September 14, 2026, 11:16:19 pm
Hoffman Amps Forum image Author Topic: 1969 Super Reverb leaking reverb with pot at zero  (Read 5171 times)
Offline fradenigris
  • change those filter caps...
    • NGR Pedals
« on: June 18, 2016, 01:15:56 pm »
Hello,
as thread title implies I have a problem with a '69 Super Reverb: I can still hear a faint reverb even with reverb pot at zero. I replaced the pot with a CTS one to no avail. Any suggestion?
Thank you!
Re: 1969 Super Reverb leaking reverb with pot at zero
« Reply #1 on: June 18, 2016, 02:20:40 pm »
Can you totally kill the reverb by turning it off with the footswitch?
Use a gator jumper clip lead connected between the middle lug of the reverb pot and chassis ground. Does this kill the reverb?
« Reply #2 on: June 18, 2016, 04:08:49 pm »
Fender put out a technical bulletin about the vibrato
 http://bmamps.com/Schematics/fender/Tech_Notes_-_Vibrato_Ticking_Fix.pdf
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« Reply #3 on: June 18, 2016, 08:16:00 pm »
pot is dirty or defective , check with ohmmeter
Colas
P.S.: call me Alvin.
