August 29, 2026, 02:05:01 pm
Hoffman Amps Forum image Poll
Which do you prefer?
Nylock nut
1 (14.3%)
Keps nut
4 (57.1%)
I use both
2 (28.6%)
Total Members Voted: 7
Hoffman Amps Forum image Author Topic: Nylock nuts or Keps nuts?  (Read 6129 times)
« on: February 27, 2016, 10:16:39 pm »
The nylock's are quite a bit less money.
But I wonder if for some things like bolting down a ground lug they will give a better ground connection to the chassis?  :dontknow:
Re: Nylock nuts or Keps nuts?
« Reply #1 on: February 27, 2016, 10:35:07 pm »
I vote kep nuts all the way inside an amp. Stainless steel kep nuts are not expensive if you buy a box of 100 on eBay. I would definitely rather have a kep nut for any ground lug.
I find nylocks handy for situations where you want to lock the nut but don't wan't to really torque it down tight, like mounting a reverb tank to a chassis. They would be good on speakers too.
« Reply #2 on: February 27, 2016, 10:59:06 pm »
What about tube sockets?
« Reply #3 on: February 27, 2016, 11:14:55 pm »
I haven't been using any nuts on sockets for several years now. But if I had to, I'd use keps just because I have a good supply in sizes 4, 6, 8, and 10. If I had nylocks on hand rather than keps, I'd use them on sockets. But I would not use a nylock on a ground lug, even if I didn't have keps. I'd use a star washer. I just like the way keps or external tooth stars bite into the chassis, making a very good electrical connection. Nylocks will not do that unless you put a star washer under them.
« Reply #4 on: February 27, 2016, 11:22:27 pm »
Ok.
That's what I'm thinking too.
« Reply #5 on: February 29, 2016, 02:46:13 pm »
I prefer keep nuts as well.  Actually I use Allen Bolts and Keep Nuts mostly everywhere.  I buy in quantity from Mcmaster Carr, but on tube sockets I prefer to tap and use allen head with a drop of blue locktite.
