September 08, 2026, 07:17:56 pm
Hoffman Amps Forum image Author Topic: GFI and ISO PT?  (Read 4633 times)
Online Willabe
GFI and ISO PT?
« on: February 12, 2016, 11:55:52 am »
Should I be using a GFI wall outlet in my work shop and an ISO PT for any amps I'm working on?
GFI > ISO PT > Variack (when needed) > light bulb limiter (when needed) > amp
And should my oscilloscope (and signal generator, when I finally buy 1) be plugged into the same GFI and the ISO PT when I use it?
« Last Edit: February 12, 2016, 09:58:11 pm by Willabe »
Re: GFI and ISO PT?
« Reply #1 on: February 13, 2016, 09:12:47 am »
GFI
Not sure if you gain anything because of your iso, they *sense* issues tween ground - neutral(?) and your iso I believe *isolates* your bench ground from house ground. IF you try, make sure your wires from *bench* to *box* are correctly wired
Offline drgonzonm
Re: GFI and ISO PT?
« Reply #2 on: February 19, 2016, 11:54:04 am »
I believe a GFI is a smart thing to put in your workshop.  I've worked in industries were all power tools needed to be gfi'ed.  I have even seen electrical inspectors cite someone because their coffee pot was not grounded.
To me, the key word is "workshop"
Could suggest a quad box where, one half the box is not GFI'ed, just in case, some of your electronics do not like the GFI.
Re: GFI and ISO PT?
« Reply #3 on: February 19, 2016, 02:57:00 pm »
On the one hand, most stuff that "does not like GFI" is defective, should be fixed or replaced.
Large (>1/2HP) motors are a traditional exception, because of the high starting current (>40A). This requires 1000:1 balance of the lines to avoid crossing the 50mA short-term trip of a US GFI. Some older wires (and GFIs) were not that perfect. Yet I have been running large motors on GFIs, no problem except when a plug was in the mud (then it should trip!).
That said.... I just took one device off a GFI and I am thinking about another.
The furnace quit. It drips (condensing) so has a small pump to lift the condensate out of the cellar. The pump was dead. I'd wired it to kill furnace before it overflowed on the floor. Furnace was non-GFI but pump was GFI. Random trip? Annoying, and there isn't that much danger (pump is all plastic). I moved the pump to a non-GFI outlet. (Still have GFI right-there for worker power tools.)
The internet went out. The modem-thing is in the cellar, so GFI had seemed wise. But I had been working around it, the plug overlaps the test button, and apparently I had bumped it enough to trip-out the GFI and kill the internet. For now I use a different plug, but I just may mount a network-only non-GFI outlet high in the joists, where it can't be used casually for lamps or vacuums. Leave the existing GFI where it is (chest level) for those things.
