September 17, 2026, 02:07:43 am
Hoffman Amps Forum image Author Topic: B+ and screen wire layout?  (Read 5244 times)
Offline Mike_J
« on: March 11, 2016, 04:34:17 pm »
Towards the end of the AB763 one-channel build. Want to run the wire going from the standby switch to the B+ cap along side the wire going from the screens on the power tubes to the cap for the screen supply. Is there a problem with running them together?
Mike
Offline p2pAmps
    • p2pAmps
Re: B+ and screen wire layout?
« Reply #1 on: March 11, 2016, 05:08:40 pm »
Mike
I've never had a problem myself doing that...
Everything Affects Everything
Offline Fresh_Start
  • noob de Lux
« Reply #2 on: March 11, 2016, 05:19:15 pm »
Others will chime in, but you're describing raw, unfiltered "DC" from the standby switch running parallel with the leads to the power tube screens.  I would avoid it, but if it works for Mike it should work for you. Can you run the standby switch lead back to the end of the chassis and around?  Any pics of your layout?
It took me a long time (and several builds) to realize that we have 3 dimensions to work with.  180 degree crosses are fine.  Running parallel isn't.  Also, laying high voltage/current leads like plate supplies on the chassis leaves room above for sensitive low voltage like preamp tube control grids.
Respectfully,
Chip
P.S.  Mike responded as I was about to hit "Post"
Quote from: jjasilli
Quote from: PRR
« Reply #3 on: March 11, 2016, 05:21:40 pm »
That's fine. Just don't run that dirty B+ wire from the STBY switch or screens near the sensitive input jacks or preamp stuff.
Offline Mike_J
« Reply #4 on: March 11, 2016, 05:26:01 pm »
Thank you for the responses. Simplifies the layout. Will send a picture once the boards are installed.
Mike
