September 16, 2026, 01:58:19 am
Hoffman Amps Forum image Author Topic: Low volume of bright channel on 5E3  (Read 5510 times)
Offline mayburyds
« on: February 29, 2016, 10:44:17 am »
Hi,
Need some help again!
5E3 was fine yesterday, today there is hardly any volume on bright channel, normal channel seems to be a bit louder but that could be my imagination.
Tried new valves in pre amp section, checked that the input jacks on bolted down tight and re-flowed solder joints for the bright channel but no joy.
Any ideas on where to look next would be welcomed!
Cheers.
Re: Low volume of bright channel on 5E3
« Reply #1 on: February 29, 2016, 02:32:43 pm »
Volume pot?  There are 2 and I have seen it when you have one turned up actually lower the volume on the one you are plugged into.
Offline mayburyds
« Reply #2 on: February 29, 2016, 03:08:30 pm »
Hi,
Thanks for the reply.
I understand the pots interact with each other, but if I have both volume pots on 3 I just about get sound from the bright channel and bordering on break up on the normal channel.
Cheers.
« Reply #3 on: February 29, 2016, 04:02:10 pm »
Such trouble is *usually* a bad connection. Works one day, not the next.
Yes, the 5E3's interactions can also mean a large change of response from "small" change of knob settings. I assume you fiddled enough to know.
Bad tube, bad pot etc.
But on a new build which DID work, I would be looking at the joints. Sometimes they just barely work, but that is good enough, until they don't work at all.
Offline mayburyds
« Reply #4 on: February 29, 2016, 05:01:29 pm »
OK, thanks, I'll go over the joints again and double check.
Cheers.
Offline mayburyds
« Reply #5 on: March 02, 2016, 07:38:36 am »
Checked the voltage on pin 6 on v1 and it was very high. Reflowed the solder on the shared bias connection on pin 8 and that fixed the problem.
Many thanks for your help.
« Reply #6 on: March 02, 2016, 08:46:52 am »
Good job.   :icon_biggrin:
