September 18, 2026, 07:42:51 am
Hoffman Amps Forum image Author Topic: What kinds of things blows fuses?  (Read 6225 times)
Offline TerryD
« on: November 09, 2015, 06:56:40 am »
There is a 100 watt 1971 fender bassman head that I want to sell for a fellow in town.  It's pretty beat up.  It's blowing fuses.  What things do that?  Could plugging it in without being hooked up to speakers do that?  Thanks, Terry
Re: What kinds of things blows fuses?
« Reply #1 on: November 09, 2015, 07:04:42 am »
Excessive current draw blows fuses. That's it.
The challenge is finding the thing that pulls excessive current. "No speakers" doesn't do that typically; that's an issue of potential voltage spikes in the output transformer, and usually just kills the OT.
There is a 100 watt 1971 fender bassman head ...  It's blowing fuses.  ...
When? When it is turned on? When you play it? When you dunk it under water?
« Last Edit: November 09, 2015, 05:06:01 pm by HotBluePlates »
« Reply #2 on: November 09, 2015, 07:17:40 am »
When does it blow the fuse?
Flipping only the power switch on?
Flipping the standby switch on after power switch is on?
Offline Paul1453
« Reply #3 on: November 09, 2015, 07:34:44 am »
You want to sell for a fellow?  In it's current fuse blowing state it will not fetch much of a price, and certainly is not of much value to this fellow.  Maybe you want to BUY this from the fellow and then fix it for yourself.  Ask him if he'd take $20 for it.  No, how about $30?  You might get yourself a deal.
Offline TerryD
« Reply #4 on: November 09, 2015, 09:52:52 am »
Thanks.  I was hoping to give him 200 and sell for 400 but apparently "It was just my imagination....once again"
Terry
« Reply #5 on: November 09, 2015, 10:11:16 am »
FROM GEOFEX.COM . Tube Amp Debug page:
Fuses blow quickly for massive overloads, like AC shorts to a grounded chassis. They blow with a some time lag - maybe only a second or two, up to minutes, as the overcurrent gets closer to the fuse's actual rating. Anything that uses enough power to cause the AC line current to exceed the rating of the fuse will eventually cause it to blow.
It is important to remember that a fuse NEVER blows without something else being wrong. It could be that:
« Reply #6 on: November 09, 2015, 10:38:49 am »
Paul1453 has the right idea. Try to buy it cheap.
The GEOFEX list jjasilli posted is the punch list.
The standard concern here is: If you know enough to fix this (it's fairly easy) then you shouldn't be asking the question. Please don't take my comment as an insult. It's a safety concern. The things that blow fuses are 99% of the time located in the highest power/voltage section of the amp.
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« Reply #7 on: November 09, 2015, 10:55:29 am »
remove the output tubes and power it on. if the fuse doesn't blow, replace the power tubes one is short.
P.S.: call me Alvin.
« Reply #8 on: November 09, 2015, 05:07:48 pm »
... apparently "It was just my imagination....once again"
Not blowing fuses now?
Offline TerryD
« Reply #9 on: November 09, 2015, 05:26:33 pm »
No. Getting 400 beaners as is.
