August 29, 2026, 02:05:23 pm
Hoffman Amps Forum image Author Topic: PA conversion finished – odd plate voltage reading  (Read 4939 times)
g-man
  • Guest
« on: April 06, 2016, 08:35:18 pm »
« Last Edit: August 06, 2024, 03:03:23 pm by g-man »
g-man
  • Guest
Re: PA conversion finished – odd plate voltage reading
« Reply #1 on: April 07, 2016, 05:49:55 am »
« Last Edit: August 06, 2024, 03:03:57 pm by g-man »
« Reply #2 on: April 07, 2016, 06:56:38 am »
Now I'm thinking my regular meter probe was unable to get a good reading on V5 because it was closer to the phase inverter, NFB wire, OT? Does that seem likely?
Normally, no.
You have something wired to pin 1 of your sockets. What is it?
« Reply #3 on: April 07, 2016, 07:26:34 am »
I believe pin 1 is connected to the PI coupling caps and there is a grid stopper mounted between pin 1 and pin 5, Fender style.
g-man
  • Guest
« Reply #4 on: April 07, 2016, 07:35:27 am »
Deleted
« Last Edit: August 06, 2024, 03:05:11 pm by g-man »
« Reply #5 on: April 07, 2016, 07:50:59 am »
I've see the same thing happen  a couple times while testing plate voltage on the output tubes. Each time it was caused by a poor connection between the probe and the socket. The poor connection would even cause a high freq oscillation that could be heard through the speaker. Using needle tipped probes or gator clips gave a reliable connection and reading. Maybe this was happening with you?
g-man
  • Guest
« Reply #6 on: April 07, 2016, 08:22:56 am »
Deleted
« Last Edit: August 06, 2024, 03:06:03 pm by g-man »
« Reply #7 on: April 07, 2016, 10:53:10 am »
Hi Stu! I replied last night then removed it but was thinking the "odd" photo was correct and the "normal" one was not. If you don't recognize the "." placement holders then the 423 vdc looked much more normal than only 9.25volts on a plate reading!
g-man
  • Guest
« Reply #8 on: April 07, 2016, 09:12:17 pm »
Deleted
« Last Edit: August 06, 2024, 03:06:29 pm by g-man »
g-man
  • Guest
« Reply #9 on: April 07, 2016, 09:17:27 pm »
Deleted
« Last Edit: August 06, 2024, 03:06:53 pm by g-man »
« Reply #10 on: April 08, 2016, 12:29:59 am »
on volt chart: V5-6 pin 7 should be V5-6 pin 8 column?
g-man
  • Guest
« Reply #11 on: April 08, 2016, 06:12:33 am »
Deleted
« Last Edit: August 06, 2024, 03:07:18 pm by g-man »
