September 15, 2026, 11:41:33 pm
Hoffman Amps Forum image Author Topic: Doug's Relay Power Supply and LEDS  (Read 5235 times)
Offline James H Harmeyer
« on: February 27, 2016, 12:41:18 pm »
Can anyone tell me if Doug's Relay Power Supply can power 10 or 12 Leds? I believe each Led will have to have a current dropping resistor to bring the 5 vdc down to around 3 volts. But, other than that will the power supply work for 10 Leds?
« Last Edit: February 27, 2016, 12:47:10 pm by James H Harmeyer »
James H
Re: Doug's Relay Power Supply and LEDS
« Reply #1 on: February 27, 2016, 01:47:31 pm »
Doug's relay power supply uses a 7805 regulator chip that can supply 5V at 1.5A if a proper heat sink is used. A typical LED will use .02 amps, so you could theoretically power 75 typical LEDs at that current requirement. 10 or 12 typical LEDs would be no sweat.
« Reply #2 on: February 28, 2016, 04:36:23 am »
Thanks Sluckey for the response and the info, I appreciate your input. But, now I wonder if it would be better to change out the 7805 for a much more efficient switching regulator (LM7805-1A), that doesn't need a heat sink. Or will a good heat sink on the 7805 be good enough to keep this working for a long time? I'm just trying to keep heat from being the cause of a failure.
James H
« Reply #3 on: February 28, 2016, 06:02:54 am »
I would stay with the TO-220 case. Just bolt it to the chassis to provide an adequate heat sink. You'll need an insulator.
« Reply #4 on: February 28, 2016, 03:53:41 pm »
You don't need a regulator. Take your raw 7VDC, use a 270 Ohm resistor for each LED. 19mA per LED, 0.13 Watts per resistor+LED (1/4W Rs are ample), 1.5 Watts total heat for a dozen.
« Reply #5 on: February 29, 2016, 05:57:06 pm »
Sluckey,    what kind of insulator are you talking about for bolting the regulator to the chassis and this will still provide a good enough connection to transfer the heat?
James H
« Reply #7 on: February 29, 2016, 07:13:53 pm »
Mica or silicon. Use heat sink grease too.
Use heat sink grease on the mica only.
