September 19, 2026, 02:19:05 am
Hoffman Amps Forum image Author Topic: Latest build pics "Cream 18W Project"  (Read 9934 times)
Offline TubeGeek
    • Glacier Amps
« on: January 01, 2016, 01:50:23 am »
I have been building a few 18W mojo kits this winter and wanted to share how this one came out.  It was customized a bit from the standard mojo kit.
I added VVR and it works great in this circuit.  I also modified the layout from mojo and made a few component changes to my liking and styling.  I used one of Doug's 3 position switches for off/standby/play which then allowed me to use the empty hole for the VVR master control pot.
This project in particular need a little help with the low end due to the speaker choice.  I used a brand new Celestion speaker...The G12 Cream 90W alnico model.
I am pleased with the faceplate and backplate design on this project, it ties in with the cream speaker.
This amp sounds really quite nice to me. I have another of these kits coming up on the bench next week too, only it's not going to be as customized.
« Last Edit: January 01, 2016, 01:41:00 pm by TubeGeek »
Re: Latest build pics "Cream 18W Project"
« Reply #1 on: January 01, 2016, 09:06:57 am »
Looks great!  :icon_biggrin:
Where did you get the chassis and cab?
« Reply #2 on: January 01, 2016, 09:23:34 am »
Nice!
Offline TubeGeek
    • Glacier Amps
« Reply #3 on: January 01, 2016, 10:43:45 am »
It's a mojotone kit that I have customized.  I had the faceplate and backplate laser engraved locally where I am.  Here is a pic of the backplate:
« Last Edit: January 01, 2016, 01:45:14 pm by TubeGeek »
« Reply #4 on: January 01, 2016, 10:46:47 am »
Huh, ok, thanks.   :icon_biggrin:
Offline ratgon
« Reply #5 on: February 10, 2016, 11:52:39 pm »
Beautiful. Really nice work on the design of the cab and plates
« Reply #6 on: February 11, 2016, 12:24:23 am »
Very classy looking! Congrats!
« Reply #7 on: February 11, 2016, 03:18:24 am »
Hey TubeGeek, Great work as usual.
Is the face plate a black plastic with a thin cream veneer that the laser cuts through the cream to show the black???
Love the font, reminds me of a led zeplin lp cover, cool.
Offline TubeGeek
    • Glacier Amps
« Reply #8 on: February 11, 2016, 05:54:18 am »
Thanks for the compliments.
Yes the faceplate is a lasermark plastic that when lasered, leaves black font.  It is available in all sorts of colours.
« Last Edit: February 11, 2016, 10:06:35 pm by TubeGeek »
Offline avspecialist
    • Perfect Vision & Sound
« Reply #9 on: February 11, 2016, 06:35:45 am »
That is an excellent job. I built quite a few mojo kits. can you tell me more about the Vvr circuit you used, was it a London.  I have an 18 watt I built for a customer and would like to control the loudness better. can you post pictures of the install and tell us how you wired it in. I would really appreciate it, thanks Bob
« Reply #10 on: February 11, 2016, 09:01:32 am »
+1
Timbo, google "Led Zeppelin font"...here's one result: http://ledzeppelin.alexreisner.com/fonts.html
avspecialist,
Here's a link to an archived topic on VVR:
http://el34world.com/Forum/index.php?topic=6899.0
Offline TubeGeek
    • Glacier Amps
« Reply #11 on: February 11, 2016, 09:59:00 pm »
I got the cathode bias VVR idea from the link that silvergun posted.  All I did was build it using a terminal strip and installed it where I had room in the amp, in between the preamp board and PT.
I had to use a 3 position switch for off/standby/on.  Then i used what used to be the standby switch hole in the chassis for the VVR which I just called MASTER on the new faceplate.
Pretty simple install overall and it worked nicely.
If you look closely you will notice I inverted the faceplate from mojo's.  This way when you walk up to the amp, the text is facing toward you instead of away.
« Last Edit: February 11, 2016, 10:11:25 pm by TubeGeek »
Offline TubeGeek
    • Glacier Amps
« Reply #12 on: February 11, 2016, 10:00:32 pm »
+1
avspecialist,
I sat down with the owner and we looked through the fonts I have on my mac.  We selected 3 fonts and when I was at the laser guy's place, this font seemed to work the best so I went with it.  It is a common font found in Pages or Word called "Eccentric Std".
« Reply #13 on: February 11, 2016, 10:11:16 pm »
Your work sure looks good James. I really like seeing young folks enjoy this stuff as much as you do. Don't ever stop!
Offline TubeGeek
    • Glacier Amps
« Reply #14 on: February 11, 2016, 10:14:01 pm »
It keeps me out of trouble  :icon_biggrin:
It has got to the point where I should learn to turn it down a notch or two.  I have tendency to take on too much work for my own good because I enjoy it so much.  Oh well, it beats watching tv.
« Reply #15 on: February 11, 2016, 11:21:36 pm »
WHAT, He's a young bloke, he must be 50 then.
« Reply #16 on: February 12, 2016, 04:45:03 am »
I just assumed he was young. He runs with way too much energy and enthusiasm for an old fart. I don't think his soldering station has cooled down since that Vibro-Champ! Well, maybe once when he moved back to Canada.
« Reply #17 on: February 12, 2016, 06:48:00 am »
nice work. very nice.
Offline TubeGeek
    • Glacier Amps
« Reply #18 on: February 12, 2016, 11:38:45 am »
Haha you still remember that eh!  I remember doing a face palm when I realized I used conductive esd rubber mat as an under the board insulator. :l2: Good times.
I'm 37, so not too young and not too old.  I feel like I am 50 though.
« Reply #19 on: February 12, 2016, 02:24:35 pm »
 :thumbsup:
« Reply #20 on: February 12, 2016, 02:54:08 pm »
when you hit 50, you may want to edit this post :icon_biggrin:
