September 14, 2026, 03:51:36 am
Hoffman Amps Forum image Author Topic: 1st 5E3 build dead short problem  (Read 7347 times)
Offline Skip Hagey
« on: October 29, 2015, 04:00:12 pm »
AAArrgghh!  After my first power up of my first scratch 5E3 build, Dougs version, I have a dead short that I simply cannot find. I've checked and rechecked found some errors and corrected them, I think, but still have the short.  Hooked up to a spkr, I get an initial hum immediately and then as the caps start to charge, the light comes on on my circuit protection.  Then she really starts to hum!  Could someone give me some ideas where to look, I've run out of my own?! I'm sure it's probably something staring me in the face but I can't see it!  I do find I have trouble with the orientation of the  input jack and vol/tone control wiring diagrams, but i've tried them in more than one configuration w no luck.  Thanx, Skip :BangHead:
Re: 1st 5E3 build dead short problem
« Reply #1 on: October 29, 2015, 04:51:26 pm »
Did you read ALL the pages Doug wrote/drew out on his 5E3? Link below;
http://el34world.com/schematics.htm#Hoffman_5E3_Tweed_Deluxe_
I don't know how your double checking your build, but this is a great way to double check it;
http://el34world.com/Forum/index.php?topic=17701.0
« Reply #2 on: October 29, 2015, 11:41:20 pm »
Go over your diagram with a bright light on the build and a yellow-marker to keep track. (This is probably Willabe's link.)
But first: it is OK until the tubes warm up. Pull the tubes. Actually, the small tubes are almost never able to suck enuff to light a light, pull your rectifier and power bottle(s). Does it still short? Put them back one at a time (rect first).
« Reply #3 on: October 30, 2015, 06:28:10 am »
As the others have requested
Do this first and then let us know
Offline p2pAmps
    • p2pAmps
« Reply #4 on: October 30, 2015, 07:02:04 am »
I had this happen on a Bassman I rebuilt and it was a bad bias pot.  I basically did'nt have any bias so as the tubes warmed up the amps started climbing rather fast...
Everything Affects Everything
Offline Skip Hagey
« Reply #5 on: November 04, 2015, 03:08:16 pm »
 :icon_biggrin: I'd like to thank all you who took the time to respond and let you know that all this time it was a bad output tube!  Go figure. I don't have a tube tester so assuming all tubes are good doesn't really pay off!  I still have issues like the normal channel works but the bright one doesn't.  I think i'll be able to figure that out though.  this thing is quiet as a mouse and does sound good, but a little bass heavy.  I'm running into a 2 by 12 running 4 ohms.  my wife is sleeping right now so I haven't opened it up yet...can't wait.  thanks again guys, i'll post some pics soon....
{EDIT- fixed munged icon -- PRR}
« Last Edit: November 04, 2015, 05:54:25 pm by PRR »
« Reply #6 on: November 04, 2015, 09:01:49 pm »
....  this thing ... does sound good, but a little bass heavy.
That's normal unless you're plugged into the Bright channel and turn the Tone control up.
Some players reduce the value of the coupling below 0.1uF (to 0.047uF or 0.022uF) to reduce bass.
Offline Skip Hagey
« Reply #7 on: November 05, 2015, 07:18:38 am »
Thanks, that's my next task, trying different coupling values.  So many variables...!
Offline Skip Hagey
« Reply #8 on: November 13, 2015, 11:07:19 am »
So I've had two Tung sol 6v6 tubes short out with this new 5E3 build...are these tubes just inferior or as it possible I have another problem.  I have some NOS 6
v6's that seem to work fine..at least for now.  Maybe the plate voltage is to high for these tubes and if so what would you suggest?  Thanks...
« Reply #9 on: November 13, 2015, 11:24:29 am »
What is your plate dcv? What is the PT your using?
Offline Skip Hagey
« Reply #10 on: November 13, 2015, 11:42:00 am »
5.8 and 6.1 @ pin 3, PT is the one Doug provides for his circuit.  Ahhh...DC voltages are 322.2 and 321.8
« Last Edit: November 13, 2015, 11:47:06 am by Skip Hagey »
« Reply #11 on: November 13, 2015, 12:13:40 pm »
What is the DC voltage on pin 4, 5, and 8 of each 6V6?
Offline Skip Hagey
« Reply #12 on: November 13, 2015, 12:20:19 pm »
1st.  pin 4=286.9, pin 5=4.0, pin 8=17.9.  2nd,  pin 4 287.8, pin 5=4.6, pin 8=17.9
« Reply #13 on: November 13, 2015, 12:25:09 pm »
Pin 5 should be zero volts. Recheck those pins again please.
Offline Skip Hagey
« Reply #14 on: November 13, 2015, 01:17:20 pm »
yeah, the meter was all over the place so I took an average of the readings...and the readings were in mv's so .004
« Reply #15 on: November 13, 2015, 01:27:21 pm »
None of those voltage readings would put any stress on a good 6V6. Maybe you've just been unlucky? Try some JJs if you have them.
Offline Skip Hagey
« Reply #16 on: November 13, 2015, 01:44:32 pm »
Thanks, i've since read that the tung-sols don't tolerate higher voltages and that hte JJ's or the EH new releases are more tolerant... I'll have to order some!
« Reply #17 on: November 13, 2015, 01:52:14 pm »
I wouldn't consider 325V as high for any 6V6.
