August 29, 2026, 02:52:14 pm
Hoffman Amps Forum image Author Topic: KT88 O/P tranny  (Read 6574 times)
Offline ernie_jr
  • gimme a banana
KT88 O/P tranny
« on: April 08, 2016, 09:49:49 am »
Will KT 88's be able to pull a 3800 ohm load at 530 volts on the plates?   I have Hammond O/P that is rates 60 watts at 3800 Ohms
Ernie
Re: KT88 O/P tranny
« Reply #1 on: April 08, 2016, 11:56:00 am »
Not exactly enough info Ernie. However in fixed bias pri Z is in the ballpark but OT power rating not enough, cathode bias pri Z is not good even mis-matching pri z w/ speaker load but ballpark may be acceptable with tone and output power losses? Hard to say on that one until built & tested?
Offline ernie_jr
  • gimme a banana
Re: KT88 O/P tranny
« Reply #2 on: April 08, 2016, 12:05:03 pm »
Fixed bias and I wont be running it full out
Ernie
Re: KT88 O/P tranny
« Reply #3 on: April 08, 2016, 12:13:41 pm »
you probably won't be able to even if you wanted at 3.5k, but 3.5k at 8ohms, should be 7k at 4ohms, then you'd be close enough from the *old* data sheet I have
Re: KT88 O/P tranny
« Reply #4 on: April 08, 2016, 01:13:45 pm »
Will KT 88's be able to pull a 3800 ohm load at 530 volts on the plates?   I have Hammond O/P that is rates 60 watts at 3800 Ohms ...
In class AB, the load to one side will be Primary Z / 4, or 950Ω for your OT.
Page 7 of the KT88 data sheet shows a knee for G2=200v at either Plate=50v, 260mA or Plate=40v, 250mA. 950Ω * 260mA = 247v + 50v (across the plate) = ~300vdc. You're best adding some additional plate voltage to allow for sag, and if cathode biased you should add the bias voltage to this figure. Power output will be ~32w.
Page 7 has a separate graph for G2=300v, with a knee at (an estimated) Plate=80v, 400mA. 950Ω * 400mA = 460v, plus anticipated sag (with an average current of ~255mA just for the KT88 plates). Power output will be ~76w, so bass response/bandwidth will probably suffer a bit.
Or you could split the difference. Say 500v plate, 250v screen and call it a day?
Offline ernie_jr
  • gimme a banana
Re: KT88 O/P tranny
« Reply #5 on: April 08, 2016, 01:36:54 pm »
the amp is basically and Ampeg b 25
Ernie
Re: KT88 O/P tranny
« Reply #6 on: April 08, 2016, 03:10:50 pm »
That amp would need a significantly-different power supply to provide KT88's a screen voltage which makes sense with that load.
Re: KT88 O/P tranny
« Reply #7 on: April 08, 2016, 05:20:14 pm »
Ernie
the only hammond 60W OT i can find are 4.3K or 6.6K. is this OT from a hammond organ?
btw, it'll work. not optimally, but it will. you can run the screens at near B+, however, you'll need to increase (-)biasV significantly and grid drive requirements will increase more or less proportionally. i'd use 1K on screens perhaps even 1.5K.
Offline ernie_jr
  • gimme a banana
Re: KT88 O/P tranny
« Reply #8 on: April 09, 2016, 08:17:01 am »
It is an old hammond, not even a UL version I got off Ebay for $40.  I can still find the specs when I google it.  It has alot of iron for a 60 watt transformer. The power supply I am using is straight out of a SUNN 200s with Ampeg b25 pre-amp and phase inverter.
Ernie
Re: KT88 O/P tranny
« Reply #9 on: April 09, 2016, 08:51:05 am »
It is an old hammond, not even a UL version ... The power supply I am using is straight out of a SUNN 200s ...
You will make a screen node, right? The 200s had a UL OT.
Dummy load is right that you could have KT88 screen voltage up near plate voltage, but as he says, you'll need a much bigger bias voltage (than using 250v screen) and consequently a much bigger drive voltage from your phase inverter.
Offline ernie_jr
  • gimme a banana
Re: KT88 O/P tranny
« Reply #10 on: April 09, 2016, 09:48:04 am »
Have 1000 ohm 5 watt screen resistors and I can get as high as -64 volts for the bias,
How did Ampeg get away with voltages like this on the 7027's?
thanks
ernie
« Last Edit: April 09, 2016, 09:50:57 am by ernie_jr »
Re: KT88 O/P tranny
« Reply #11 on: April 09, 2016, 09:55:37 am »
I meant that since the 200s is UL, there is no screen node in the power supply. You'll need to add a screen supply node, at which point you can consider what d.c. voltage should be at that node.
Offline ernie_jr
  • gimme a banana
Re: KT88 O/P tranny
« Reply #12 on: April 09, 2016, 10:06:23 am »
Thanks, I Know, will use taps as fender dose, When I said SUNN, I meant 400 volt P/T, 1.5 Henry choke, just using filter caps of 110, 50, 40, 40mfd for the 4 nodes.
Thanks for all the advice,
Ernie
Re: KT88 O/P tranny
« Reply #13 on: April 09, 2016, 04:54:43 pm »
thanks
ernie
600VDC is max plate voltage and 500VDC is max g2 as stated in RCA datasheet. apply higher (-)biasV to compensate for higher g2 voltage. there is a condition for 2 tubes @ 540V B+ and 400V g2 that makes 75W into 6.5K. if driving with 2 pair into 3.25K load, you theoretically have a 150W amp. ampeg V4/V22 run 2 pair of 7027 into 2.9Ka-a Z load and ampeg states that it makes 100W. it would seem that with 2 pair of 7027 it should be 150W, however, the V4 manual states that it can be as much as 30% higher than the figure printed on the back of the chassis.
ampeg V4 manual
RCA 7027-A datasheet
« Last Edit: April 09, 2016, 05:00:36 pm by DummyLoad »
