July 28, 2026, 09:00:09 am
Hoffman Amps Forum image Author Topic: 1959 Tweed Bassman Board Build  (Read 36791 times)
Re: 1959 Tweed Bassman Board Build
« Reply #50 on: October 21, 2015, 12:30:42 pm »
Ha! Wrong color. Why not just bolt it down and hook it up?
« Reply #51 on: October 21, 2015, 04:07:05 pm »
I tried so bad to find the light blue one but no luck. Most of them on Ebay are too big as well. The other orange ones are pretty small  (penny size).
I am am not sure what they are rated at either. I have like a 58VAC bias tap. Educate me on these rectifiers.
« Last Edit: October 21, 2015, 04:14:39 pm by plexi50 »
« Reply #52 on: October 21, 2015, 04:46:15 pm »
Can i use this orange one from the box?
« Reply #53 on: October 21, 2015, 07:34:12 pm »
It works! :worthy1:
« Reply #54 on: October 21, 2015, 08:07:15 pm »
I was just kidding. I left the selenium rectifier in my 5F10 just because it was working, but if it ever fails I'll replace it with a trusty 1N4007.
I never bought into the amp forums' chatter about toxic poisons associated with selenium. I've worked with selenium rectifiers all my life, some as big as gallon paint cans. I respect the fact that they are poisonous but I don't intend to eat one or smoke one. I don't chew on lead or sip antifreeze either!   :icon_biggrin:
Back in the late '60s we used to occasionally pull a trick on the instructor in tech school. At the end of the day the circuit breakers for lights and work benches would be turned off. Someone would connect a SR across a tv cheater cord and plug it into a workbench outlet. Whoever turned the breakers on the next day got a strong rotten egg smell as the selenium rectifier smoked! We didn't know it was poison gas back then. No one ever suffered except for the foul smell. Well, there was that one time with Billy, be that was probably the mushrooms!   :laugh:
Anyhow, at least you know how to connect one properly. And if you ever smell rotten eggs, you'll know where to look.  :icon_biggrin:
« Reply #55 on: October 22, 2015, 08:42:40 am »
That a real good story! Man i don't want to smell that smell. I used to drill water well's in the early 1980's. The sulfur smell of rotten eggs is pretty bad at times. Depended on how much vegetation and such from the Dinosaur era there was.
I drilled Lion Country Safari's well in Palm Beach at 800'. I had someone with a shotgun keeping an eye out for lions while drilling in the field. Looking back i don't think i would do that again.
« Reply #56 on: October 22, 2015, 05:33:33 pm »
I couldn't resist buying these NOS 1958 CBS 5881 tubes. I feel like i am paying alimony to my 5F6A amp.
« Last Edit: October 22, 2015, 05:37:02 pm by plexi50 »
« Reply #57 on: October 22, 2015, 06:13:26 pm »
CBS made tubes, so I assume they made those. But aside from the label, those look 100% like 50's Tung Sol 5881's.
« Reply #58 on: October 22, 2015, 07:48:28 pm »
Yes they sure do HBP. And maybe a tad more robust. But what turns me on is the script on the box:
A Division Of Columbia Broadcasting System Inc. Guaranteed 1000 year usage! Ha!
Edit: I ran across a tube store that has these same tubes and are advertised as being made by Tungsol.
« Last Edit: November 04, 2015, 09:11:34 am by plexi50 »
« Reply #59 on: October 31, 2015, 12:26:15 pm »
I am going to try a NOS RCA GZ34 i just bought and compare voltages with the NOS CBS 5U4GB i have in the amp now.
I looked at cheaper tubes but i just have this thing for vintage real tubes made of stronger metal than they use today.
Welded plates vs Stapled plates as well.
Online Willabe
« Reply #60 on: October 31, 2015, 12:49:26 pm »
Oh you have an RCA GZ34, nice!     :icon_biggrin:
« Reply #61 on: October 31, 2015, 01:47:38 pm »
Not yet. Just paid for it. Looks nice
« Reply #62 on: October 31, 2015, 05:07:17 pm »
They want money for those.
I have been able to get NOS RCA 5V4A tubes for under $10 each. No, it ain't a GZ34.  It ain't $50 either for a dumb rectifier. But it's a robust tube w/indirect heating and the later ones, the ones that are NOT shaped like bowling pins but same envelope as RCA 6L6GC: straightsided but with that slightly rounded top. Those are nice tubes.
« Reply #63 on: October 31, 2015, 05:16:09 pm »
Power transformer from a 1962 Wurlitzer Organ. 360-0-360. ... I was shooting for 325-0-325 for the original Tweed Bassman B+ of 400 VDC on the power tube plates. ...
I believe you'll have over 450vdc loaded, and a tad over 500vdc unloaded.
Yeah i know it's not the right PT for this.
I am just going to spring out in the morning,load my visa and buy the right PT for it. I have come this far and i don't want to skimp and wind up with a Tweed Ampeg. The PT has been removed/
it'll sound better with the higher b÷.
« Reply #64 on: October 31, 2015, 06:44:12 pm »
The 5V4 is a fine tube. I used to have some of them. I am looking forward to hearing the amp with that GZ34.
I look at it and don't believe sometimes i actually built it with all the old parts i could find. And that they were all good parts.
I wanted to do it proud
Offline p2pAmps
    • p2pAmps
« Reply #65 on: November 01, 2015, 05:49:51 pm »
Amazing build, congrads
Everything Affects Everything
« Reply #66 on: November 01, 2015, 06:38:25 pm »
Thanks much mscaggs. Cant wait to get the tweed head cab being made by John Mergili
« Last Edit: November 01, 2015, 06:45:13 pm by plexi50 »
« Reply #67 on: November 01, 2015, 09:41:17 pm »
I am going to try a NOS RCA GZ34 i just bought ...
RCA box & label, but that's a Mullard GZ34; again 100%.
The plate structure, "Made in Great Britain" label, hole in the guide post and 2-line code in faint gray on the glass (above the "RCA Electron Tube" on the base) confirm it's a Mullard GZ34. Hard to see, but the 1st character in the upper line of that code looks like a "B" which indicates Mulard's Blackburn plant.
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« Reply #68 on: November 01, 2015, 10:47:45 pm »
Bravo !!  :bravo1:
https://soundcloud.com/ukiuki
« Reply #69 on: November 02, 2015, 05:20:58 am »
I have had a lot on my plate lately (not tube related) and didn't even notice the hole in the guide pin and BK Mullard script before i purchsed it. I stole that tube for $125.00 + $5.95 ship. Thanks for noticing all that HBP.
« Reply #70 on: November 02, 2015, 06:25:29 am »
... didn't even notice the ... BK Mullard script ...
The "BK" on the tube base is RCA's date code. Look on the glass above the "A" in "RCA" for a faint code, 2-lines made of ~3 characters per line. The 1st character in the top line is probably a "B".
« Reply #71 on: November 02, 2015, 08:17:33 am »
What is the big deal with the GZ34 Mullard?  The metal base ones bring insane money.  I have a a few around.  One has Heath on it another Amperex and a couple of RCA's as well.  I have heard they are very durable, but is there some other reason they are in great demand?
« Reply #72 on: November 02, 2015, 09:13:25 am »
I wonder why they are so expensive as well. No answers from me. I can now see the faint digits HBP
Online Willabe
« Reply #73 on: November 02, 2015, 09:39:40 am »
1 reason is the Hi-Fi guy's love them.
« Reply #74 on: November 02, 2015, 05:16:28 pm »
What is the big deal with the GZ34 Mullard?  ...  I have a a few around.  One has Heath on it another Amperex and a couple of RCA's as well. ...
A number of sources talked them up as the ultimate GZ34 (Mullard, as well as Amperex/Philips in general).
I have a few as well, never used them in anything.  To me, a rectifier with a larger voltage drop makes more sense in a tube amp where you want rectifier-sag or rectifier-sound...
« Reply #75 on: November 02, 2015, 05:37:33 pm »
I wonder what the date code will be. I will have it here Wednesday.
« Last Edit: November 02, 2015, 08:49:54 pm by plexi50 »
« Reply #76 on: November 02, 2015, 06:18:14 pm »
I am wonder what the date code will be. I will have it here Wednesday.
From a probably-reliable source, Feb 1967.  The Philips factory codes I pointed you towards on the glass carry their own date code, and could be used to corroborate the RCA-brand date code.
« Reply #77 on: November 02, 2015, 08:55:20 pm »
Yes i found that source info as well earlier tonight and saw RCA's secret code. BK Philips to reflect Feb 1967.
I think i can see The letter F ? B 2 but it is clearly eye ball guessing from the faded angle of the picture.
« Last Edit: November 02, 2015, 08:57:48 pm by plexi50 »
Offline uki
    • Uki's Guitar Trip
« Reply #78 on: November 02, 2015, 09:44:50 pm »
Wow this is an amazing work ! :bravo1:
« Reply #79 on: November 03, 2015, 07:45:24 am »
Thankyou uki.
« Reply #80 on: November 04, 2015, 11:39:01 am »
Received 5AR4 / GZ34 this morning. Pin#4 dead. No filament or emissions. Bummed out. D*m! :cussing:
« Reply #81 on: November 04, 2015, 09:37:22 pm »
Refund for DOA? (I hope)
« Reply #82 on: November 04, 2015, 10:37:52 pm »
if you want it, i have a used GE 5AR4 with plenty of life left. 35bux + postage. last used one i have.
« Reply #83 on: November 05, 2015, 07:33:01 am »
The seller says they have more NOS 5AR4 tubes and will do an exchange. I sent the bad one back yesterday.
Thanks DummyLoad i may take you up on that offer.
« Reply #84 on: November 08, 2015, 10:48:11 am »
Got a refund on the DOA RCA GZ34. Decided to grab this Amperex Bugle BOY GZ34 while i could.
Steve i found the powder blue Selenium rectifier. 1961 Date.  :icon_biggrin:
« Last Edit: November 08, 2015, 10:53:22 am by plexi50 »
« Reply #85 on: November 08, 2015, 11:04:09 am »
Great! I heard that most of the Bassman magic is inside that rectifier. Don't let the stink out!
« Reply #86 on: November 08, 2015, 11:09:40 am »
Ha!!! What if i put a moth ball next to it?  :l2:
« Last Edit: November 08, 2015, 11:16:37 am by plexi50 »
« Reply #87 on: November 08, 2015, 11:16:15 am »
Ha!!! What if i were to put a moth ball next to it?
Moth balls are easier to chew than selenium rectifiers. I loved that smell when I was a kid!  :icon_biggrin:
« Reply #88 on: November 08, 2015, 11:20:36 am »
Moth balls did have a strange smell . If you sniffed to hard it would make your eyes water. Never sorted a moth ball.
Maybe that's the next craze we will here about in the news.
« Reply #89 on: November 12, 2015, 04:24:36 pm »
I received the Amperex GZ34 this morning. The code from what i can see is,
1 07
f33
LOD
My B+ is now 425VDC  (edit: (430 VDC) and bias grid is -48.5VDC. The amp does sound good with the plate voltage up from 408 VDC.
« Last Edit: November 29, 2015, 12:32:47 am by plexi50 »
Online Willabe
« Reply #90 on: November 12, 2015, 04:29:56 pm »
 :icon_biggrin:
« Reply #91 on: November 12, 2015, 07:59:45 pm »
f33
LOD
That "L" is almost certainly a right-triangle. The right-triangle indicates Amperex's Heerlen, Holland factory.
« Reply #92 on: November 12, 2015, 08:35:46 pm »
f33
LOD
I am using magnifier lens and still cant see it all that good. This is the best pic i can get of it. Very difficult.
« Last Edit: November 12, 2015, 08:41:25 pm by plexi50 »
« Reply #93 on: November 21, 2015, 01:45:20 pm »
Received the Tweed Head cabinet this afternoon. Just beautiful Craftsman ship. I had no trouble getting the holes marked and drilled for the screws. Of all things, i forgot i don't have any power cord retainers.
The Peavey 410 cab doesn't look so nice in comparison.
John Mergili sure does nice cabinet work. :worthy1:
« Last Edit: November 21, 2015, 01:51:15 pm by plexi50 »
« Reply #94 on: November 21, 2015, 01:48:20 pm »
Wood knots!
« Reply #95 on: November 28, 2015, 11:13:16 pm »
Dam this amp sounds incredible! Not to brag but man this thing is different than just another amp build for me. I have had several people play it and it is exceptional. I suppose that 4 ohm OT has it under control.
2 Ohm is loud but tone suffers. 4 Ohm has less bass and mid's but tone is greatly improved from what i have read online with a 4 ohm OT.
Of course this was a Hi-Fi thread i got this info from. Got the 5F6A Bassman tube chart and early 60's power cord retainer for it.
I'm in awe of having actually built it with all the NOS parts i have been able to find.
I will do a sound clip of it soon. More than a keeper.
« Last Edit: November 28, 2015, 11:16:02 pm by plexi50 »
« Reply #96 on: November 29, 2015, 12:10:30 am »
excellent workmanship.  :icon_biggrin:
« Reply #97 on: November 29, 2015, 12:29:48 am »
I found a 1959 8087 power tranformer in a 1960 6G6 Blonde Bassman i worked on 2 week ago. I was drooling. Real early 6G6.
Never expected to see one in anything other than a Tweed Bassman. Pic of it/
Look at the circle on the transformer with the (T) inside of the triangle. It measured 380-0-380 VAC/
« Last Edit: November 29, 2015, 12:34:05 am by plexi50 »
