June 14, 2026, 06:25:33 pm
Hoffman Amps Forum image Author Topic: 100-200 Hz noise  (Read 11690 times)
Offline chocopower
100-200 Hz noise
« on: March 16, 2016, 02:26:22 pm »
Hi there.
I have this old tube amp with a selenium rectifier bridge.
i upgrade it with a modern rectifier bridge (is not new. I get it from some old equipment)
After the upgrade, overall voltages rise, but everything is still in safe range.
The problem now is that i have a 100-200 Hz hum noise who start after a few seconds after switch-on and after 2-5 seconds, get down to a more moderate level but still is there.
I check for cold joints, bad tubes...
Any idea?
David
Re: 100-200 Hz noise
« Reply #1 on: March 16, 2016, 02:43:02 pm »
120 Hz indicates HT B+.  Maybe bias supply if thats fixed bias tapped off the B+.  If you change 1 thong in an old PS, might as well change all of it  .
Offline chocopower
« Reply #2 on: March 16, 2016, 02:53:03 pm »
The amp is cathode bias but it use a voltage divider with a cap to ground to generate a voltage to elevate the heaters center tap.
Could be the cap the culprit?
David
« Reply #3 on: March 16, 2016, 03:11:24 pm »
If the filter caps are as old as that selenium bridge, then I would replace every one of them. Your line frequency is 50HZ, right?
Offline chocopower
« Reply #4 on: March 16, 2016, 03:18:06 pm »
Yes.
220v - 50Hz  (Spain)
I´m gonna change the caps...
David
Offline FranciscoPerez
    • 22 nanofarads
« Reply #5 on: March 16, 2016, 03:46:21 pm »
Great to see a spanish tube amp enthusiast around here!
+1 on changing psu caps.
Offline chocopower
« Reply #6 on: March 16, 2016, 03:58:38 pm »
Hi there man!
I´m from Galicia.
Were are you?
« Last Edit: March 16, 2016, 06:01:14 pm by chocopower »
David
    • 22 nanofarads
« Reply #7 on: March 16, 2016, 04:56:09 pm »
Based in Valencia, but working in Madrid several days a week.
Nice to know you chocopower  :icon_biggrin:
« Reply #8 on: March 16, 2016, 06:18:37 pm »
... I have this old tube amp with a selenium rectifier bridge.
i upgrade it with a modern rectifier bridge (is not new. I get it from some old equipment) ...
What is the amp? Are you sure the selenium rectifier was a bridge rectifier (with 3 or 4 lugs for soldering wires)?
I only ask because many selenium rectifiers in tube amps are a half-wave rectifier, some are a full-wave rectifier, some are bridges, some are a bridge part but wired as a full-wave rectifier.
Offline chocopower
« Reply #9 on: March 16, 2016, 06:28:25 pm »
yes sure. 4 wires.
I made that mistake years ago and learned the lesson...  :BangHead:
David
Offline chocopower
« Reply #10 on: March 16, 2016, 06:32:44 pm »
One similar to this:
David
Offline chocopower
« Reply #11 on: March 16, 2016, 06:34:57 pm »
And i install one similar to this:
David
Offline trobbins
    • Tim's projects and info
« Reply #12 on: March 16, 2016, 06:40:50 pm »
The vintage rectifier was most likely CuO, not selenium.  If you crack it open you would likely find a few cylindrical stacks of small disks.
You should really try and locate some common diodes like UF4007, and just use them for replacements (even if you have to make up a full bridge).  Using very large current modern diodes/bridges can cause there own noise and hum issues due to capacitance and reverse recovery.
Offline chocopower
« Reply #13 on: March 16, 2016, 06:49:09 pm »
ok.
I have some 4007 around here.
I just used the bridge because it seems nice and make simple the process, but i didn´t know that using a "too" big one could generate problems.
Tomorrow i´ll install the 4007.
Thanks!!
David
« Reply #14 on: March 17, 2016, 12:28:49 am »
Offline chocopower
« Reply #15 on: March 17, 2016, 07:03:38 am »
Ok....
diodes and resistors and caps in the B+ line changed. Noise still there.
Right now, the only original cap is the bypass cap for the power tube cathodes.
Schematic attached.
Any idea¿?
« Last Edit: March 17, 2016, 07:17:19 am by chocopower »
David
« Reply #16 on: March 17, 2016, 07:29:05 am »
Try a fresh set of tubes, especially the output tubes.
Offline chocopower
« Reply #17 on: March 17, 2016, 08:25:29 am »
Yep..
is the last thing i can try. I have not a pair of el84.
Have to say that with the rectifier upgrade voltages rises from 255v to 292v in A point in the B+ rail.
This could damage the old EL84 pair....
David
« Reply #18 on: March 17, 2016, 08:33:34 am »
Why did you replace the original rectifier? If you put the original rectifier back in does the noise go away?
Offline chocopower
« Reply #19 on: March 17, 2016, 09:06:48 am »
The original rectifier had a huge voltage drop.
Power transformer have 115-115 secondaries and after rectifier i get 255vdc.
With new diodes i get 292vdc.
David
Offline chocopower
« Reply #20 on: March 17, 2016, 09:56:10 am »
more...
in the coupling caps for the power tubes i have 3mV in one and 1.5mV in the other.
Is this leaking too much?
David
« Reply #21 on: March 17, 2016, 10:31:21 am »
no
Did you have hum before you replaced the rectifier?
Offline chocopower
« Reply #22 on: March 17, 2016, 10:37:20 am »
no
David
Offline chocopower
« Reply #23 on: March 17, 2016, 10:41:17 am »
More information.
With the light-bulb limiter, star as normal. Light goes down, but after 4-8 second the bulb light increase at the same time the noise came. Bulb not light really high, but seems i have a short....
David
« Reply #24 on: March 17, 2016, 10:49:26 am »
You had used a *block-molded* bridge, then was suggested 4007's, which do you have now?
You might have 1 bad diode in the bridge configuration?  Measure Volts AC from the + of the bridge to ground, how much AC is there?
« Reply #25 on: March 17, 2016, 10:50:13 am »
What you describe is exactly how a light bulb current limiter should operate when connected to a properly working amp.
Offline chocopower
« Reply #26 on: March 17, 2016, 09:53:32 pm »
I changed the block-molded bridge for 4 new ones 4007´s.
Noise is still there.....
Tomorrow i´ll make those measurements.
Everybody, thanks a lot for your help!
David
Offline chocopower
« Reply #27 on: March 18, 2016, 02:28:38 pm »
I dont know.
I clean up the layout, move some wires and hum is gone.
The good thing, i made a lot of search, after all your recommendations, and learn a lot new stuff in the process.
Thanks a lot!!!!!
David
« Reply #28 on: March 18, 2016, 03:04:33 pm »
Nice, all is well that ends well
Please can you say more about the Bern Toaster ?
Ciao
Offline chocopower
« Reply #29 on: March 18, 2016, 03:22:12 pm »
Yep..  Sometimes the solution is just do the things with calm and care.
The amp is an old french amp (60´s).
The original design had only a 12ax7 wired in gain stage + cathodyne and a pair of EL84 in cathode bias and U.L.
I added a ef86 gain stage and reorganize the B+ rail. Original amp have the b+ supply for the O.T. after the choke.
I rise the filter cap values from 8uf to more modern values.
Right now im working in tune the high/bass response.
I´m looking for the cleanest amp possible and use pedals for get "more".
I have no way to do pictures right now, but the look is a LOT like a and Orange Tinny Terror, but in grey.
My main concern is the O.T.
It have 4-8-16 outputs, but is not easy to change from one to other. The secondaries are those with a lot of taps and you need to combine them in different ways to get the needed option.
I attach the transformer specs.
« Last Edit: March 18, 2016, 03:26:48 pm by chocopower »
David
« Reply #30 on: March 18, 2016, 03:55:55 pm »
I've the same situation on some Geloso and RCF OT (old PS amps)
An ef86 in V1 is a strange choice for an amp you want to get the max clear
Which is the reason for this choice, filament current ?
(I've seen the 56k plate resistor)
Offline chocopower
« Reply #31 on: March 18, 2016, 03:58:26 pm »
I just love EF86.
I explain me wrong. i love clean, but no so clean. :icon_biggrin:
I already try the same configuration but with EL34 and is my main amp.
David
« Reply #32 on: March 18, 2016, 04:29:00 pm »
The 56k plate resistor tame at the right level the esuberance of the EF86, a more quiet tube will be 5879, but isn't so easy to have under hand
(I mean by second hand or at Hamfest here in Italy)
I've a bounch of EF86 (some NOS some used) and only a pair of 5879 that I bought new
« Reply #33 on: March 18, 2016, 09:24:37 pm »
Bah. They were obsessed with the last dB of fidelity. Wire it like this and switch freely.
There will be some difference of response above 10KHz. And 4-Ohm will measure slightly lower output than 8 and 16. But since we never have speakers *identical* except for impedance (and speaker impedance is always a wide target), who cares?
Offline chocopower
« Reply #34 on: March 18, 2016, 10:50:08 pm »
PRR, thanks a LOT!
David
