September 15, 2026, 06:07:06 am
Hoffman Amps Forum image Author Topic: Leslie speed controll  (Read 9459 times)
« on: June 30, 2015, 12:15:35 am »
Do you think this router speed control ($20) would be safe to use with the 2 speed guitar Leslie? But..... if it would work, it might be a noise generator?
(Scroll down the page a little.)
http://www.menards.com/main/tools-hardware/power-tools-accessories/routers-accessories/c-10087.htm
« Last Edit: June 30, 2015, 12:25:45 am by Willabe »
Offline scrimpus
Re: Leslie speed controll
« Reply #1 on: July 01, 2015, 12:31:26 pm »
That sort of thing will not work with the existing Leslie motors.
« Reply #2 on: July 01, 2015, 01:13:54 pm »
I don't doubt your answer but why won't it work?
The Hammond motors are a different kind of motor than used in routers?
« Last Edit: July 01, 2015, 01:38:19 pm by Willabe »
« Reply #3 on: July 28, 2015, 01:20:03 am »
Hey Brad, No that type of speed I don't think that it would work.
The motors in the leslie's are brushless and work on magnetic fields.
https://www.youtube.com/watch?v=OdnOnGjK8hM :dontknow:  :l2:
I did find that there is a controller that converts the single into a variable speed but they are about $800 bucks.
I know SG look into it but don't know how far he got. :icon_biggrin:
« Reply #4 on: July 28, 2015, 09:04:53 am »
Well guys...I didn't get far cause I didn't need one, but if you look at Reply #8 in Timbo's ROTOSONIC thread:
http://el34world.com/Forum/index.php?topic=17572.0
I mentioned the use of PWM (pulse width modulation) as it applies to wire feeders in welding.
PWM is used to provide a variable speed control so you can dial in your wire feed speed to match the voltage of the welding power source and application in MIG welding.
There is usually one pot on the front of these feeders that sets the wire feed speed by supplying a PC board with a control signal that gets converted into a control voltage that spins the drive motor at your desired speed.
So lets say the drive motor is 24VDC...it would receive a control voltage from 0VDC - 24VDC with 0VDC = a dead stop and 24VDC = full speed.
Brad, I might be able to harvest the parts you need to try this and ship them to you if you'd like to take a run at it.
I just don't have time/inspiration to hook it up myself right now. I choose the schematic that I posted originally because of the 120VAC input requirement,,,for simplicity.
My only big concern would be if the RPM range would be usable???  :dontknow:
It appears as though the Leslie had a slow=40RPM and a high =390RPM,,,so I'm not sure we could hit top speed.
We could do 0-?
The drive motors we use are over-kill for this application, but there are some light duty units that might work.
MY part of the dream would be to add a foot pedal to the equation that would contain just a pot, so you could have speed control from min -max. with your foot.
I also have access to some used/obsolete foot pedals here because of their use in TIG welding applications. They have switches that engage the circuit before the pot comes in to control the circuit. That's another possibility...have the switch activate the leslie, and the pedal travel work the speed.
This all would take someone more motivated than I to pull together, but sure would be cool. Maybe someday.
Looks like there's plenty of stuff on YouTube to check out, and smarter guys have probably solved this with way less effort.
It just crossed my mind this way because I'm around THIS stuff.
« Last Edit: July 28, 2015, 09:07:26 am by SILVERGUN »
« Reply #5 on: July 28, 2015, 11:47:15 am »
Just for the record, I found out that the common 24VDC motor that we use in these has a top speed of 122RPM, so even though you could use the circuit, we would have to sub in a correct motor.
We only ever concern ourselves with IPM (inches per minute) as it relates to wire feed speed, so it was interesting for me to get a conversion to RPM.
I apologize for the tangent.
I do realize this was a very simple question about a very inexpensive control option.
Nothing simple or inexpensive about my idea.
« Last Edit: July 28, 2015, 01:08:22 pm by SILVERGUN »
« Reply #6 on: July 29, 2015, 01:13:33 am »
Hey SG, good to see you back.
I too have lost some interest in these gizmos, As I have another unit sitting in my shed waiting............................
to be housed. :icon_biggrin:
« Reply #7 on: July 29, 2015, 07:59:33 am »
THANKS TIMBOooo!
All of this talk and thought about this has me re-interested, and hopefully I'll eventually find the time.
Since I've wandered so far off the reservation, I'll keep going and just post one more thing that I found interesting...
This thing really caught my eye and might be a nice project,,,,right after the other 12 projects in line in front of it.
I've got a Celestion Neodynium magnet speaker that is super light that would probably work great for this application.
This type cabinet with a full speed control pedal would be incredible.
https://www.youtube.com/watch?v=bSzI40xV1wU
« Reply #8 on: July 30, 2015, 02:51:37 am »
MAN, why didn't I think of that. :l2:
