September 17, 2026, 10:41:42 pm
Hoffman Amps Forum image Author Topic: Got a free Tektronix 2445A 150MHz 4 channel scope  (Read 7081 times)
« on: September 25, 2015, 08:17:34 pm »
A friend just gave me a Tektronix 2445A 150MHz 4 channel scope with a high voltage probe. Looks to be in good shape.  :icon_biggrin:
Is this a good scope for tube amps? Anybody familiar with this scope?
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
Re: Got a free Tektronix 2445A 150MHz 4 channel scope
« Reply #1 on: September 26, 2015, 01:16:44 am »
From what I understand any scope in the 50MHz range is fine.  I just bought a Rigol DS1054Z because it gets rave reviews for having 4 channels and 50MHz.  The audio range of most guitar amps is like 10Hz to maybe 20kHz.  So 50MHz is well within range.
~Phil
Phil Davis
tUber Nerd =|D
Offline vibrolax
  • In a vacuum tube, no one can hear you scream
    • Jon's Homepage - DIY vacuum tube guitar amps, pro audio, original music.
« Reply #2 on: September 26, 2015, 06:22:07 pm »
I'm not familiar with that particular scope, but it is more than perfect (as long as you have a 10x probe) for working on any kind of audio gear.  You received a great gift.  My everyday scope is a 15 MHz Leader LBO-514, though I do have a Tektronix 556 (100 lbs, 44 tubes, 800W).  Oh, here's a picture of one stack of my test equipment when I was moving it earlier this year.
Jon
« Reply #3 on: September 26, 2015, 06:47:08 pm »
Nice looking stack of test gear.  :icon_biggrin:
Yes it came with a 10x probe.
A friend from church is coming over this week to show me how to use it.
    • Daviszone
« Reply #4 on: September 26, 2015, 08:25:34 pm »
I was under the impression that a 10x scope probes can't take over 300v and guitar amps regularly go up to 500 or 600 in some cases.  I bought a few 100x scope probes so that I can go higher.  Anyone want to confirm that for me?
Phil Davis
tUber Nerd =|D
Offline vibrolax
« Reply #5 on: September 26, 2015, 08:41:05 pm »
I don't know for a fact. My lbo-514a label on the bnc input says 600V max.  My tek p6103 says it's good to 500v.   The voltage ratings for your probes should be on the data sheet.
Jon
« Reply #6 on: September 26, 2015, 10:39:06 pm »
The 2445 Max input voltage is 400V (dc + peak ac) or 800 V pp ac @ 10KHz or less.
Here's the operators instruction manual. You can probably find a service manual also.
     http://www.mit.edu/~jhawk/tek2445.pdf
« Reply #7 on: September 26, 2015, 11:14:33 pm »
Voltage rating on probes depends more on the caps they use than the X-factor.
Since 'scopes don't need more than a Volt to get a full picture, 100X probes may be useful for a 'scope which has little turn-down for large inputs.
Note that the OT plate leads of a 400V DC amp will kick to 700V-800V.
In many practical cases, you do not need a precision probe. 10Meg and 100K gives 100X reduction, stands high voltage, and uncompensated bandwidth is beyond the audio band.
IMHO 1MHz is more than ample for 99.44% of guitar-amp work. 100KHz is often fine. I have used a 19KHz 'scope and learned stuff. With the transistorization of 'scopes, you can't hardly find anything under 5MHz. Bandwidth is a non-feature. Easy controls may be far more useful.
