September 15, 2026, 02:30:58 am
Hoffman Amps Forum image Author Topic: Hoffman Tweed Princeton #001  (Read 8057 times)
Offline p2pAmps
    • p2pAmps
« on: September 24, 2015, 04:56:49 am »
Parts came in yesterday (thanks Doug) So I knocked this one out for a friend.  Pretty cool amp...
Everything Affects Everything
Re: Hoffman Tweed Princeton #001
« Reply #1 on: September 24, 2015, 06:33:14 am »
Looks good Mike!
Offline p2pAmps
    • p2pAmps
« Reply #2 on: September 24, 2015, 07:56:40 am »
Looks good Mike!
Hey thanks Doug...
Offline Fresh_Start
  • noob de Lux
« Reply #3 on: September 24, 2015, 08:12:27 am »
With a nice 10" alnico speaker that is a really fun amp to play.
What transformers did you use?
What voltage on plate of 6V6?
I ask because I had to work to get voltages down to 5F2 levels.  It was worth the effort since I wanted that warm tweedy sound and feel. So was an extra filter cap and choke before the power tube plate node.
Cheers,
Chip
P.S. A small thing but a log taper volume pot instead of linear taper would be a big improvement.
Quote from: jjasilli
Quote from: PRR
Offline p2pAmps
    • p2pAmps
« Reply #4 on: September 24, 2015, 08:23:29 am »
Cheers,
Chip
Hi Chip,
Right now I am looking at 370 on the plates...  The trannies are Heyboers.
Thanks for the tip
Offline p2pAmps
    • p2pAmps
« Reply #5 on: September 24, 2015, 08:54:28 am »
So does anyone think a 12" would totally suck in one of these amps?
« Reply #6 on: September 24, 2015, 10:48:18 am »
Almost like the Flintstones compared to your neat little Princeton Reverbs.
Offline Fresh_Start
  • noob de Lux
« Reply #7 on: September 24, 2015, 09:02:22 pm »
No, it wouldn't suck. Just need a bigger cab.  However, there isn't enough wattage to really push any 12" speaker I can think of.
IIRC for a brief period on the '50s, Fender put the 5F2A circuit in a cab with a 10" speaker and called it a "Harvard".  I can tell you that a Weber 10A100 is a great match for this circuit. "Warm, crunchy, early breakup. Compressed /fattened at high volume."  Sounds about right. Ted recommended light dope If I remember right (sorry he's gone).
Cheers,
Chip
P.S.  Should've started with "Another really nice, clean build."
One lead dress question - it looks like the junction of the two 68K resistors with the shielded wire going to the first triode grid is unsupported. Is there a turret under there not shown in the photo?
« Last Edit: September 24, 2015, 09:10:03 pm by Fresh_Start »
Quote from: PRR
« Reply #8 on: September 24, 2015, 09:28:51 pm »
Celestion Vox blue, 12"/15w.  :icon_biggrin:
« Reply #9 on: September 24, 2015, 09:48:07 pm »
Although it does not matter one iota, by custom, the red OT wire should go to the B+ and the blue should go to the plate of the output tube.
« Reply #10 on: September 24, 2015, 10:51:05 pm »
Except when it squeals.
Offline p2pAmps
    • p2pAmps
« Reply #11 on: September 25, 2015, 05:38:37 am »
And boy did it squeal!
Offline p2pAmps
    • p2pAmps
« Reply #12 on: September 25, 2015, 05:42:14 am »
I use shielded cab for the input tied to the 2 68K resistors.  Yes there are not turrets for that but I have honestly never had a problem.  I know Marshalls and some other tie the 68Ks to the board but never have seen it on any Fender yet.  So far it works for me.  Good eye...
« Last Edit: September 25, 2015, 07:30:15 am by EL34 »
« Reply #13 on: September 25, 2015, 07:32:37 am »
That should not be a problem.
Those 68k carbons in that config are pretty stout
