August 29, 2026, 02:05:23 pm
Hoffman Amps Forum image Author Topic: princeton reverb AA1164 new build  (Read 3816 times)
Offline khansen810
« on: January 12, 2016, 10:25:59 am »
Just finished building this amp using the Hoffman turret board. Everything is working properly and sounds great. I do having the following problem. Powered with no input (input shorted) and the volume set at about 3 or higher and all the other controls set to 0 except for the volume. When you turn up the reverb pot (reverb turned off) there is an increase in the hum. Not sure what's causing this and if there is a solution. Maybe this is normal? Much appreciated.
Offline p2pAmps
    • p2pAmps
Re: princeton reverb AA1164 new build
« Reply #1 on: January 12, 2016, 12:23:11 pm »
Not normal I don't think.
Pull that chassis and check every single component value and triple check your wiring first and foremost.  Each and every time I have issues on a new build it turns out to be me!
Good luck and I think we would all like to see some guy shots of your amp
Everything Affects Everything
« Reply #2 on: January 12, 2016, 02:48:13 pm »
Here's a great way to double check a new build, click on the link at the very bottom of my reply.   :icon_biggrin:
« Reply #3 on: January 12, 2016, 06:35:05 pm »
