September 15, 2026, 10:58:15 pm
Hoffman Amps Forum image Author Topic: Dual 5Y3  (Read 7653 times)
Offline Mats
Dual 5Y3
« on: September 08, 2015, 09:39:22 am »
Hi
Im trying to get my schematics in order. I got to this one, Angela Super Singel-Ended.
My question here: Dual 5Y3 in a PSE amp ??
Perhaps its just a cool thing, with two rectifiers.
The schematic says, the PT is Fender Deluxe or equivalent.
Can that PT really handel two 5Y3 ?
/Mats
Re: Dual 5Y3
« Reply #1 on: September 08, 2015, 09:50:59 am »
5Y3 draws 2A, Deluxe/Reverbs use GZ34/5AR4 they draw 1.9A. Latter Deluxe? Reverb's used 5U4, 3A current draw.
So 2x5Y3=4A heater current draw. Even if the Fender PT had a 3A/5v heater that's still 1 amp short.
Why not just use a single GZ34? Just have to watch the B+ plate dcv. A single 5V4 (2A heater) will give less B+dcv than a GZ34. (Our host Doug sells a new 5V4 that's spot on for dcv compared to a NOS 5V4 for a very good price.)
Or Classic Tone might make a small PT that has enough 5v heater current and B+ current to run 2x5Y3's and 2x6V6's? SE 6V6 Champ's only draw ~40mA B+. So 2xParallel SE 6V6= ~80mA.
« Last Edit: September 08, 2015, 10:11:53 am by Willabe »
Re: Dual 5Y3
« Reply #2 on: September 08, 2015, 10:04:22 am »
If I paid $50 for a transformer that was rated for 5V@2A I definitely would not put a 4A load on it. I think the dual rectifiers are just show. I'd put a 5AR4 in it and move on.
Offline Mats
Re: Dual 5Y3
« Reply #3 on: September 08, 2015, 12:21:12 pm »
Hi
Thanks for answers.
Yes, 4A for dual 5Y3.
Thats, as you say, its just for show.
I wonder why they put it in there in the schematic ?
/Mats
Re: Dual 5Y3
« Reply #4 on: September 08, 2015, 01:53:20 pm »
Marketing?
I did a build that where I wanted "symmetry"  and the tube regulator made it "un-balanced"  so I took a bad octal, drilled out the base, stuck in and led and used it as a power indicator, walla, 2 tubes for balance
Re: Dual 5Y3
« Reply #5 on: September 08, 2015, 03:15:27 pm »
Having two rectifier tubes in parallel halves the resistance and modify the drop of voltage, so there is an increase in B+ level
may be the reason is this ?
« Last Edit: September 08, 2015, 03:18:10 pm by kagliostro »
Re: Dual 5Y3
« Reply #6 on: September 08, 2015, 04:42:38 pm »
again, quoting sluckey, just use a 5AR4 if that's the case.
Offline billcreller
  • 1934
Re: Dual 5Y3
« Reply #7 on: September 11, 2015, 08:28:22 pm »
What if I have a lot of 5Y3s & no 5AR4s ?
Re: Dual 5Y3
« Reply #8 on: September 11, 2015, 09:12:37 pm »
I didn't do the math tween tube cost and tranny but I'm thinking the tube looses, well, unless you have lots of dual 5Y3 trannies :icon_biggrin:
Offline foghornleghorn
Re: Dual 5Y3
« Reply #9 on: September 18, 2015, 12:58:06 pm »
I used two 5Y3GTs in a 4x6V6 amp with an AES tweed Bassman PT. So 3A 5V winding. It has not given any problems. I sold it a while ago to a pro player and have had no frantic phone calls about it since.
So I'd say a 3A winding is OK, but I wouldn't put two 5Y3s on a 2A winding, I think that's asking for trouble.
Offline Mats
Re: Dual 5Y3
« Reply #10 on: September 21, 2015, 11:20:16 am »
Hi
If 3A is OK for a up and running amp.
Perhaps the winding 5V 3A, of that PT is underrated a little
and can deal with the dual 5Y3 at 4A.
/Mats
