September 16, 2026, 09:01:21 pm
Hoffman Amps Forum image Author Topic: 12AX7 so many choices, how to pick?  (Read 36812 times)
Offline Papa Jim
« on: December 04, 2015, 01:05:35 pm »
Newbie question. Is there a any tips you can share when it comes to select 12AX7 or other tube when so many choices exist. Brands, NOS, and price. Also a ton of other tubes that will replace a 12AX7???? From what I have seen so far Electro-Harmonix is at the low end of price. Are they o.k.  Does it make a big difference in sound?
Offline Toxophilite
Re: 12AX7 so many choices, how to pick?
« Reply #1 on: December 04, 2015, 01:56:05 pm »
Regarding used tubes:
I would suggest that the biggest differences lie in condition of the particular tube (life left, strength, triodes balanced? , microphonic)
Some of the subs have more or less gain, some are special low noise versions for sensitive preamp applications
like the 7025 or the 12AD7
New tubes are probably mostly good. I've had what people consider to be cheap Chinese tubes sound just as good as strong tested vintage telefunkens, bugle boys or Mullards.
As far as sound goes, I guess I don't have dog ears, though I have been playing professionally on and off for 25 years, and I'm something of a recording engineer as well.
I have had pretty well all the most coveted 12AX7 come through my hands and I've tried most in my amps with little or no difference in sound.
I say get good strong tested and or new tubes...and practice your instrument :icon_biggrin:
IMHO You are the biggest influence on your sound, then your instrument, then your amp and speaker. Tubes come after all that, probably after your amps transformers,  if they have a discernible effect at all.
Many people hold a completely different view, I'm sure they will chime in as well.
It is fun to play around with tubes though!!
« Last Edit: December 04, 2015, 02:01:02 pm by Toxophilite »
Offline Papa Jim
« Reply #2 on: December 04, 2015, 02:16:30 pm »
Thanks. Kinda what I was thinking but just looking for some kind of verification. I plan on always buying new for sure. As far as price unless someone can convince me, I think I will just kinda get an average of the cost and then pay somewhere between it and the lowest priced ones. At least for right now that's what I'm thinking.  As long as we're talking amp building costs I assume it is probably worth the small extra to purchase Metal Film Resistors vs Carbon. Also Film capacitors vs Ceramic. What ya'll think about that.
Offline Toxophilite
« Reply #3 on: December 04, 2015, 02:36:23 pm »
Resistors and caps are just as debatable points as tubes
I fall into somewhat the same camp
With components, buy new, not vintage. vintage components are past their due dates (except for maybe transformers)
Even if you have a vintage amp, think of it this way; you don't want to put 50 year old tires on your 50 year hot rod....
I use metal film flameproof resistors wherever I can, as they are safer and don't cost significantly more (cents)
For Capacitors I have used Sprague Orange drops, Solens (German)silver mica, and then most lately cheap brown small polyester caps
They all worked great and sounded fine with no discernible difference
One thing to consider, The big amp makers of yore that people love and often copy were businessmen who usually used the cheapest parts they could get that would do the job. I'm pretty sure they weren't sitting around trying different capacitors, resistors or tubes in their amps to see which sounded best. They were small components in a larger circuit.
Get decent parts but use what you can afford, especially for a new /experimental build
Put your money into transformers and if it's a combo a good speaker(s)
Speakers have large impact on sound, once again in my opinion it's largely about quality and condition, don't be fooled by nostalgia.
Once again there will be other viewpoints
Check out Doug's store. He has a large variety of parts and price points, pretty well everything you could want or need.
« Last Edit: December 04, 2015, 02:39:20 pm by Toxophilite »
Offline dmp
« Reply #4 on: December 04, 2015, 03:00:37 pm »
I tried swapping different 12ax7s in a tube amp a few years ago. I remember that I didn't notice much of any difference when played clean. When the tube was heavily distorting, the tubes sounded way different. Some sounded absolutely killer, and some sounded kind of lifeless. I don't remember exactly what they all were, but they pretty much lined up with new manufactured tubes sounding unimpressive and the vintage tubes sounding amazing. I'm pretty sure I had a JJ and EH for newer tubes and RCA, Amperex for vintage tubes.
I'm sure there are other people here who have done much more of this than I have.
The best thing to do is get some and try it.
Offline Papa Jim
« Reply #5 on: December 04, 2015, 03:14:44 pm »
To Toxophilite's comment.  Yep, I've been doing some pricing today and have pretty much come to the conclusion that Dougs prices are very economical and I will go exclusively with him once I discovered that. Besides I started a cart on his site and it works so awesome, creating amp documentation as you go, along with even photos of each part included. Awesome.
dmp. Good observation and I will keep that in mind if I don't like the sound. I will probably stick with my tube buying plan for this first build, play thru it, then purchase a few others and test again. Heck I feel like I will probably be getting hooked on this hobby and can use anything I buy eventually.  :l2:
« Last Edit: December 04, 2015, 03:18:45 pm by rolloman »
« Reply #6 on: December 04, 2015, 03:23:08 pm »
This is my "I've had good luck with ........" snippet. I've had good luck with EH 12AX7 Guitar Center on sale sometimes for $10. If you have a small smattering of amps, you are going to use 4 or 6 or 8 or 12 or 24 12AX7 over the next year....so buying a dozen if they can give you an even better price is not the worst idea ever. Is there an Xmas sale on TOOBS? I have not looked. Point being, if you save $3-5 on each of a dozen tubes, you can go pay $10 or $20 too much for one or two elsewhere. If you are paying $100 for multiple vintage RCA NOS 7025 I will withhold my opinion.
You never know with used tubes. There are very low emission RCA, GE, Mullard etc; tubes everywhere. I like to try to buy used test equipment which can have 12AX7s and very often 5751's in them. SOME, only SOME organs can yield a treasure trove of used tubes but only a few use more than a few 12AX7..Most use 12 or 24 or 36 12AU7, much less useful a tube. (tho everybody needs one)
Offline Papa Jim
« Reply #7 on: December 04, 2015, 03:37:22 pm »
Funny you mentioned EH eleventeen,  I was just reading this below on AMP FIX website.
The Russian Sovtek company manufacture a range of quality valves, and sell them in their thousands to the likes of Mesa Engineering (Boogie) and Fender, Groove Tubes, Electro Harmonics, etc. With the individual company logo's printed on them, and at hugely discounted prices. They are then marketed by those companies and sold on to the the likes of you an I in some cases at greatly over inflated prices. To be fair the exception would be Electro Harmonics. These do retail at a fair market price.  No amplifier manufacturer makes their own valves, they all buy from the major factories.
« Last Edit: December 04, 2015, 03:39:33 pm by rolloman »
Offline Toxophilite
« Reply #8 on: December 04, 2015, 03:57:42 pm »
Sounds sensible, build an amp get it working, then if you want to monkey with more expensive/fancy tubes to see if it turns your crank, it's an easy enough thing to swap tubes in and out
Most of all
Have fun!
and don't get electrocuted...or see the magic smoke..at least not the electrical kind :icon_biggrin:
Offline Papa Jim
« Reply #9 on: December 04, 2015, 05:21:52 pm »
Have fun!
Do you speak from experience. :l2: :l2: :l2:
Offline Toxophilite
« Reply #10 on: December 04, 2015, 05:35:23 pm »
Yes for all the above!  :icon_biggrin:  though I've only been indulging in accidental electrocution in recent years..
« Reply #11 on: December 04, 2015, 05:58:39 pm »
So are you saying you did it on purpose in prior years?
Offline Toxophilite
« Reply #12 on: December 04, 2015, 06:24:53 pm »
yeah but after a while I began to find it reVOLTing! :icon_biggrin:
« Reply #13 on: December 04, 2015, 06:55:40 pm »
I thought everyone tried it...once :icon_biggrin:
« Reply #14 on: December 04, 2015, 07:32:12 pm »
... any tips you can share when it comes to select 12AX7 or other tube when so many choices exist. Brands, NOS, and price. ...
Overall, no. I can't share tips because in the end your opinion is the only one that matters for your amp. Use what works best for you.
That said, my experience has been that of the preamp tubes, the one directly connected to the input jack makes the most impact (because a change there is amplified by the rest of the amp).
I've also found that some amps seems to have very noticeable changes with a  tube change, while others seem to sound the same no matter what s in the socket. So it's up to you to find what works best for you.
In the early 2000's, I went into a well-stocked music store and bought one of every 12AX7 they hand (8-10 brands). I tried each in one of the amps I had, and most sounded the same to me. Years earlier, I had tried several different old-production 12AX7's (RCA, G.E. Telefunken) in a '67 Princeton Reverb. I heard some subtle, but noticeable differences. That said, having tinkered amps since the late-90's, my opinion is you'll get a bigger change of amp tone by changing parts values in the amp circuit than by a tube swap or a resistor-/cap-type swap. The latter are icing on the cake, and may get lost if you're not listening to the amp/guitar by itself.
Offline Paul1453
« Reply #15 on: December 04, 2015, 09:18:03 pm »
I have been experimenting with this recently.
Unless you have gotten vintage tubes like I have, scoring premium tubes salvaged from other junk gear, this is too expensive to test.
There is definitely a difference in your amps sound when you put a sweet premium tube in the V1 spot.  It is subtle, though.
Many people will not notice this subtle difference.  You might be one of them.
Many places charge like 10x the cost of a regular 12AX7 for a premium Mullard or Bugleboy.  Is it worth it?
Not to me, but I guess there is a sucker born every minute.
I do prefer the sound of premium tubes, but I would never pay retail prices to use them.
« Reply #16 on: December 04, 2015, 11:14:17 pm »
One of the things that I read early in my state of tube curiosity was the first page of this pdf from Merlin's preamp book: http://www.valvewizard.co.uk/Common_Gain_Stage.pdf
I took this to say that it would serve me well to expend more energy concentrating on all of the components and circuit structure that affect overall "tone" instead of focusing on specific tube types/brands as the be all, end all of tone shaping.
I found this theory to be helpful in every aspect of tube amp building and it has afforded me the clarity to look beyond folklore and lose less sleep wondering what a "better" preamp tube might sound like. (or "better" capacitor, transformer, resistor, etc., etc., etc., etc.)....so I figured I'd share that "idea" with you.
That said....
Here are 2 reference forms that someone (much more knowledgeable and experienced than I will ever be) spent time putting together. There was a time when these descriptions offered me some form of mental comfort and direction. But now it seems that I am at the mercy of the specific circuit I am putzing around with, and wind up just subbing in tubes until I find one that gets me closer to the tone I am searching for.
One of my favorite authors once wrote "TONE is found somewhere between the ear and the beers" (or something like that.....you get the picture).
http://www.thetubestore.com/12AX7-Tube-Reviews
Offline Toxophilite
« Reply #17 on: December 04, 2015, 11:45:30 pm »
I always like what I read once where a fellow pointed out that nowhere in the marketing of tubes or capacitors etc in the 50s and early 60s did anyone talk about tonal qualities and or sound. They all talked about ruggedness, longevity and staying in spec. There was no mention of tubes sounding like British tweed jackets.....This was the heyday of tube technology when everything required them and marketers were no slouches either. If marketers knew of any quality that would sell their products better they certainly wouldn't neglect to mention it.
Individual capacitor and tube tonal qualities seems to be a comparatively recent concept
Still it's fun and the electrocutions are way better than with weak solid state gear!
« Reply #18 on: December 05, 2015, 12:03:44 am »
... nowhere in the marketing of tubes or capacitors etc in the 50s and early 60s did anyone talk about tonal qualities and or sound. They all talked about ruggedness, longevity and staying in spec. ... If marketers knew of any quality that would sell their products better they certainly wouldn't neglect to mention it.
In some ways this is because today the marketing is aimed at mostly non-tech folks. Anyone can pull a 12AX7 from the socket and install a new one as "a mod."
Most of the old marketing was in publications targeting knowledgeable DIY folks (like the Ham who builds his own transmitter/receiver) and repair personnel. The DIY guy wants to spend his relatively limited budget on tubes that aren't noisy and will last, giving economy in measured useful lifespan. The repairman wants a replacement tube that won't quickly turn faulty and have him called back to re-fix his work (often for free), so that he can build/maintain his reputation and keep the one-time labor charge in his pocket.
If you pay close attention, the magazines that target the repairman repeatedly talk about "avoiding callbacks" on almost all tube and cap ads.
Offline Toxophilite
« Reply #19 on: December 05, 2015, 12:22:20 am »
Sounds good to me! Something that is reliable and works show after show, rehearsal after rehearsal, session after session!
Offline Fresh_Start
  • noob de Lux
« Reply #20 on: December 05, 2015, 09:27:48 am »
I've had some fun substituting different tubes in a few amps.  +1 to the idea that the first preamp stages are the most important. Especially in terms of the noise floor because any noise at the front end gets amplified further.
New tube fabrication doesn't seem to be especially precise. With a really simple circuit like a 5F2-A, sometimes I can hear differences between tubes with the same label.  There do seem to be trends between different labels. EH 12AX7s are my starting point. Consistently low noise and an absence of ice pick high end. But I've found new Tung Sols and even some Chinese tubes that sound really good.
I've also had good luck with a few "almost new old stock" 12AX7s. Only worth it in the V1 spot, but worth it in some amps.
Power tubes vary a fair amount too. Chinese 6L6s don't sound the same as "winged C" Svetlanas. At least not in the Super Reverb I built. The amp's owner preferred the Sveltlanas too - and I didn't tell him which were which. (And yes I re-biased when changing tubes)
I got a pair of JJ EL84s for my Blues Jr.   Harsh, brittle and unpleasant in that amp.  A pair of Ei power tubes made that amp sing.  Fixed up a couple of issues in a Peavey for a young friend and tried all of the EL84s I had on hand. To my surprise, the JJs sounded great in that amp. Again, I had the owner pick his favorite pair out of three choices and he liked the JJs hands down.
I guess my point is that tubes are not consistent like transistors which either work or they don't. If you have a modern amp with multiple channels and lots of tone tweaking, maybe the cheapest tubes that are quiet make sense. OTOH with simpler circuits, tubes can make a difference. Certainly as much as capacitor choices IMHO.
Nothing close to speaker choice though!
Respectfully,
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #21 on: December 06, 2015, 09:21:20 am »
... a fellow pointed out that nowhere in the marketing of tubes or capacitors ...
... the magazines that target the repairman repeatedly talk about "avoiding callbacks" on almost all tube and cap ads.
Sounds good to me! Something that is reliable and works ...
It just occurred to me that marketing, whether today or 60 years ago, has little to do with the product being sold. The product could be good, bad, be anything really. Successful marketing reflects the psychology of the target audience, and what they're worried about. It then tells them (truthfully or not) that the product will make everything better, and keep them from having cause to worry.
I never took marketing in school, but I bet that "insight" on my part i covered in the intro to marketing class...
Offline Toxophilite
« Reply #22 on: December 06, 2015, 10:00:57 am »
I think the point I had read (and shared) was that marketers are generally very tenacious and exploitive of any quality they can use to flog something on the unsuspecting public. I was under the impression that they will often invent a dilemma or 'fear' (like governments often do!) and then seemingly provide the solution.(This is REALLY 'successful' marketing) so the dilemma doesn't actually have to reflect the current mindset of the populace it just has to be believably presented.
I thought it was a humourous and enjoyed the connection as marketing is EVERYWHERE and it's very hard to avoid. Generally I am not keen on it as it is rarely aimed at making people feel good.
Out of curiousity, as you seem very well informed,(and I say this with NO mockery)
Has there has been any scientific, peer reviewed, factual literature published regarding the 'tone' or ' sound' of amplifier components like tubes and capacitors?
It would be very interesting to read
« Reply #23 on: December 06, 2015, 10:53:47 am »
I worked for a sub company of J&J, as a service engineer on CAT scanners, the *real* engineers were in final stages of a truly new scanner that blew away anything out there.  The sales team and  marketing was wetting their pants over the new homes and boats they were gonna buy, so they sold the scanners before they were released from engineering.  my company sold out to GE a year later because of all the down-side bugs and cost over-runs etc, but the marketing & sales guys made their money!
Offline Paul1453
« Reply #24 on: December 06, 2015, 11:17:38 am »
I'm thinking sound is a subjective matter and does not relate well to scientific quantifiable measurements.
We can measure gain, noise levels, MTBF, shock and heat tests, but quantifying what sounds good doesn't seem to be so easily measured.
I used to think my tube tester could give me a good indication of this, but have now realized that this is not so.
Many tubes I have tested score low or even bad but sound just fine in an amp to me.
Often I have a hard time discerning the difference between tubes that score high/above specs from tubes that score low/or even bad.
I did watch a Youtube video about Mullard tube manufacturing and the growth of their operations.
It seems they made facilities to produce almost everything in house.  With testing labs to control QC.
I think that is a big part of their allure.  Quality inputs to the manufacturing process led to consistent quality output.
Offline Toxophilite
« Reply #25 on: December 06, 2015, 12:50:00 pm »
I'm not sure about that
There is a lot of science behind audio engineering
Identifying frequencies to remove and or enhance them, isolating the sonic qualities of individual instruments to help locate them in a mix so that they don't interfere with other instruments etc etc. Finding frequencies that have a tendency to feedback, tuning PAs to particular spaces etc etc etc.
Audio engineers/ soundman could be described as people who know how to translate technical information regarding sound into something an average muscian/person would think 'sounds good'. Kind of an interface between the two worlds.
So I believe how things actually sound can be measured and defined, and there is gear readily available to do it.
Certainly there are preferences, that is subjective, but there are absolutes
If you read descriptions of what people say certain brands of tube 'sound' like. You will often find people saying the same sorts of  things, which often sound like they are related to frequency response.
This could be for two reasons
1 - They are all hearing the same sonic characteristics (which would often be about EQ or frequencies represented)
2- They are all reading the same information/sources and have developed a lexicon regarding the tubes as a result
If it's the former, it should in some way be measurable, defined, or tested
However I think I'm totally off topic annnd riding a hobbyhorse!, These concepts interest me and I digressed
back to the scheduled programming.
« Last Edit: December 06, 2015, 01:16:29 pm by Toxophilite »
Offline Paul1453
« Reply #26 on: December 06, 2015, 01:06:22 pm »
I think you are correct in that some of these sound characteristics should be measurable.
But that might not tell the whole story.
What sounds good to me might be very different from what sounds good to you.
Again we are back to that subjective determination of what sounds "good".
To me, the old premium 12AX7s do sound subtlely better.
But definitely not worth 10x the price of current production.   :l2:
Offline Toxophilite
« Reply #27 on: December 06, 2015, 01:18:38 pm »
I think there's a lot to be said about anything made when almost most electrical devices used tubes and there was vast industry and much experience in place to manufacture them to a consistent degree of quality.
« Reply #28 on: December 06, 2015, 03:03:35 pm »
Nice discussion and thread. But I will simply only say that various tubes do in fact matter. There is a discernible difference between them especially in V1 sockets as pointed out earlier. If you don't hear it, then possibly you either have an inefficient speaker, lame amp circuit, poor set of damaged ears from years of playing too loud,  dark sounding guitar and/or pickups, old strings that need changing (unless you use flat wounds), long high capacitance guitar chord, maybe your amp was made with all ceramic disc caps (oh the horror), heck maybe all of them combined? If you don't hear the differences than I feel badly for you that you can't. Do all mustard flavors or cheddar cheeses taste the same? Do all micro brews, cabernet wine's or scotch whiskey taste the same? Can you test them with signal generators & oscilloscopes? Of course not. Ha! How about the marketing angle with cryogenically treated tubes? Those are supposed to be the best?! I haven't seen anyone mention that "tube live's matter"? Maybe that's another thread? For some reason I feel like I'm channeling PRR with cynicism or Richie200 at moment? (and PRR nothing but respect for you - you have a way about keep things simple and understandable - Richie not so much (inside joke)) Peace out!
Offline Toxophilite
« Reply #29 on: December 06, 2015, 06:52:17 pm »
Well don't feel sorry for me
I have a lovely amps, Excellent high efficiency speakers, Beautiful regularly maintained guitars (great acoustic tone, well set up etc etc), good quality normal length patch chords, change strings regularly, play lovely clean crisp sounds
Do not play too loud (jazz rockabilly, latin, etc etc) etc etc So NO NO NO NO NO NO to all those assumptions.
Strangers are always telling me how lovely setup sounds ( I play live a lot)
And with respect
I don't compare electrical components to organic foods , aged whiskies or fine wines .
Tubes are manufactured objects mass produced in factories developed over a matter of a few decades, not the result of thousands of years of tradition, experimentation, family recipes, complex organic processes etc.
Couldn't even begin to imagine them in the same league myself . I could compare music to those things though.
But I will NEVER begrudge you your enjoyment of them or suggest that anything you are doing, using, etc is deficient,and I certainly wouldn't pity you for enjoying them or spending extra money on them.
Please enjoy them and the differences you hear! (I say this seriously)
To me the magic is in the music, the playing of it,and to a slightly lesser degree, the instruments. Gear is tonnes of fun, but to me, ultimately an ends to a means, and a pleasurable pastime.
Best regards
« Reply #30 on: December 06, 2015, 06:58:23 pm »
I played around with  single 12ax7's one time monitoring it with a scope and a spectrum analyzer borrowed from work, with single freq, or 2 freqs things were reasonable, gain, bandwidth, noise, but when you started mixing multiple freq as fast as you could strum it became totally *unmanageable* with test equipment
I told the guitar player "it looks like S*&T"
That said I am NOT a sound engineer, I would starve :icon_biggrin:
Offline Toxophilite
« Reply #31 on: December 06, 2015, 07:12:38 pm »
Well obviously my opinion is an extremely popular one
Maybe it's too practical??
 :icon_biggrin:
Feel free to pile on!
You could if you had tubes that had similar amounts of gain do some simple recordings with everything else being the same.
Same guitar part, same mike position etc etc and then have a very close listen and look at the actual waves forms.Perhaps something would show up.
Digital recording is pretty cool that way. And there are frequency analyzers which are pretty neat too.
However there could be little Djinn living in those little bottles :icon_biggrin:
No two tubes are the same strength and thus will always sound a little different.
 I just never found it significant, it never made my day, nor wrecked it, Music was still just as enjoyable.
This is like a discussion on politics and or religion!
« Last Edit: December 06, 2015, 07:18:19 pm by Toxophilite »
Offline Fresh_Start
  • noob de Lux
« Reply #32 on: December 07, 2015, 09:50:05 am »
One thought on tube-era marketing:  it was aimed at a different market. Tube radios, TVs and maybe organs either work right or they don't. The ham radio operator doesn't care if his tone is warm or has ice pick highs. He does care if a tube is microphonic or doesn't produce gain in an acceptable range. Other than that, it works or it doesn't.
Guitar amp builders OTOH obsess over polyester vs. polypropylene caps, foil orientation, magic mojo from Mercury Magnetics transformers (now there's a lesson in marketing sizzle!), oxygen free cables, partially depleted pickup magnets, and a million other things.
Like JojoKeo, I can hear differences between different tubes. Sometimes, in some spots.
Chip
Quote from: PRR
Offline alerich
  • This one goes to 11.
« Reply #33 on: December 07, 2015, 10:20:02 am »
+1
Like SG I find myself simply rolling tubes to see what impact it has and whether I dig it or not.
« Reply #34 on: December 07, 2015, 11:00:44 am »
+1
Precisely - which implies that we DO in fact hear various tone and gain differences between different tubes used, not to mention various artifacts and hopefully not microphonic issues also. This fact is not limited to 12ax7s but all other 12a_7 preamp tubes as well as pentodes also.
« Reply #35 on: December 07, 2015, 01:58:06 pm »
I will give 2 brand new EH 12Ax7's for any 1 Truly NOS RCA, Tung SOl, Telefunken, Mullard, Amperex or EI.  If you have some RCA, NOS large white letter black plate 12Ax7 or Bugle Boys I will give you 3 new EH 12Ax7.
Hell, I will even do NOS GE 2 to 1.
I promise to never sell them so I will not profit from you.  If I do ever get rid of them I will send them back to you.
Oh hell, make it 3 to one and 4 to one on the Mullard, RCA black and TungSol.  I will bet my PM box gets full now. :l2:
Oh yea, I will pay shipping both ways.
Any takers?  I bet not.
« Reply #36 on: December 07, 2015, 02:38:10 pm »
I will give 2 brand new EH 12Ax7's for any 1 Truly NOS RCA, Tung SOl, Telefunken, Mullard, Amperex or EI.  If you have some RCA, NOS large white letter black plate 12Ax7 or Bugle Boys...
Ed, I have a nice box filled with 'em. I won't be running out anytime soon. I use the new production tubes for phase inverters, trems, reverb or other "worker bee" positions and save the oldie AND goodies for the important jobs. btw, you didn't mention a few others but don't say 'cause we don't need further competition than there already is in finding them. It always gives me a big  :icon_biggrin:  when I get lucky and my searching pays off with an excellent price. This disputes comments that they (good ol' NOS) can only be found with paying high prices and therefore not worth it. Rubbish & sour grapes both. But as you also know, even at $50+/tube, nothing can touch what a really sweet tube will give you. Not special transformers, special caps & resistors, or even the best of speakers.
Just my opinions & observations forum friends...we all know SRV didn't care anything about what tubes he used right?  :laugh:
Offline Toxophilite
« Reply #37 on: December 07, 2015, 03:19:43 pm »
Why doesn't anyone talk about the healing properties of tubes?
I've just been turned on to this and I find I'm leading a warmer, articulate, and more transparent life with less top end 'fizz'
My girlfriend has noticed that my middlle is more scooped and my bottom end seems a lot 'tighter' :icon_biggrin:
« Last Edit: December 07, 2015, 03:26:14 pm by Toxophilite »
Offline Toxophilite
« Reply #38 on: December 07, 2015, 03:40:29 pm »
Ed I'll trade you a used Bugle boy made at the Ontario Amperex plant denoted by the little 'r' in the date code etching for three  Eh 12ax7. It doesn't have the little picture of the tube playing a bugle which I know makes it sound better but it's the same thing otherwise. I've sold a gazillion of these in the past 10 years and I've kept some to use, as Amperex was a good name in manufacturing. More importantly I didn't have to buy them! I'd be happy to have three new Eh tubes. That means I'd have 2 more tubes and they'd be brand new!!! How many can i get for an Amperex 7025?
Offline Paul1453
« Reply #39 on: December 07, 2015, 03:56:43 pm »
To me, tubes seem to be the only electrical components worthy of comparison to fine food or drinks.
There does seem to be some type of organic nature / personality to tubes.   :icon_biggrin:
If they didn't have that, I'm pretty sure we would all use the cheaper SS guitar amps instead.   :l2:
« Reply #40 on: December 07, 2015, 05:28:18 pm »
I am not sure of why you would post this to me.  I assume you know what NOS is, but in-case you do not it means a tube that has not been used.  New Old Stock.
I am sure you are not thinking I am dumb.
If you missed me writing that go back, but I think you are being a straw man as it is ridiculous to even offer this to me as I know you are not so stupid to not understand what I meant.
Also, tube manufacturers certainly did and do refer to the audio quality of their tubes and some were designed to have specific characteristics like aligning the screens to remove the kink giving us the Kinkless Tetrode and enclosed to direct the electrons as in a Beam.
They also advertised having better audio quality. Look at the old ad I have posted here.  I actually collect old tube ads and you would be surprised how many do refer to improved audio quality.
You have the right to you opinion, but in the future please leave me out of your debate if all you want to do is be silly.  I mean why would I want an old used tube?
BTW, say what you want about the little bugle on the tube, but they are worth more money.  It is not that they are guaranteed to sound better, but you can be assured they are made for audio in Holland.
So again I ask you.  Did you miss the NOS part of my post or are you simply trying to make me look foolish.
« Reply #41 on: December 07, 2015, 06:35:37 pm »
"Scientific" and "peer reviewed" suggest a scientific journal. I'm not an AES or IEEE member, but suspect there is such material in their journals, at least for component parts. Dunno about such writing for tube sonics.
There is a good article series on Capacitor Sound printed in Electronics World in 2002. I submit it is scientific, having been researched and written by a capacitor engineer and because it gives results that, while substantiating some of the general claims about cap sound, also points out notable deviations (like how different flavors of ceramic dielectric caps both represent the worst- and best-measuring samples). The author spends a great deal of space on his measurement setup to enable others to duplicate his results; result replication is important for published scientific research.
(A quick note: "PET" in the articles is polyethylene theraphthalate, also known as polyester. But there's more than one type of polyester, and Mylar is a special form of polyester. "PP" generally means polypropylene in the article. For all dielectrics, construction methods can differ, and the article suggests construction method can cause measurable distortion in some caps.)
The challenge with doing the same with tube sound is deciding what factor(s) to measure which will be indicative of in-circuit sound/performance. There aren't too many tube manufacturing engineers left to guide the choice. As an active component, there are additional dimensions to the problem compared to passive components (which are surprisingly complex when you delve into real-world components compared to theoretical ideal components).
« Reply #42 on: December 07, 2015, 06:56:36 pm »
I LOVE these little guys and not just for 12ax's...  :thumbsup: :notworthy:
Offline Paul1453
« Reply #43 on: December 07, 2015, 07:22:37 pm »
Ed's point of real NOS tubes has me wondering.   :dontknow:
This supply must be very limited and trending toward extinction every day.
I have seen sellers on Ebay selling just the premium Mullard, Amperex boxes, for very expensive prices.
I wondered why anyone would buy them.  I think I can see why now.
It makes me wonder how many of the tubes sold as NOS actually are unused tubes?   :w2:
Offline Toxophilite
« Reply #44 on: December 07, 2015, 07:41:06 pm »
Oy yoy you Ed you sure do take this seriously
We are talking about electrical components  here aren't we??
Or are we talking religion and politics??
Seriously
No-one was calling you dumb
if I had a proper shiny , just came from a vault tube , the only reason i wouldn't trade it to you is that some 'enthusiast' would pay me piles for it and then i would go buy some other perfectly useful new tubes or other things like guitars strings, food etc etc
Anyway clearly this is really important to you and I apologize if I'm making light of it
However I never think it's bad to be silly
There is enough unhappiness in the world from people taking things excessively seriously. we are witnessing it all the time, sadly
I don't want any part of this 'debate ' I was offering the original fellow an opinion and I think a reasonably sensible one
To concentrate on building and amp and not worry to much about hunting down special important parts which will make tiny differences
To me the magic is in the player, the mind the heart the soul and the music not in the glass tubes
time spent tube rolling could be better spent playing and or rehearsing
I'm sorry I'm not preaching to the prevalent choir with this concept
I had an opinion and Jojokeo told me I was deaf, I had old strings, I had crappy amps etc etc etc yeesh!
I responded with humour as I was trying not to be offended by the rudeness
I am not stopping anyone from spending any amount of time with capacitors and tubes etc
I just prefer playing music , and making amps for fun
« Reply #45 on: December 07, 2015, 08:12:12 pm »
I prefer JAN tubes. But I will use an import if I have to. I guess.  :icon_biggrin:
« Reply #46 on: December 07, 2015, 08:57:22 pm »
I have been through many many crappy sounding preamp and poweramp tubes.  As has been said here over and over there is a difference.  I say huge difference - sorry, but I will have to take Jojo's angle.  Either you have been weaned on inferior product and think it is the norm, or the application is flawed.  If even your drummer can tell you that you sound like crap, you know your in trouble.  Geez, everything from spikey to thin to horrid distortion characteristics, my gosh, I could go on and on.  It's as plain as my big nose.  They all check out fine electrically, but the majority of the crap I've run across ARE new manufacture.  I've ranted several times here about Groove-your-wallet Tubes and my round robin with their Chinese and eastern euro crap tubes.  Many new manufacturers are copying the old charts for advertising knowing full well the tube can never achieve those numbers.  How do I know?  I've got the dead soldiers to prove it.  My goodness a good tube can change the whole dynamic character of an amp.  This is not to say some old mfg stock are bad, because there where/are.  However, the functional old tubes are superior.  Companies that are trying to copy some of the old tubes to the molecule are outrageously expensive - for a reason.  It's not in the labor or short runs.  Some simply can not be replaced these days.  Case in point my old stash:
« Reply #47 on: December 07, 2015, 09:35:53 pm »
The reason I am so keen on this subject is because I've spent a lot of hard earned money with sub par results.  I'd like to think I can save someone some cash based on my unfortunate experiences.  I think we are all giving our opinion for the original poster.  I may disagree with some folks but I have real reason and a lot of live and woodshed hours to back it up.  It's all well and good to talk about the spiritual aspect of music and guitar playing.  However, telling someone to practice more and roll tubes less could be considered just as rude to someone who is trying to explain what they have encountered.  When the rubber meets the road, its the little differences that make a world of difference.  That's why Brian May, Robin Trower, Page, Beck, SRV, etc, etc.... sound like they do and you can tell who is trying to sound like them - but not quite there.  I guarantee you these guys are not using crappy tubes from Chine.  After all, that's part of the reason why we are all here in the first place - to chase that tone as SG said.  I happen to think the glass plays a large role.  However, I am partially deaf and I do play with strings that are years old.  But that doesn't matter because I have THIS  :m8
Offline Paul1453
« Reply #48 on: December 07, 2015, 09:37:20 pm »
Wow, I guess the reason I thought there was only a subtle difference is because all the tubes I have are old ones salvaged from other gear.
I didn't have any of the new manufacture tubes to compare with.  I guess I'm just lucky.
All the more reason for me to continue with my junk gear acquisitions then.   :laugh:
I picked this one up for $21 including shipping just for the Hammond/Mullard 12AX7 and 12AU7 I could see it had.   :icon_biggrin:
« Last Edit: December 07, 2015, 10:14:27 pm by Paul1453 »
« Reply #49 on: December 07, 2015, 10:02:32 pm »
C'mon Toxo I was not speaking to you directly at all or I would've put something by you in quotes like above. And I was being humorous as well so why did you not take it as that also as you're saying above (rhetorical - no need to respond)? Something is inconsistent and amiss?
