September 17, 2026, 07:36:19 am
Hoffman Amps Forum image Author Topic: replace amp input jack with switch  (Read 5007 times)
Offline waldner
  • I REALLY DO love tube amps
« on: June 24, 2015, 11:21:28 pm »
I want to put a switch in place of one of the unused input jacks on an amp.  The standard carling switches are a larger diameter than the input jack holes.  Anyone know of any SPDT switches I could get that would fit the existing hole size so I don't have to drill it larger?  I guess I could use one of the tiny little switches with the blue back, but they are so small compared to the hole that they will want to move around.
I figure someone must have covered this territory before but I couldn't find any info.
Re: replace amp input jack with switch
« Reply #1 on: June 25, 2015, 12:07:38 am »
The easy but not bat-handled answer would be to use a rotary switch...or, a pot w/a built in switch, and don't use the pot. I'm unaware of a 3/8" bushing bat-handled switch.
Offline AZJimC
  • What a pretty glow!
« Reply #2 on: June 25, 2015, 03:19:50 am »
I recently came upon this issue. I ended up with a 1/4" Carling mini toggle. I made a bushing by slicing a ring from a 3/8" plastic tube. A couple washers and it smashes the plastic bushing into place and it stays centered very well.
« Reply #3 on: June 25, 2015, 09:30:32 am »
We also need to know what you want to use the switch for.
Offline waldner
« Reply #4 on: June 25, 2015, 10:38:01 am »
I want to use the switch to internally jumper the inputs on a 5F6A.   I did it on my 5E3 and it's nice.  I also never use the 2 low inputs and then could put another mod switch in the other unused hole.
Offline vibrolax
  • In a vacuum tube, no one can hear you scream
    • Jon's Homepage - DIY vacuum tube guitar amps, pro audio, original music.
« Reply #5 on: June 25, 2015, 01:44:26 pm »
I like the 1/4" mini-toggle solution.  It's a low-current signal routing application, so no worries about big fat wire or its current-carrying capacity.
Jon
Jon
Offline MFowler
« Reply #6 on: June 26, 2015, 06:59:10 am »
I use a plastic/nylon isolating washer with 1/4" mini switch in this jack hole sometimes.
But you could just use the input jack wired as jumpered so you would have a normal input jack and a jumpered jack that would save you headaches.
« Reply #7 on: June 26, 2015, 07:20:10 am »
RadioShack has this 'push on/push off' switch that fits a 3/8" hole. They may also have other options...
http://comingsoon.radioshack.com/spst-3-amp-soft-feel-push-on-push-off-switch/2751565.html
EDIT... I just realized you need a SPDT switch. Sorry.
« Last Edit: June 26, 2015, 07:31:48 am by sluckey »
