August 29, 2026, 02:05:50 pm
Hoffman Amps Forum image Author Topic: Modify 5F1 to use 6L6  (Read 10753 times)
Offline leevc5
« on: May 09, 2016, 07:00:24 pm »
How I modify my 5F1 kit to use and take advantage of the higher power output of a 6L6?
If not is there a way to put two 5F1 kits together and get one ~10 Watt amp?
Re: Modify 5F1 to use 6L6
« Reply #1 on: May 09, 2016, 09:08:58 pm »
How I modify my 5F1 kit to use and take advantage of the higher power output of a 6L6? ...
What kit are you using? Is this a Hoffman board, using all the parts on the BOM? Do you already have the power & output transformers, or are you in a planning stage?
Offline leevc5
« Reply #2 on: May 09, 2016, 09:52:28 pm »
I already have the hoffman kit built.
« Reply #3 on: May 10, 2016, 07:02:57 am »
What specific power & output transformers are you using?
« Reply #4 on: May 10, 2016, 10:59:17 am »
What I did to my VibroChamp might help.
« Reply #5 on: May 10, 2016, 12:21:56 pm »
Jjasilli,
Really been itching to build a SE 6L6.  Is there anything you would do differently?
Any particular reason for using 2 Orange Drops to bypass V1, or just what you had?  The 1uf/3k3 Bias on both cathodes I have seen in a Morgan Amp, but never done it myself.  Did you do that to keep Bass frequencies off a smaller speaker or just like it?
The 330pf from pin 5 to 8, how effective is it?
Offline leevc5
« Reply #6 on: May 10, 2016, 12:26:23 pm »
I am using W022772 PT and W022905 OT.
« Reply #7 on: May 10, 2016, 12:29:40 pm »
Jjasilli, what is the PT in your schematic?
Offline leevc5
« Reply #8 on: May 10, 2016, 12:53:08 pm »
Thanks for all the help.  This is great!
« Reply #9 on: May 10, 2016, 12:53:40 pm »
The W022772 6.3v filament winding is rated @4A so no problemo there. Selectable 600v or 660v on the main secondary as well. That's a good little PT.
« Last Edit: May 10, 2016, 05:12:37 pm by mresistor »
« Reply #10 on: May 10, 2016, 01:09:10 pm »
My PT is stock Fender VibroChamp:  125P1B
Note:  the filter choke occupies the spot on the chassis which formerly held the OT.  The new, bigger OT is on a supplemental chassis mounted to an inner sidewall of the cabinet.
« Last Edit: May 10, 2016, 01:16:23 pm by jjasilli »
« Reply #11 on: May 10, 2016, 05:24:31 pm »
manufactured by whom?
« Reply #12 on: May 10, 2016, 06:34:15 pm »
It's a SilverFace Fender VibroChamp with a stock PT.  Don't know manufacturer.
Offline Fresh_Start
  • noob de Lux
« Reply #13 on: May 10, 2016, 11:59:16 pm »
Documents on AX84.com cover just about every power tube.
May I suggest a choke between the "reservoir" cap and the OT node on the power rail?  Much cleaner power supply.  Might help even more with a 6L6.
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #14 on: May 11, 2016, 06:17:52 am »
I am using W022772 PT ...
And the stock Princeton/Princeton Reverb PT. It and the W022772 PT are capable of 70-100mA on the high voltage winding, so powering a 6L6 (for actual increased power output) should be no problem.
... W022905 OT.
Okay, a 7kΩ:4Ω OT.
Assuming your B+ lands ~375-400v, you could bias a 6L6GB/5881 (or any 25w or higher variant) to ~62mA and get ~11w of output power. To get the most out of a 6L6GC (which would still only be a couple extra watts), you'd really like a 4-5kΩ primary impedance (probably what Jjasilli is using with his Hammond OT).
Offline leevc5
« Reply #15 on: May 11, 2016, 08:48:27 am »
I sincerely thank you all for the help and advice but it looks like the bottom line is that where I am with the current kit it is not worth the effort to just get a couple of Watts.
I will save the schematic for my next build so that I can get the full advantages of using a 6L6.  Or I might look at doing a dual 6V6 or 6L6 build, I'll have to do a cost analysis.  The darn PTs and OTs cost are just killers when you want to build a kit I wish I could find a source that had better prices.
« Reply #16 on: May 11, 2016, 09:06:44 am »
That PT will support a 6L6. The OT will too. Connect a 4Ω speaker to the 8Ω tap. Then simply replace the 5Y3 and 6V6 with a 5U4 and 6L6.
« Reply #17 on: May 11, 2016, 03:00:43 pm »
If it has "606" printed or stamped on it anywhere   it was made by Schumacher for Fender.
