July 29, 2026, 08:48:39 pm
Hoffman Amps Forum image Author Topic: PR #3  (Read 12851 times)
Offline p2pAmps
    • p2pAmps
PR #3
« on: November 08, 2015, 05:11:22 pm »
I almost hate to keep posting the Princetons I am building but maybe the pictures will help anyone doing their first one.  This one is in progress...
http://p2pamps.com/ml/
Everything Affects Everything
Re: PR #3
« Reply #1 on: November 08, 2015, 05:45:44 pm »
Looks good. Got one hand tied behind your back?  :wink:
Offline p2pAmps
    • p2pAmps
Re: PR #3
« Reply #2 on: November 08, 2015, 05:53:38 pm »
Ha!  Nah, my hand is feeling much better so I'm back at it.  Got this PR to build, and a 70s Twin to service and blackface up...  I'm also expecting my 5e3 cabinet soon so I can fire that up...  OH yeah, there's my day job somewhere in there LOL
Re: PR #3
« Reply #3 on: November 08, 2015, 06:39:49 pm »
Looks good
One word on the reverb tank board
Hopefully it does not start feeding back
The cardboard may have been used as a dampener, just like the soft vinyl bag is used
Have to wait and see on that one  :icon_biggrin:
I have had many a tank that starts to feedback and then grows and grows on the resulting cabinet vibrations
Offline p2pAmps
    • p2pAmps
Re: PR #3
« Reply #4 on: November 08, 2015, 07:22:16 pm »
Looks good
That logic does seem right except I spent some time with my first one trying different materials just to see the results.  No baffle was bad, reverb was in and out and kinda acted crazy.  Cardboard was ok,  Foam was ok, indoor/outdoor carpet ok.  I finally decided to use the 1/4" as it was easy to attach the tank and looked to be the strongest of them all.  I know, how strong does it really need to be?  Well, since I have plenty of 1/4" around to shop I used it...
Re: PR #3
« Reply #5 on: November 09, 2015, 06:15:25 am »
And by the way, DO keep posting your PR builds  :icon_biggrin:
Offline p2pAmps
    • p2pAmps
Re: PR #3
« Reply #6 on: November 09, 2015, 07:16:53 am »
Ok, Doug.  I just didn't want to bore everyone with the same ole stuff...
Offline p2pAmps
    • p2pAmps
Re: PR #3
« Reply #7 on: November 09, 2015, 07:32:02 am »
Ok, so here is something the guys here on this forum taught me.  I wanted to slow down my tremolo and also get more intensity.  Worked great for me.  The 220K replaced a 1M resistor.  I also tried a 470K but ended up liking the 220K better.
Re: PR #3
« Reply #8 on: November 09, 2015, 01:37:59 pm »
COOL  :icon_biggrin:
Re: PR #3
« Reply #9 on: November 09, 2015, 09:49:34 pm »
Yes. The .022 really get a nice hold of usable (Sane) tremelo.  I love Princetons. Got a real 64 here 3 years ago for $100.00 that was painted blue & pink. Go figure. My friend just pulled his baffle board and put in a 12" 1962 Jensen P12Q. I haven't heard it yet cause i have been busy with other things. He has it miked and he claims it is on par or better than his 1969 Deluxe reverb/
« Last Edit: November 09, 2015, 10:02:06 pm by plexi50 »
Offline p2pAmps
    • p2pAmps
Re: PR #3
« Reply #10 on: November 13, 2015, 05:17:00 am »
« Last Edit: November 13, 2015, 05:26:28 am by mscaggs »
Re: PR #3
« Reply #11 on: November 13, 2015, 10:04:22 am »
Alright, now you are just showing off. :icon_biggrin:
Looks like you got some teflon tubing.  McMaster-Carr?
Offline p2pAmps
    • p2pAmps
Re: PR #3
« Reply #12 on: November 13, 2015, 10:21:12 am »
The Teflon spaghetti tubing is from evilbay  :dontknow:
Re: PR #3
« Reply #13 on: November 13, 2015, 10:25:06 am »
You've become a PR factory!
Nice work.
Offline p2pAmps
    • p2pAmps
Re: PR #3
« Reply #14 on: November 13, 2015, 10:26:27 am »
Nice work.
Man I hope not...  Nothing worse than turning a hobby into a job to suck the fun right out of it.
Offline Paul1453
Re: PR #3
« Reply #15 on: November 18, 2015, 10:02:46 am »
Your work is so meticulous and clean, very impressive.   :worthy1:
I really don't see much of this type of craftsmanship.
Some old Govt lab gear from the 40's or 50's had good build quality.
But your work is on a whole different level.   :worthy1:
Offline p2pAmps
    • p2pAmps
Re: PR #3
« Reply #16 on: November 18, 2015, 02:16:46 pm »
Well that was a pretty nice thing to say, thank you...
Offline Paul1453
Re: PR #3
« Reply #17 on: November 18, 2015, 06:37:34 pm »
Your labor of love clearly shows in your workmanship.
Please don't ever let this become a job where you need pump it out in pursuit of another $.
It almost appears that when you have this all hooked up and powered on on your bench,
that you could accidentally spill a bin of washers in there and come out unscathed.   :blob8:
If you have some experience, you know when you are witnessing an exceptional performance.
If someone wants to see what a quality amp build looks like, I will point them to your pictures.
Keep up the good work!   :icon_biggrin:
Offline p2pAmps
    • p2pAmps
Re: PR #3
« Reply #18 on: November 18, 2015, 07:05:14 pm »
Thanks again for all your very kind words...
Offline 6v6Pin1
Re: PR #3
« Reply #19 on: November 18, 2015, 09:15:47 pm »
What is the red coloring on the fasteners and also something similar on the solder connections? What is it and why do you add it? I think it looks cool, but is there a functional reason too? Thanks.
Offline Paul1453
Re: PR #3
« Reply #20 on: November 19, 2015, 12:45:38 am »
I don't see any fasteners?  Turrets??   I see a little flux residue on some of the solder joints.  I am sure with the quality workmanship displayed so far, he will clean any of that excess flux residue off with a solvent before he deems his build complete.  Most others don't bother to clean that off.  It helps make a good, clean and shiny and not cold, solder joint.
Offline p2pAmps
    • p2pAmps
Re: PR #3
« Reply #21 on: November 19, 2015, 05:36:19 am »
The red stuff is called Dykem.  It is a red lacquer of sorts.  It is my own way of doing a QA at the end of the build to make sure I didn't miss a solder joint.  Also, when and if the amp sells and someone brings it in for a repair I can se if my work had been disturbed.  Other than that I don't think it serves any purpose what so ever.
Offline p2pAmps
    • p2pAmps
Re: PR #3
« Reply #22 on: November 19, 2015, 05:41:05 am »
The flux will most certainly get cleaned up at the end...
Re: PR #3
« Reply #23 on: November 19, 2015, 06:36:54 pm »
Historically: Alice soldered the radio and Betty inspected it, marking approved points with red nailpolish (or Dychem). If Betty got called away and Carol took over, Carol could see what Betty did or missed. Dave could spot-check production inspection by looking for the red dots.
You see it in LOTS of old gear.
mscaggs may not have a large staff cross-checking each other, but he knows it is a good idea.
Offline Paul1453
Re: PR #3
« Reply #24 on: November 19, 2015, 07:16:26 pm »
If you ever get a chance to closely inspect any ultra-light aircraft engine and control mechanisms you will often times see the same type of (locktite/Dychem/nail polish) markings.
It helps to quickly identify if any of your critical components have vibrated or broken loose somehow.
Something you definitely want to discover before taking to the air. :icon_biggrin:
Re: PR #3
« Reply #25 on: November 19, 2015, 09:29:41 pm »
Hiwatt used to do the same in guitar amps.
Offline p2pAmps
    • p2pAmps
Re: PR #3
« Reply #26 on: December 06, 2015, 06:13:11 am »
All done and shipped.  I built this amp for an old band mate (Mike) in a group I played in out in Northern CA called Silver Creek.  Man did we have fun!  On one hand I miss those days, on the other hand I'm sure glad I'm not playing till 2am anymore :)
« Last Edit: December 06, 2015, 06:18:10 am by mscaggs »
Offline bnwitt
  • Crankin' out the tone.
Re: PR #3
« Reply #27 on: December 06, 2015, 09:08:24 am »
Nice work indeed.  And thanks to Hot Blue Plates and Doug for making the Hoffman PR a reality!  Such a nice layout to work with.
Re: PR #3
« Reply #28 on: December 06, 2015, 09:25:32 am »
You did the lion's share of the work to make the layout drawings palatable! I felt like I just got the ball rolling back then.
Offline p2pAmps
    • p2pAmps
Re: PR #3
« Reply #29 on: December 06, 2015, 09:26:32 am »
Well, who ever did what is appreciated by many I' m sure....  Thanks guys, love me some PR
Offline bnwitt
Re: PR #3
« Reply #30 on: December 06, 2015, 09:46:52 am »
HBP you're being modest.  You were the brains behind the project, I threw in some mistakes on the layout :l2:  And then Doug and Sluckey made it all correct.
