch up in the back of my chassis to the NFB without drilling a hole and have been A/B'ing it with and without NFB. Tested it pretty thoroughly with a lot of jamming. I too believe it's something that would go by the wayside into non use.
I am kind of leaning to preserving the original circuit since it's sounding so much better to my ears when I rewired my raw switch like my own schematic. Don't know why it wasn't wired that way to start with? I think I really need to get a better speaker for this amp that would lean in a darker direction instead of brighter. sluckey suggested Celestion plus I still have some corrections to the circuit I haven't performed yet I probably need to do first before making any further determinations. Since I don't have any old vintage fender amps, my original idea was to get as close as possible to that sound with this Peavey Pacer conversion. I have seriously considered removing the Mid/Raw control and putting the tone stack back to original spec--I can't help but wonder if that slight deviation might be hindering it. My only historical reference tp DR sound is I did have a Silverface DR in the 70's that I really liked. Platefire
« Last Edit: June 23, 2015, 10:21:42 am by Platefire »
« Reply #30 on: June 23, 2015, 11:10:46 am »
Did someone say Celestion?  Greenbacks do sound nice in a Deluxe and I have used a single 12 Blue extension.  I really love the compression of AlNiCo speakers in Fender amps.
The Blackface Deluxe is arguably the most desirable club amp there is.  It is very versatile in its stock form.  I don't care for NFB switches, but I do like them on pots.  This way if I am in a small place I can back off and get a little breakup sooner, but if I need more volume and headroom I can tighten it up.  IMO NFB is the most important factor in the feel of an amp.
I do like a mid pot and a dwell.  Everything else is just icing on the cake.  I also like a 2, 10 with a BF Deluxe.  It is really a great amp and I am sure you will get it where you want it.  I know when I have it right is when I plug in and start playing and no matter what I play it sounds good to me.
« Reply #31 on: June 23, 2015, 11:31:00 am »
Here's a few other things to consider:
-A speaker that will get you more bass and less highs without breaking the bank (I haven't tried it but I do like the Celestion G12H30 it's "based" on)
The "55hz" spec represents the lower resonant frequency and should result in a more bass-rich tone
https://wgs4.com/Reaper55
-I have always raised the value of the entrance cap to the P.I. from the stock .001 (by at least doubling it with a parallel cap of the same value, but different brand/composition, based on experimentation)
-My favorite mod for thickening it up is to replace the MID cap with a much lower value, which brings the slope of the mid-bass EQ up A LOT(I use .001 or .002)
Put it on a switch as a "mid-boost" with the low value cap in the "boost" position and the stock cap as the "OFF" position
-The MID cap trick PLUS the PI entrance cap adjustment gives you a wide range of "tune-ability", but obviously take you away from the stock arrangement.
Best of luck tuning it in
EDIT- I found this video that I feel does a good job of letting us hear the difference in the 55hz nodel
https://www.youtube.com/watch?v=hevJjWLyfWg
« Last Edit: June 23, 2015, 12:10:37 pm by SILVERGUN »
Offline Platefire
« Reply #32 on: June 24, 2015, 04:28:36 am »
Thanks! Like I said on previous post, will be back in two weeks. See you then. Platefire
BTW-Got a new smart phone. So if I figure it out, might be back sooner on that :dontknow:
Offline Platefire
« Reply #33 on: June 28, 2015, 06:39:28 am »
I've been thinking about the higher than normal voltages downstream fromm
Power rail B. Thinking of increasing the 10k between rail B & C upward to see what that does. Platefire
Offline Platefire
« Reply #34 on: June 30, 2015, 09:31:41 pm »
Got a question about my last check on voltages listed on post #19. On V4 PI plate voltage is 242/220 yet my "C" rail voltage is 325 V just like the Fender DR layout Dwg. Also the plate voltages on the Fender layout is 180/170. OK-----having established that and what I  can't resolve in my thinking about it is----if my "C" rail voltage iis 325 same as Fender DR, then why is my PI plate voltages so much higher-----I don't get it?? Patefire
« Last Edit: June 30, 2015, 09:38:03 pm by Platefire »
« Reply #35 on: June 30, 2015, 10:08:16 pm »
I don't get it??
Maybe it's because you are using a 12AX7 for the PI rather than a 12AT7.
Offline Platefire
« Reply #36 on: July 01, 2015, 09:35:21 am »
Well I just never observed and noted a 12ax tube making that much difference in plate voltage before? This transformer/choke set came out of a brand new DRRI that was designed for a normal channel plus I have a dias based tremolo. That's just one 12ax less than original transformer design, so it shouldn't be that much over powered to make that much difference it seems tolike. Platefire
« Reply #37 on: July 01, 2015, 09:50:18 am »
Since it's on your mind why not try it now. Let us know what you find out.
Offline Platefire
« Reply #38 on: July 01, 2015, 10:20:48 am »
Well I'm not at home. In NC for anther week. I am working this amp long distance :l2:   So it will be another week to see what a 12AT7 would do to the plate voltage. I'll try it for grins when I get back. I know the current draw is different on the two tubes and I suppose that's what's causing the ruckus! Platefire
Offline Platefire
« Reply #39 on: July 09, 2015, 07:56:37 am »
Well I'm back now. I tried the 12at7 in the PI and the voltage reading went down to 176/184 as compared to stock Fender 170/180----with modern AC suppy, not bad!
My reverb control is super sensitive where it gets real wet fast. I installed 12au7 in my v2 driver and that helped some. Also v3 and v1 is about 30 to 40 v high. Think I'm going to experiment with increasing main resistor to node D to lower voltage to v1 and v3 iin one sweep.
My schemtic shows v3a voltage from node C incorrectly, it should be and is from node D.
I really would like to hear it at vintage stock voltages before deciding any further changes other than maybe a different speaker. Platefire
BTW---think I'll leave the 12at7 in the PI for now
« Last Edit: July 09, 2015, 08:01:14 am by Platefire »
« Reply #40 on: July 09, 2015, 10:13:01 am »
Replace the pot with a 100KA (log taper)pot.
Offline Platefire
« Reply #41 on: July 10, 2015, 12:17:55 pm »
Thanks Sluckey for the tip on the reverb pot.
Got a turret/de-solder question since I don't do this very often and get a little nervous due to my lack of experience pulling parts instead of installing.
OK---this is the situation---you got two resistors coming into the same turret head with the leads down in the top hole with a nice cap of shinny solder on top. Whats the best method of removal? My thought would be to heat the top of the turret up until the solder starts melting and pull the resistors leads out with needle nose pliers----then re-heat it and suck excess solder out of the hole with a solder sucker. This may not be best? If so please inform me! Platefire
« Reply #42 on: July 10, 2015, 12:25:31 pm »
I usually heat the top of the side of the turret rather then straight down on the hole of the turret. Use pliars & then a solder sucker.
Offline Platefire
« Reply #43 on: July 10, 2015, 03:04:10 pm »
Thanks tubenit
I've had a lot of experience on old style p to p but not on turret board de-soldering/removal.
Platefire
Offline Platefire
« Reply #44 on: July 11, 2015, 11:32:52 pm »
Did a lot of the changes discussed and Man! On first impressions, I think I've got a lot sweeter DR.
Changed the NFB resistor to ground from 100 to 47
Permanently added a 22uf/50V to trem first stage cathode. This improved the intensity nicely.
Changed out power resistor from node C to D from a 10K/3W to a 22K/3W
The 22K resistor to node "D" really brought the V1 & V3 voltages in line with Fender DR AB763 levels within just a few volts. That changed the amp quiet a bit. The clean headroom, overall amp volume and brightness was reduced in one sweep. The amp sound now has more body and less ice picky. The amp is more touch responsive with the tone having more even harmonic content. Voltages across the board are pretty much in line with original DR, so hopefully I'm now getting a reasonable facsimile of what a vintage DR would sound like. I'm still debating with myself about a NFB switch or pot?? Attached is the schematic with I think all the latest changes incorporated. Thanks very much for everyone's help!!! :worthy1: Platefire
« Last Edit: July 13, 2015, 12:04:18 am by Platefire »
Offline Platefire
« Reply #45 on: July 12, 2015, 09:52:31 pm »
Just wondering??? How many really use their NFB switching/pot arrangement on a regular basis. tubenit said he didn't use his, put it back stock and plugged the hole. Ed said he likes a pot to dial in a sweet spot in a smaller room to get a little more breakup.
I've been thinking about possible versatile arrangements----DPDT Center off--with center off=no feedback, jumper on one set of poles for normal feedback and the other set of poles with a fixed resistor or connected to a pot.
Also I was thinking of a pot with a on and off switch. Run the NFB from speaker to the input term of the pot first, then from pot output term to one term of the switch and from the other switch term to the regular stock NFB resistors of amp. Switch off would be no NFB, switched on would be stock NFB+pot resistance as set and full clockwise would be the stock DR NFB setting.
There is probably better ways to do this that has been rehashed before--these were just some of my thoughts going beyond just a SPST switch with a little more versatility. All this may be overkill, but I did try no NFB and kinda liked it!?!?  I thinking for a blues digger like me maybe a nice option. But really---I use pedals for my dirt! so you can see the debate is still raging with myself :icon_biggrin:
sluckey---you recommended a 100kL pot for reverb---I checked and that's what is in there just like the original DR schematic.
I've really been getting into DR's lately. Took my Allen Accomplice to church and set it up. It has a Emi Texas Heat.
Really sounding good with my strats/pedalboard. Tweaking my Peavey DR at homes so I'm DR to the max here lately.
Not a bad place to be! Platefire
« Last Edit: July 12, 2015, 10:15:10 pm by Platefire »
« Reply #46 on: July 12, 2015, 10:02:58 pm »
Uh, no. I recommended you REPLACE that pot with a 100KA (log taper).
Offline Platefire
« Reply #47 on: July 12, 2015, 10:08:00 pm »
OK, sluckey--sorry! you got to cut us old men a little slack :l2: guess I'll have to order one, none in stock!
Offline Platefire
« Reply #48 on: July 14, 2015, 12:08:19 pm »
Think I've decided what I want to do on NFB. I like Ed's use of a pot for fine tuning the NFB or lack thereof to your taste. Maybe just a little extra resistance to make a smaller room more cozy but----I also like the ability to go full grown Nada NFB. I don't want to drill a lot of holes--one is enough.
So I came up with the idea of using a switchable pot. The only problem I couldn't fine any 100 or 50KL switchable pots. I have a non-switchable 50KA so I measured resistance and going counterclockwise from 4:00 oclock fully open(no resistance) it goes to about 12:00 oclock only gains 5K resistance. So the other 45K is from 12:00 to 8:00 oclock---then switched off---no NFB. I think that will be fine!!! So Doug had a 50KA switchable, so I ordered that. Attached is a quick and dirty sketch of hookup and operation. Platefire
« Last Edit: July 14, 2015, 12:13:13 pm by Platefire »
« Reply #49 on: July 14, 2015, 03:18:48 pm »
I like to use a locking pot.  I never used a switchable pot as I never found a need.  I have used switches for different R values.  I don't change them often.  I find I change more on Plexi and JCM800 builds.
I don't change them much on my Deluxe or Princeton builds but I like having them, but when you hear a Fender amp with little NFB and add some raw you really kinda sorta have it available.  Makes them dirty little critters.  Kills the blackface vibe, but I remember listening to Pete Anderson talking about what Steve Fryette modding his 66 Deluxe he did these things.  Pete said he recorded all his early stuff with Dwight Yoakam using the Deluxe but mainly using all mids from the raw that was installed.
I have also heard of changing to a cathode driven tonestack.  Supposed to be a fairly simple mod to do this.
Have you decided on your speaker or speakers?  This past weekend I played the Blackjack 21 FUCHS amp with the Wizard speaker and found out it is supposed to be like the G12-30 Celestion.  Basically like a greenback.  I really like that combo and if I did not have too many amps I would really like to have one of these.
