September 15, 2026, 10:00:15 am
Hoffman Amps Forum image Author Topic: Recommendations for a EL84 based amp build  (Read 7294 times)
Offline Planobilly
« on: September 26, 2016, 10:36:15 am »
Hi guys,
The Hoffman AB763 amp I have finished went well. I now would like to build a EL84 based amp.
What I really wanted was to build a turret board style amp like a Zinky Blue Velvet. I have never been able to find a schematic of that amp. I guess I could call Bruce Zinky to see if one exist. I am not sure what he would have to say. I use to have one but I never took it apart.
Has anyone here ever played a Blue Velvet and if so can you recommend something similar?
Billy
Between fishing, flying, and fooling around with guitar amps, somehow 70 years got behind me. Shorter of breath and one day closer to death as the song goes.
Re: Recommendations for a EL84 based amp build
« Reply #1 on: September 26, 2016, 01:59:41 pm »
fwiw, not a Zinky;
find your favorite '84 pa, and well, adjust as needed :dontknow:
Offline NEjoe
« Reply #2 on: September 27, 2016, 12:41:18 pm »
Never played a blue velvet amp.
Are they single ended or push-pull?
« Reply #3 on: September 27, 2016, 02:16:39 pm »
> not a Zinky
I really suspect that is a Hi-Fi line amp, not a geetar amp fragment.
"Blue Velvet" can mean different things to different people.
Offline labb
« Reply #5 on: September 27, 2016, 02:51:07 pm »
You might/are correct, like K I hoard novel schematics, knew I had velvet, and looking a second time I did file it under hifi, my out
adjust as needed
:icon_biggrin:
2amps back, I did use similar architecture 6SN7, it made it to the public domain 4guitar
Offline Planobilly
« Reply #6 on: October 01, 2016, 12:37:30 am »
Hi,
Bruce Zinky was a designer working for Fender who designed the Prosonic as a custom shop project. He is now the owner or part owner of the Supro line of amps.
I have read that the  new Supro Dual Tone is the same as a Blue Velvet but I am sure that is not true. A Blue Velvet has tube reverb and the new Supro does not. The Blue Velvet uses two EL84 tubes and the Supro uses 6973 tubes.
I have ask a lot of people about a schematic and done a good bit of searching with no results. I also have not seen any of the new Supro schematics.
I may not find a schematic but I can buy the amp used for around $800....pretty pricey way to get a schematic....lol
Cheers,
Billy
Offline VMS
« Reply #7 on: October 01, 2016, 02:17:59 am »
It's not the new 1624T dual-tone which I think is a reissue of an old supro. But I believe those Blue velvets were made under supro name for a while:
https://reverb.com/item/405990-zinky-blue-velvet-supro-dualtone-2011-black
https://reverb.com/fi/item/2859424-supro-1624t-dual-tone-1x12-combo
