August 29, 2026, 02:05:02 pm
Hoffman Amps Forum image Author Topic: Stereo guitar preamp  (Read 5854 times)
Offline Toxophilite
« on: October 28, 2015, 02:19:26 am »
So I've been ogling Hoffmans stereo guitar pre.
It uses more tubes than I would imagine seems to have 4 gain stages per channel with a bassman 5F6-a-like cathode follower tone control
I was curious as to the rational as even the bassman only seems to use 3 gain stages :dontknow:
Can someone explain it? Is it simply a matter of more gain?
Looks neat though
I might try something simpler though as I like to have a straight in guitar pre for recording late at night(in my apartment)
I've built several of these and used to use one all the time for quiet recording:
http://www.beyondsanityproductions.com/index.php?option=com_content&view=article&id=13:akai-roberts-preamp-mods&catid=18:diy-articles&Itemid=28
Which gives you two preamp channels , with one feeding into a SE amp
It was easy for me as there was essentially a cookbook like recipe for me to follow
Has anyone built one of these? they're useful. I sold my last one
Because of the time I spent here I think I could get the 12ax7 channel on one of these a little hotter which would be cool
However I think a Hoffman like standalone stereo pre would be even more useful and fun to build
Have to find or make an appropriate chassis
I have several PTs which might be appropriate I wonder how skookum they would have to be??
 I see my unit as basically running 2 12ax7 ( 2 Ab763 preamps)
Next I'd have to build a revibe!!..it never ends!! :icon_biggrin:
« Last Edit: October 28, 2015, 04:07:25 am by Toxophilite »
Re: Stereo guitar preamp
« Reply #1 on: October 28, 2015, 06:20:15 am »
You should link to the documents on my library page so the guys know what you are referring to
here's the link to the schematic
http://el34world.com/projects/images/stereopreampschematic.gif
My tube pre amp is just the pre amp out of a Marshall type amp and it has the same tone controls
V1B and V3B are just there so you could try and get less clean sound in the pre amp if you want thatVolume pots up - Master down
Or not, Volume pots down -  Master up to get a cleaner tone
On the PT, I already stock the PT I used on that project and the Re-Vibe
It's the Mojo779 on this page
http://hoffmanamps.com/MyStore/catalog/TransformersMobile.htm
« Last Edit: October 28, 2015, 06:28:36 am by EL34 »
« Reply #2 on: October 28, 2015, 08:45:45 am »
Your counting cathode followers (CF) as a gain stage. They are not.
Offline Toxophilite
« Reply #3 on: October 28, 2015, 10:12:06 am »
Right, sorry about that
Thanks for answering those questions
I'm completely unfamiliar with Marshall schematics, being a newbie, though I did know they came from the same source
I quite like the whole stereo pre and revibe combination you made!
THanks again!
« Reply #4 on: October 28, 2015, 10:17:47 am »
Offline Toxophilite
« Reply #5 on: October 28, 2015, 10:31:46 am »
Cool, and thanks
I'll check those out, i was looking at the 18 watt at one point but for my first few builds I've been pretty Fender-centric .
