September 14, 2026, 04:01:14 pm
Hoffman Amps Forum image Author Topic: LED in Hoffman AB763 bias vary tremolo?  (Read 4952 times)
Offline bnwitt
  • Crankin' out the tone.
« on: September 05, 2016, 05:19:45 pm »
Has anyone replaced the R/C components on the Hoffman AB763 V5-A Tremolo Oscillator with an LED?  If so does it work/do anything to the strength of the oscillator?
Re: LED in Hoffman AB763 bias vary tremolo?
« Reply #1 on: September 05, 2016, 05:23:56 pm »
I did it with a Gibson trem, took it from mild mannered to ballsy and brash, the musician types liked it
« Reply #2 on: September 05, 2016, 07:06:51 pm »
Sluckey has and reported it strengthens the oscillator output.You essentially have perfect bypassing down to d.c.
Offline bnwitt
« Reply #3 on: September 05, 2016, 07:25:36 pm »
Thanks for the replies Shooter and HBP.  Looks Like I'll be giving it a try.  The player I'm building a BFDR for wants that strong Ry Cooder Tremolo tone.
« Reply #4 on: September 06, 2016, 10:00:12 am »
... The player I'm building a BFDR for wants that strong Ry Cooder Tremolo tone.
I wonder if Cooder used a small amp which injects trem at a preamp cathode, like a VibroChamp.  They certainly get swampy trem...
The tweed Tremolux gets a swampy trem as well.  I don't know your appetite for building experimental amps, but it seems you could graft a blackface preamp to the tweed Tremolux paraphase inverter & output section.  Or the player could use an EQ pedal to scoop mids if a tweed Deluxe/Tremolux isn't the right sound.
Offline bnwitt
« Reply #5 on: September 08, 2016, 01:29:57 pm »
I did a little research on Ry Cooder's equipment and he has lots of amps and guitars.  The vibroverb and tweed deluxe were amps he had on stage at a few performances:
http://www.thegearpage.net/board/index.php?threads/ry-cooders-backline-on-october-3-2008.448912/
He supposedly uses an outboard compressor somewhere in his signal chain and he has a little tube preamp built into a variac body for feeding the BFVV and Tweed Deluxe as well:
http://www.rycooder.nl/pages/ry_cooder_Instruments_gear_amps_effects.htm
I'm putting a middle control on this BFDR's tremolo channel as I always do with black faced Fender amps as I just think not having one stinks.
Barry
« Last Edit: September 08, 2016, 01:32:28 pm by bnwitt »
