September 14, 2026, 12:04:59 am
Hoffman Amps Forum image Author Topic: 5E3 V1 Voltages  (Read 6339 times)
Offline mayburyds
5E3 V1 Voltages
« on: May 12, 2016, 03:37:57 pm »
Hi,
Need some advice again please!
Had a problem with the socket on V1 and a lose pin 6.
After replacing the faulty socket I measured the voltages on pin 1 & 6 and they read about 100vdc with all the controls at zero, if that makes any difference. After playing for about an hour I turned down the controls to zero and checked the voltages again and they were up to around 125vdc.
Is this normal or should they be static?
I do have a VRM kit installed and the amp sounds ok.
Any thoughts appreciated.
Cheers.
Re: 5E3 V1 Voltages
« Reply #1 on: May 12, 2016, 04:16:10 pm »
VRM?  :dontknow:
Offline mayburyds
Re: 5E3 V1 Voltages
« Reply #2 on: May 12, 2016, 05:05:57 pm »
Sorry, it's a VVR kit from Trinity amps for varying the b+ voltage.
Cheers.
Offline Paul1453
Re: 5E3 V1 Voltages
« Reply #3 on: May 12, 2016, 05:37:31 pm »
When something doesn't seem right to me, I try to look at the circuit and components involved and try to figure out if things are operating within their parameters.
Pins 1 & 6 are your plates, and they are supplied voltage from the PS through the plate resistors.
Resistors can drift, but 25% change would be outside of specifications.
Resistors also tend to decrease in resistance when they get hot.
If your VVR hasn't increased 25% then I wouldn't expect the V1 plate voltages to increase 25%.
So, what's next?  Well the tube right?
If the tube was conducting more current when it was cold,
there would be a bigger V drop across the plate resistors,
and the plate voltages would be lower.
If when the tube warms up it starts conducting less current,
there would be less V drop across the plate R's and higher V on pins 1 & 6.
If there are voltage numbers on the schematic, are your voltages within +/- 20% of that?
If things sound good, and your numbers are within that 20% range then I wouldn't worry about it too much.
You could try to swap that tube and see if you get the same results.  :dontknow:   :icon_biggrin:
Offline mayburyds
Re: 5E3 V1 Voltages
« Reply #4 on: May 12, 2016, 05:42:18 pm »
Thanks for the reply. I'll swap the tube tomorrow and check the voltages.
Cheers.
Re: 5E3 V1 Voltages
« Reply #5 on: May 12, 2016, 06:07:52 pm »
... After replacing the faulty socket I measured the voltages on pin 1 & 6 ... After playing for about an hour I turned down the controls to zero and checked the voltages again and they were ...
Does the amp sound good?
If so, it's probably fine. A 25v increase at that plate (if your plate load resistor is exactly 100kΩ) just means a reduction in tube current of 25v/100kΩ = 0.25mA. That could be normal tube drift, especially if these are new tubes.
Offline mayburyds
Re: 5E3 V1 Voltages
« Reply #6 on: May 12, 2016, 06:14:38 pm »
Amp sounds fine and the tubes are about a year old.
I'll try another tube just to see if it makes a difference.
Thanks.
Offline mayburyds
Re: 5E3 V1 Voltages
« Reply #7 on: May 13, 2016, 03:21:07 am »
Hi,
Measured the voltages cold this morning and they read 100vdc. Left the amp cooking for an hour and remeasured the voltages which again read 100vdc.
But when I adjusted the VRM/VVR control down and then back to full the voltages went up to around 125vdc. I kept the DMM attached and the voltage gradually dropped back down to around 100vdc after about a minute or so.
So, I now understand why I get different voltages and I guess it's the amp settling down after the change in voltages due to the VRM/VVR adjustment.
Many thanks for the replies and help, much appreciated.
Cheers.
Offline Paul1453
Re: 5E3 V1 Voltages
« Reply #8 on: May 13, 2016, 04:49:55 pm »
It is always good to learn the little intricacies of our amp's circuits!
Especially if we implement mods to the original design.   :icon_biggrin:
