October 12, 2026, 05:16:29 am
Hoffman Amps Forum image Author Topic: Smartphone/Amp Conflict  (Read 12751 times)
Offline Platefire
« on: June 28, 2015, 10:37:40 am »
Don't know how it is with my other amps but I've been using my DIY Champ lately and everytime I switch it of standby with my new smartphone in its holster, it just makes all kinds of noise. I have to get it at least 20 feet away to stop. Any easy solutions short of turning my phone completely off or moving it away from my amp??? Platefire
On the right track now<><
Re: Smartphone/Amp Conflict
« Reply #1 on: June 28, 2015, 11:30:34 am »
Probably need a grid stopper resistor on the grid input to the first preamp tube. Or, if it's in a cabinet with the tubes oriented upside down, you may need a sheet of sheet metal or screening to cover the open "top" of the inverted chassis.
Offline Platefire
« Reply #2 on: June 28, 2015, 12:00:04 pm »
Got the grid stoppers. The cab/chassis is classic 5F1 arrangement but no shielding on inside backplate chassis cover. Also playing a non-shielded strat sss. Platefire
« Reply #3 on: June 28, 2015, 12:53:35 pm »
That should tell you how much your smartphone is talking to big brother!
Try a 100pF cap across the input jack to see if that will help the amp. Probably can't make the phone shutup without pulling the battery.
Offline Platefire
« Reply #4 on: June 28, 2015, 02:37:31 pm »
OK! When I back in Lousyanna I'll give that a shot. Thanks, Platefire
« Reply #5 on: June 28, 2015, 03:33:09 pm »
Platefire,
Just more evidence on how awful smart phones are.  Anything that would not be compatible and respectful to that sweet Fender amp should be considered suspect at the very least.
I don't trust my smart phone for a minute. I find them to be like unfriendly rabid pitbulls.   :cussing: :icon_biggrin:
You should have not gotten one.  You have always been such a great guy &  I fear that phone will surely be your demise. They are consistently malicious and hostile to anyone born in the 50's.
 :embarrassed: :cry: :l2:
« Reply #6 on: June 28, 2015, 03:42:51 pm »
AMEN!
« Reply #7 on: June 28, 2015, 04:11:04 pm »
Let us ALL rise up and make a noise unto the Tubenit and say amen!
Offline Platefire
« Reply #8 on: June 28, 2015, 05:42:14 pm »
Amen, Evil Machine! Plus embarising. I walk upon the Church stage to begin Praise & Worship, flip off my standby switch----- not only making a noise but multiple noises simeltaniously. I had to pull off the phone and hand it off to my wife while everbody. Is looking around wondering what's going on. Don't want this to be a continuing episode :help:
« Reply #9 on: June 28, 2015, 06:41:46 pm »
You could just wrap the phone in tin-foil, God usually doesn't call on phones anyway :icon_biggrin:
Offline AZJimC
  • What a pretty glow!
« Reply #10 on: June 28, 2015, 07:10:09 pm »
I used to line my hats with foil, but that quit working somewhere in the mid 90's...
New technology I'm assuming, now you have to use an active jammer. :cussing:
« Reply #11 on: June 28, 2015, 07:47:51 pm »
Leave your cell phone in the parking lot.
Offline Toxophilite
« Reply #12 on: June 28, 2015, 08:00:59 pm »
A conventional hammer should solve that problem, your amp will work perfectly after that.
i wonder what sort of ringtone people use for gods?? :icon_biggrin:
« Reply #13 on: June 28, 2015, 09:07:25 pm »
like, maybe a HF tube, say 50W, put into oscillation and see if the phone still works :dontknow:
« Reply #14 on: June 28, 2015, 09:09:22 pm »
You can smash, or tin-wrap, *your* phone, but there are others.
May I suggest that you add shielding to your rig? Come over here I'll give you a 6"x15" hunk of air-duct you can nail over the open side of the chassis. Good hardware/home stores have aluminum tape which might work in the axe. If you are on the road, go in a deli and beg/buy a couple feet of aluminum foil, work it in there so it touches ground but doesn't short anything else.
« Reply #15 on: June 28, 2015, 10:08:18 pm »
you probably have AT&T or T-Mobile or one of their re-sellers. GSM phones: they are the worst. i have verizon: no issues unless i get a text message or call.
whenever richard comes over (he has t-mobile) we get to listen to: chop-chop-chop-padip-padip-padip at random and frequently... :-\
100pF grid to ground or grid to cathode on 1st stage will help A LOT. line the inside of cabinet with copper or aluminum foil. AC duct tape will probably work too.
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #16 on: June 28, 2015, 10:45:52 pm »
My drummer got a smartphone when they first came out.  At about the same time, I had installed a Death Metal mod in my JMP and it developed an intermittent crackle.  I took it home, laid it out on the bench, and (as frequently is the case) it worked fine and would not crackle.  It probably took me longer than it should have, but I eventually discovered that it only crackled when that guy had his smartphone with him.  The other guitar player had a Mesa and the phone had the same effect on it.  What was particularly interesting was that it made no difference if the smartphone was on or not - - it broadcasted exactly the same.  Sluckey is pretty hip to what is going on here and Toxophilite has a really good solution.  Whatever you do, don't put that thing up to your head.
High gain amps pick up those smartphones real good, so guitar shielding makes no difference.  In fact, we only notice it when we stop and the volume on the instruments are at zero.
I went to the Roswell UFO Museum and the younger people were wrapping their heads in aluminum foil.  I didn't know and I didn't bring any and those younger people wouldn't kick down with any.
Offline AZJimC
« Reply #17 on: June 29, 2015, 12:41:56 am »
Maybe a smartphone in one pocket, and an old dumb thinline dial job in the other so they cancel out?? :think1:
Offline Platefire
« Reply #18 on: June 29, 2015, 08:12:18 am »
I guess the easiest solution is just to leave it in the car.
« Last Edit: June 29, 2015, 08:14:36 am by Platefire »
Offline Fresh_Start
  • noob de Lux
« Reply #19 on: June 29, 2015, 08:16:17 am »
I like the noise cancelling concept!   :l2:
At first I thought you all were pulling my leg.  Now I'm wondering if some of the noise issues I've been having are due to the "smart" phone.  If it's so smart, why isn't it protected???
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #20 on: June 29, 2015, 09:00:33 am »
I heard/read/seen, somewhere that there's now a stray RF phone charger, would that be  like "perpetual motion?" :dontknow:
Offline Platefire
« Reply #21 on: June 29, 2015, 04:09:13 pm »
Well it sounds like just leaving it in the car would be simple enough but when you been wearing your phone in a holster for years everywhere you go, it's not an easy thing just to remember to take it off.
« Reply #22 on: July 03, 2015, 11:39:49 pm »
If it was just YOUR phone.
But nowadays, everybody and his dog is liable to show up with a phone. (There are cellphone-based dog tracking devices.)
And even if their last-week phone didn't make trouble, it could fall in the toilet and they show up with a new/different model.
And you might play out? If you don't do drunken pubs, maybe someone at church has a phone that dribbles static, or your uncle Fred at the family sing-along.
I think good shielding is important with any high-gain audio amplifier. And even a "tame" older Champ is high-gain in this context. It doesn't have to be headbanger-gain to pick-up a transmitter in the same room or house.
Offline Platefire
« Reply #23 on: July 04, 2015, 08:05:16 am »
Well my Champ is DIY with a switchable/Raw tone control to go from 5F1 to 5F2 plus a standby and NFB swith. My first all new build in 2001. I didn't shield the first and second stage preamp grids or the backplate. Never any problem until now. As long as the phone is about 15 feet away-+--no problem.
« Reply #24 on: July 04, 2015, 08:14:49 am »
Are you back home? Have you tried the cap on the input jack?
I still think the best idea is to leave the phone in the parking lot. Besides transmitting almost continuously, these smart phones make a lot more noises other than just announcing an incoming call.
Offline Platefire
« Reply #25 on: July 04, 2015, 12:43:24 pm »
No, won't be back until Thursday. One good thing it is helping me get aquantrd with my new phone as I now can do my internet stuff over it.
I
I got in a habit of keeping my phone close when I was chief care giver for my Dad before he passed but now their is no reason to have al phone on 24/7. So I can start laying my phone aside now without major damage. Main thing now is use it go find my wife when we go shopping :l2:
« Last Edit: July 04, 2015, 12:53:28 pm by Platefire »
« Reply #26 on: July 04, 2015, 12:50:27 pm »
That's called the freedom phone! Enjoy.
I just look for the blue light.   :l2:
« Reply #27 on: July 04, 2015, 01:19:26 pm »
Yeah, my wife ALWAYS wonders off as soon as I turn my back when were shopping, like a little kid.
Why do they do that?    :dontknow:      :laugh:
« Reply #28 on: July 04, 2015, 08:28:00 pm »
it's genetic, just make sure you have the keys and agree to meet at the car, I can get a good 30min snoze :icon_biggrin:
Offline Platefire
« Reply #29 on: July 05, 2015, 07:09:07 am »
I'm researching smart phone guitar amp apps. Not sure I want to go there but worth looking into. For my Android phone I found "Andrig" guitar amp models and effects. I.m trying to figure out how the interface will work. The last strat copy I bought has an analog/digital coverter to USB connection that might could be used?
BTW---I downloaded the gString app, so I now have a guitar tuner on my phone.
« Last Edit: July 05, 2015, 09:21:31 am by Platefire »
Offline Packerswin14
« Reply #30 on: July 14, 2015, 05:36:32 pm »
So did you come up with a solution?  My phone puts a whole bunch of hum and hiss into the in-ear monitoring system we use at church.  I've tried different receivers.  If I put the phone on the opposite side of my hip as the receiver, I can cut it by about 2/3, but the car shielding method is the only thing that's worked for me (shield it with a car in the parking lot).
Offline Platefire
« Reply #31 on: July 14, 2015, 06:51:36 pm »
Hello Packer
At. Church I usually sit on the front row for easy access to stage. I've tried just leaving it on the front row seat about 20 feet away from my amp, but it still was cutting up from there. The other night we were rehersing and I left in the sound room, then it was coming through the speaker mains/monitors. Like you, the only solution I've found is leave it in the car. Platefire
Offline stevehoover
« Reply #32 on: August 08, 2015, 12:11:38 pm »
I put my phone in an upside down metal mesh trash can (Faraday cage) and that shut it up.
It also screwed up the reception on the phone.   You should hear the racket that my router makes if I get an amp too close to that modern marvel.
It's too bad more of the old boys that designed the 50's and 60's tech that we love are not around and working.
They would have fixed the problem by now.
"Airplane mode" is what I use when trying to "mate" a smart phone with amplification.
I don't want to talk to anybody when the guitar is in my hands anyway.
« Reply #33 on: August 15, 2015, 07:38:01 am »
Hey Platefire. Have you tried 'airplane mode' yet? I think that may be your solution.
« Reply #34 on: August 15, 2015, 09:45:42 am »
Yeah, I was going to ask if you had the Bluetooth, WiFi, or Hotspot inadvertently turned on?  The only thing I noticed with my Major is when recording if I get close to the computer it makes a glorious noise.  Not sure if it is the monitor or the wireless mouse and keyboard.
« Reply #35 on: August 15, 2015, 09:56:48 am »
Oh please......
Jim :m8
« Reply #36 on: August 16, 2015, 02:44:25 pm »
« Reply #37 on: August 16, 2015, 09:12:49 pm »
 :l2: :l2: PRR you are the best for outside the box! :bravo1:
Offline Platefire
« Reply #38 on: August 16, 2015, 11:09:58 pm »
Wow! I'll try airplane mode, since I don't think I could handle PRR's metal purse. Let you know how it turns out!
